jAndrew Samba Member
Joined: October 11, 2020 Posts: 306 Location: Atlanta, Georgia
Posted: Sun Mar 28, 2021 12:18 pm Post subject: Ignition switch parts |
Today I noticed that while the ignition is off the passenger side headlights do not work. All three do not light- the low and high beam and the city lights. When truck is running they work as they should.
From reading here it seems the issue is the ignition switch. While ordering parts I see there is a connector and a "ignition switch- electrical portion" at VanCafe. Are these the only 2 parts I need to replace? _________________ '89 Syncro Doka |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Sun Mar 28, 2021 12:32 pm Post subject: Re: Ignition switch parts |
jAndrew wrote: |
"ignition switch- electrical portion" at VanCafe. Are these the only 2 parts I need to replace? |
That's one part. Yes, that would be the one you need. What is the second part?
Also, order two. They are prone to failure, cheap and easy to replace. So put a new one in, and keep the other one as a spare.
(Just to make sure, can you post the link of the product you're thinking about? To remove any potential confusion) _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Sun Mar 28, 2021 12:39 pm Post subject: Re: Ignition switch parts |
VicVan wrote: |
jAndrew wrote: |
(Just to make sure, can you post the link of the product you're thinking about? To remove any potential confusion) |
Doh! Second part listed- https://www.vancafe.com/111953631-p/111953631.htm _________________ '89 Syncro Doka |
jimf909 Samba Member
Posted: Sun Mar 28, 2021 1:19 pm Post subject: Re: Ignition switch parts |
The second part, the plug housing, isn't necessary unless it's broken. My experience is limited to a few switch replacements and the plug has never been broken.
There's a link in this thread for good switch replacement instructions.
https://www.thesamba.com/vw/forum/viewtopic.php?t=375383
p.s. Do you haul the Sprite and Smart Car in the trunk of the Eldorado? _________________ - Jim
Abscate wrote: |
hardway Samba Member
Joined: January 03, 2012 Posts: 416 Location: Fidalgo Island
Posted: Sun Mar 28, 2021 2:12 pm Post subject: Re: Ignition switch parts |
The reason that the ignition switch connector housing needs to be replaced sometimes is that it can melt from the electrical load, usually on the X contact. The terminal X powers loads that are turned off during cranking to save current for starting. The X contact powers the blowers, headlights and probably the rear defrost. The headlights are not powered normally unless the ignition is on. They cut out during cranking. Of course many headlight power systems are no longer stock. But most of the systems (Jay Brown) style still shut off unless the X contact is hot. |
Posted: Sun Mar 28, 2021 2:26 pm Post subject: Re: Ignition switch parts |
^^^ Of course, melting is the problem, not breaking. Good point. _________________ - Jim
Abscate wrote: |
Posted: Sun Mar 28, 2021 2:36 pm Post subject: Re: Ignition switch parts |
jimf909 wrote: |
p.s. Do you haul the Sprite and Smart Car in the trunk of the Eldorado? |
Usually just the dead bodies of smart ass ppl. _________________ '89 Syncro Doka |
Posted: Sun Mar 28, 2021 2:37 pm Post subject: Re: Ignition switch parts |
Thanks guys! I ordered both, cheap enough compared to most things. _________________ '89 Syncro Doka |
DuncanS Samba Member
Not only melting, but 10" high flames too. Had the steering column cover off and melting plastic insulllation was dripping on my legs. Luckily heavy duty corduroy. It was the 30 lead and couldn't be shut off. I don't recommend it. Good thing it wasn't summer and shorts.
Relay EVERYTHING. Keep switch loads as low as possible and neither they not the plugs will fail. I have both my 30 and X loads relayed so the ignition only sees coil loads.
Don't know about Dokas, but Vanagons don't have working headlights with the ignition switch off. |
