liquidrush Samba Member
Posted: Mon Mar 22, 2021 1:38 pm Post subject: Speedometer cable question |
I bought a VW speedo to use in my buggy, I was hoping someone could give me an idea of which cable I should use. Just a quick search and I see half a dozen different ones. I was going to use the grease cap I already have, drill a 1/2" hole in it and take the disc brake cap, cut out the portion with the square hole and weld it in place on my cap. Should make a nice smokey mess in the shop. |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Mon Mar 22, 2021 10:11 pm Post subject: Re: Speedometer cable question |
Try one from a super beetle I think they are a few inches longer than a bug and a little long in a a buggy will probably work. And I would just drill the square hole directly in the cap |
stevebaz Samba Member
Joined: March 14, 2008 Posts: 189 Location: El Monte CA
Posted: Tue Mar 23, 2021 3:33 pm Post subject: Re: Speedometer cable question |
dont forget the rubber seals for the speedo cable in the spindle. |
Posted: Sat Mar 27, 2021 2:06 pm Post subject: Re: Speedometer cable question |
Well I got my cable, there's no dang hole in my spindle. Am I missing something simple? Maybe I'm just not seeing it, I don't know. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5412 Location: Holland, MI
Posted: Sun Mar 28, 2021 11:23 am Post subject: Re: Speedometer cable question |
I don't think so, these are late 50s factory spindles. LH thread on the left side and of course king pins. I thought all vw beetles used a speedo drive off the LF wheel. |
dustymojave Samba Member
Posted: Sun Mar 28, 2021 7:25 pm Post subject: Re: Speedometer cable question |
If seems it's not drilled, maybe it's clogged with junk. Dirt, old grease, etc. Packed in there. Try drilling it out with a 1/4" drill bit. If you run into shiny metal, it's not drilled. If it's not drilled., it's not a spindle from a street Bug. _________________ Richard
SoCalBajas Member
Posted: Mon Mar 29, 2021 10:16 am Post subject: Re: Speedometer cable question |
May have a pin pressed in it. The buggy book goes over this. |
Posted: Mon Mar 29, 2021 1:34 pm Post subject: Re: Speedometer cable question |
May be easiest to see from the wheel bearing side. I would pull the drum brake and inspect that way. Last thing you want to do is push a bunch of dirt into the cavity where the wheel bearings are. Then you have to clean and repack the outer wheel bearing, making sure every last spec of dirt has been removed. Sounds like more work to pull the drum, but you will likely be time ahead in the long run. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
