Rear wheel bearing brand
Wellington
Wellington is offline
PostPosted: Mon Mar 29, 2021 4:09 pm    Post subject: Rear wheel bearing brand Reply with quote
I'm presently redoing a set of rear bearing housings.
I'm looking for the BEST bearings available, FAG use to be the norm, I can find the inner by FAG, but not the outer.
What are the present recommendations for the best quality bearings?
MarkWard
MarkWard is offline
PostPosted: Mon Mar 29, 2021 4:31 pm    Post subject: Re: Rear wheel bearing brand Reply with quote
Id feel comfortable with Timken and SKF.
1982 Vanagon Camper with ALH TDI.
1990 Vanagon Camper Syncro.
In Car https://youtu.be/5hbfdUJR88Q
Wellington
PostPosted: Tue Mar 30, 2021 3:58 pm    Post subject: Re: Rear wheel bearing brand Reply with quote
Timken it is then, thank you Mark ......again!
ZsZ
ZsZ is offline
PostPosted: Tue Mar 30, 2021 11:26 pm    Post subject: Re: Rear wheel bearing brand Reply with quote
The problem is usually with the outer rollers. They are too loose by new. FAG kits have INA outer rollers which are OK in size.
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
the joker
the joker is offline
PostPosted: Wed Mar 31, 2021 4:19 am    Post subject: Re: Rear wheel bearing brand Reply with quote
consider new spacers, there's info on using old verses new Idea also many hubs are worn out
