Rgl1100 Samba Member
Posted: Sun Mar 28, 2021 1:27 pm Post subject: Bus Headlight Switch Mounting |
So I realize this may be a pretty foolish question but I just can't seem to find the answer. I need to replace my headlight switch on my bus. When I pulled the current switch out I determined it was from a Type I bug since it didn't have a tab on #57. I purchased a new switch. It looks like this:
Now, other switches I have that look like this I have been able to unscrew the metal eschuton(?) underneath the knob thereby freeing up the L shaped mounting bracket that contains the screw. However, on this new on, I cannot (even with pliers) unscrew the metal piece which makes me believe its supposed to be mounted using only the screw on the mounting bracket. This is important because,if that's true, I need to enlarge the hole in my dash so that the metal piece below the knob fits through the dash to act as a stablizing point. I don't want to do this before someone tells me this is the way this type of switch is supposed to mount. It also means the previous switch I had that looks like this was not supposed to unscrew from the mounting bracket. Thanks for the help. |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 363 Location: Mississippi
Posted: Sun Mar 28, 2021 2:40 pm Post subject: Re: Bus Headlight Switch Mounting |
Well, just looking at the thing, you've got 3 components: The switch, the bracket, and the aluminum escutcheon (collar). They had to put it together somehow. Perhaps when grabbing the aluminum escutcheon firmly with pliers or vice grips you are crushing what I would imagine are the threads in the escutcheon against the shaft of the switch. I'd try wrapping the side of the aluminum escutcheon with a thick rubber band, then try to remove it with pliers or vice grips using a bit lighter grip but relying on the rubber band to help with the grip.
Or perhaps it's the third thing other than the left hand hubs on old cars and the collar inside a toilet tank around the handle that I've ever encountered with left hand threads. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Sun Mar 28, 2021 3:08 pm Post subject: Re: Bus Headlight Switch Mounting |
Bus switch mounting doesn't involve the aluminum part.
Unscrew the knob.
Plug the wires in.
Press aluminum part up against the backside of the dash where the hole is.
Screw the screw in.
Screw the knob on. _________________ aka: Evan
Posted: Sun Mar 28, 2021 3:19 pm Post subject: Re: Bus Headlight Switch Mounting |
easy e wrote: |
Bus switch mounting doesn't involve the aluminum part. Plug the wires in... put it in the hole and screw the screw in. |
Ha! You just might be correct about that after looking at the one in my '66. The aluminum escutcheon sure looks thinner and it doesn't have the opposing holes in it to tighten it against the dash like the emergency flasher and the wiper switch. Good catch! |
Posted: Sun Mar 28, 2021 3:20 pm Post subject: Re: Bus Headlight Switch Mounting |
Thank you. That’s what I thought |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
easy e Samba Member
Posted: Wed Mar 31, 2021 8:57 am Post subject: Re: Bus Headlight Switch Mounting |
Thanks! |
