Symptoms of bad automatic transmission cooler?
Thoragaverung
Thoragaverung is offline
PostPosted: Wed Mar 31, 2021 6:39 am    Post subject: Symptoms of bad automatic transmission cooler? Reply with quote
Hi,
I may be going to look at a 1985 vanagon with the auomatic transmision later this week.
I am aware of the pressing need to install a standalone transmission cooler before the integrated unit fails. What I'm wondering is, how can I check the bus to ensure it hasn't already failed? Would I see water on the AT dipstick (is there one?), or AT fluid in the radiator? What shuld I look for so I don't buy a problem?
Thanks.
Happy to help, but my advice comes with no guarantees. Use at own risk.
mikemtnbike
mikemtnbike is offline
PostPosted: Wed Mar 31, 2021 7:10 am    Post subject: Re: Symptoms of bad automatic transmission cooler? Reply with quote
Strawberry milkshake.
2020 GTI SE manual
MarkWard
MarkWard is offline
PostPosted: Wed Mar 31, 2021 7:29 am    Post subject: Re: Symptoms of bad automatic transmission cooler? Reply with quote
Depending on how it failed internally, you'd find strawberry milkshake in the main coolant tank or the ATF would be pink in color after it's run. If it's been sitting the water will separate out of the ATF and be in the bottom of the trans pan. Same is true but in reverse, the ATF will collect at the top of the main coolant tank.
In other words, you need the blender going to get the milkshake.
Thoragaverung
PostPosted: Wed Mar 31, 2021 9:32 am    Post subject: Re: Symptoms of bad automatic transmission cooler? Reply with quote
Thank you both.
Sounds pretty standard-- I'd be checking the fluids for weirdness in any event. Milkshakes are never good no matter where you find them.
kourt
kourt is offline
PostPosted: Wed Mar 31, 2021 10:33 am    Post subject: Re: Symptoms of bad automatic transmission cooler? Reply with quote
Here's some actual ATF/coolant "strawberry milkshake" photos.
Report back and tell us what you find!
kourt
Thoragaverung
PostPosted: Wed Mar 31, 2021 2:14 pm    Post subject: Re: Symptoms of bad automatic transmission cooler? Reply with quote
That doesn't look like a strawberry milkshake. More like an infected wound... ugh
SCM
SCM is offline
PostPosted: Wed Mar 31, 2021 2:17 pm    Post subject: Re: Symptoms of bad automatic transmission cooler? Reply with quote
https://www.marksbeefburgers.com/
You're welcome.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
Abscate Premium Member
Abscate is offline
PostPosted: Wed Mar 31, 2021 2:23 pm    Post subject: Re: Symptoms of bad automatic transmission cooler? Reply with quote
The fact that it’s installed is the problem
I’m not a fan of ersatz engineering followed by bush league implementation, with apologies to those who know what they are doing
Wildthings
Wildthings is offline
PostPosted: Wed Mar 31, 2021 4:00 pm    Post subject: Re: Symptoms of bad automatic transmission cooler? Reply with quote
You also need to check that the ATF and gear oil have not mixed, if one or the other is higher than it should be this might be the case.
