Owl Slayer Samba Member
Posted: Sun Jan 24, 2021 4:04 pm Post subject: Pans |
I've searched without much luck.......
I'm almost ready to order pans for my bug project. I'm inclined to order 18g pan halves from either Wolfsburgwest.com or Mtmfg.com.......but Mtmfg.com carries danish 20g quarter pans that they claim are stronger than half pans because of the welded seam. Does anyone have real life experience with these quarter pans?
18g are just under $600 shipped, quarter pans are just over $300 shipped, hence the question |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Jan 24, 2021 4:43 pm Post subject: Re: Pans |
They will all work/last for a long time. Buy what you can afford & get them installed. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sun Jan 24, 2021 4:52 pm Post subject: Re: Pans |
Thank you for the input |
Tobias Bylund Samba Member
Joined: December 10, 2007 Posts: 202 Location: Varberg - Sweden
Posted: Wed Jan 27, 2021 7:57 am Post subject: Re: Pans |
Dont bother with Klokkerholm, even if they say they are as strong (which i dont believe), they are most certainly not going to have the correct shape.
I have used several klokkerholm panels where i couldnt find a better alternative, and i have had to rework every single one. I went with the WW full pans, and they are very nice, crisp lines and thick metal, they are heavy! 1.2mm thick, where as the klokkerholm panels i have are only 0.9mm (body panels though, cant say for certain with the pans).
Regards |
beetlenut Samba Member
Posted: Wed Jan 27, 2021 8:57 am Post subject: Re: Pans |
I bought and installed one of M&T's quarter pans. The lower rear one in the below picture that holds the battery. I thought it was thicker and better made than the other quarter pan, top front red one, that I installed.
_________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9960 Location: Huntington Beach, CA
Posted: Wed Jan 27, 2021 9:54 am Post subject: Re: Pans |
I have used WW pans on the last 3 Bugs. They are exact copies of the stock pans. Same gauge of steel. I have documented this in a few builds on here.
I did not see it posted. What year Bug. If it is early the ClassicFab pans are decent, too! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Wed Jan 27, 2021 5:56 pm Post subject: Re: Pans |
Thanks for all the replies....my bug is a 65, but the pan is a 71......building a 200hp subaru motor with a subie 5sp trans......just trying to see if the quarter pans were decent or not.......lots of money flying out of my acct......lol |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Wed Jan 27, 2021 10:38 pm Post subject: Re: Pans |
The WW pans are plenty strong and the price is more than right. I only spend more if its an early car that needs a year specific stamping. _________________ modok wrote:
infiniteLoop Samba Member
Joined: October 09, 2020 Posts: 265 Location: Empire State
Posted: Thu Jan 28, 2021 11:22 am Post subject: Re: Pans |
I think that Mill supply and Raybuck are two of the best value pans.Cip has really nice ones but they are not budjet pans. |
Posted: Thu Jan 28, 2021 3:59 pm Post subject: Re: Pans |
infiniteLoop wrote: |
Thank you, I'll look at them |
Posted: Thu Jan 28, 2021 5:10 pm Post subject: Re: Pans |
1/4 pans are fine if you butt weld them in the front.
You have to cut/weld 1/2 way up the slope behind the battery if the body is still on it.
If you're installing a 5 speed then the body has to come off. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Fri Jan 29, 2021 4:18 pm Post subject: Re: Pans |
Mike Fisher wrote: |
If you're installing a 5 speed then the body has to come off. |
Thank you, the body is off as I did some rust repair to the tunnel and the frame head. As this is a mutt in the VW world I'm going with the quarter pans and will do some other reinforcing if necessary.......
Thanks everyone for the help and input |
tspot100 Samba Member
Posted: Thu Feb 04, 2021 9:36 am Post subject: Re: Pans |
mtg pans. used WW pans on 72 and 68...pans arrived bent, twisted and required quite abit of coaxing to fit correctly. not a fan of WW pans. |
viiking Samba Member
Joined: May 10, 2013 Posts: 2667 Location: Sydney Australia
Posted: Thu Feb 04, 2021 2:53 pm Post subject: Re: Pans |
tspot100 wrote: |
Not the pan's fault -it's the transport company's fault.
My WW pans travelled the 8000 miles from LA to Sydney and fitted absolutely perfectly with not one modification. Just slipped in like the original. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Sun Feb 07, 2021 6:39 am Post subject: Re: Pans |
mabey i should clarify. aside from the obvious shipping damage, the pans did not fit well requiring excessive trimming/tweaking to fit. have used other pans which were not only thicker but fit much better than the WW pans.
also ordered a heater channel bottom repair panel which was folded into 1/3rds for shipping. straightening it out was possible but still had creases from the bends. it IS a long panel but there has to be other less damaging methods of shipping. after these incidents and the poor quality fuel pump rebuild kits they used to sell..i avoid WW at all costs. |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Mon Feb 15, 2021 9:38 pm Post subject: Re: Pans |
tspot100 wrote: |
I've only installed one set of pans in my life.. earlier this year, ordered individually from Wolfsburg west. The only damage to the pans was there prior to shipping (no box damage): the forward inboard corners were tweaked up 1/4", looked like from being dropped? It was a non issue and I bent them back flat.
As far as coaxing.. I worked over the rears on both pan halves somewhat to get my edges flat all the way around. The main issue was simply a few low spots on the pans (or high spots on the tunnel), and once I dollied those out the pans sat flat enough to cleco down and plug/rosette weld.
That being said, I had a '65 project at one point, with an aftermarket 20ga pan on one side, and factory OG on the other. The flex in the 20ga pan, body off, was significantly more than the factory side. It may not be an issue to some but one of the more common car accident failure modes of the early model bug is the seats coming off the track. To me, knowing the seat track is already a relatively weak design, I don't care to make the area even weaker by going a full two gauges thinner on the floor pan. I have casually wondered what happens to these thinner floor pans when involved in an accident.. do they crumple up, or do they just tear? _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
elcomicguy Samba Member
Posted: Sat Apr 03, 2021 10:58 pm Post subject: Re: Pans |
3 yrs after WW pans are installed on a '56, I begin reconstruction of the pedal assembly and find only one hole in pan for pedal support bracket. WW says this was not correct for 56-57, and the fix is to cut out old section and weld in. I threw all the cut outs away just weeks ago! Here's the quick fix for me.
