62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Wed Feb 12, 2020 8:05 pm Post subject: Re: The Double Cab / Crew Cab thread |
Matthew Tolbert wrote: |
62DoKaGuy wrote: |
Nice, an early non-humpback 61 and a double cab, which is always badass. Mind sharing the chassis # and/or production date on the plate? |
Thank you I have been on the hunt for a bullet nose doublecab for a few years now. Here is the Mcode plate
And it’s a great-looking one, so patience prevails! Yours is less than a week before and less than 2,000 buses before the switch to humpback front bench. Cool. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Thu Feb 13, 2020 5:41 am Post subject: Re: The Double Cab / Crew Cab thread |
62DoKaGuy wrote: |
congratulations, beautiful truck. I hope to see it at some local shows -
I guess no one answered your question about your distributor. I would reach out to Hazetguy - he can tell you. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Thu Feb 13, 2020 6:39 am Post subject: Re: The Double Cab / Crew Cab thread |
EverettB wrote: |
Wow, that is nice!
which would be more correct a ZV/PAU 4R2 or a ZV/PAU 4R5 |
4R2 for a '61. |
EB did. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
4/62 Double Cab
5/61 Panel (sold)
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Thu Feb 13, 2020 7:04 am Post subject: Re: The Double Cab / Crew Cab thread |
62DoKaGuy wrote: |
EverettB wrote: |
Wow, that is nice!
4R2 for a '61. |
EB did. |
Yes.
If you want to look really correct too, you want the vacuum line with a loop in it:
'61 had no loop at all, just a straight vacuum line, but that was a bad idea as it let moisture flow back into the distributor diaphragm and wore it out _________________ How to Post Photos
Matthew Tolbert Samba Member
Posted: Thu Feb 13, 2020 9:20 am Post subject: Re: The Double Cab / Crew Cab thread |
zuggbug wrote: |
62DoKaGuy wrote: |
I guess no one answered your question about your distributor. I would reach out to Hazetguy - he can tell you. |
Thank you!! I plan to take it to as many of the shows that I can get to so if you see me come say hi. _________________ Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S |
Posted: Thu Feb 13, 2020 9:23 am Post subject: Re: The Double Cab / Crew Cab thread |
EverettB wrote: |
62DoKaGuy wrote: |
EverettB wrote: |
Wow, that is nice!
4R2 for a '61. |
EB did. |
Yes.
'61 had no loop at all, just a straight vacuum line, but that was a bad idea as it let moisture flow back into the distributor diaphragm and wore it out |
Thanks Everett. I’ve got the correct distributor just need the vacuum canister and metal line. I’ll be scouring the classifieds in search of them!!! _________________ Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S |
eddybouwens Samba Member
Joined: October 07, 2006 Posts: 15 Location: the netherlands
Posted: Sat May 30, 2020 1:04 pm Post subject: Re: The Double Cab / Crew Cab thread |
can anybody help me to indentify this gearbox? i'm going to use it for my februari 1960 DC but i now it's not the original one for this bus. Thanks!
Teddyjr Samba Member
Joined: May 31, 2020 Posts: 13 Location: St Petersburg
Posted: Mon Mar 29, 2021 3:54 am Post subject: Re: The Double Cab / Crew Cab thread |
Forgive this "noob" if I'm doing a forum post the wrong way. I did search for about a half hour first.
I just got a '67 Double Cab so this is all new to me. Does anyone know if the DC rear passenger door is interchangeable with a standard bus door? The Obsolete Air-Cooled Documentation Project illustrations at http://oacdp.org/pdfs/5867s8.pdf aren't readable regarding doors in the Body Section 8. I'd appreciate anything regarding the subject. Thanks! |
Posted: Mon Mar 29, 2021 11:30 am Post subject: Re: The Double Cab / Crew Cab thread |
I haven't tried to swap it but people have said it's the same.
The pop-out window will be reversed though as the popout hinge is on the other side of the window frame.
I have seen a few Double Cabs with a backwards pop-out window so I believe they used a regular Bus door _________________ How to Post Photos
Posted: Mon Mar 29, 2021 12:29 pm Post subject: Re: The Double Cab / Crew Cab thread |
EverettB wrote: |
I have seen a few Double Cabs with a backwards pop-out window so I believe they used a regular Bus door |
Thanks for the confirmation. I think I’ll pick up a swap meet bus door and do a side-by-side. I wouldn’t be as interested if my door wasn’t so “roached out”. |
Braukuche Samba Member
Posted: Mon Mar 29, 2021 2:22 pm Post subject: Re: The Double Cab / Crew Cab thread |
Teddyjr wrote: |
I had a regular bus cargo door on my 60 for ages before I restored it and got a correct DC one. The only difference is the way the pop out window mounts and the latch mount is different. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
dubman67 Samba Member
Joined: April 10, 2003 Posts: 273 Location: Big Sky Country
Posted: Tue Apr 06, 2021 12:00 pm Post subject: Re: The Double Cab / Crew Cab thread |
My 62
Bought last year, had lots of free time during the "pandemic" to get it road worthy.
_________________ 67 Bug
62 Double Cab
[url=https://www.vw-mplate.com/mplate2-54829.png]Click to view image[/URL]
"At 17 got my first Volkswagen...and mastered the life long art of dragin...." Ice Cube |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Apr 06, 2021 12:11 pm Post subject: Re: The Double Cab / Crew Cab thread |
dubman67 wrote: |
My 62
wow, that DC is tucking hard. looks like a half a foot? _________________ regards
Uli
Posted: Tue Apr 06, 2021 12:18 pm Post subject: Re: The Double Cab / Crew Cab thread |
mandraks wrote: |
dubman67 wrote: |
My 62
wow, that DC is tucking hard. looks like a half a foot? |
Flipped spindles, adjustable beam, and 2" raised steering box. Previous owner built it to lay on the ground (the wheel wells weren't tubbed though). _________________ 67 Bug
62 Double Cab
Two Glove Boxes Samba Member
Ohio_Style Samba Member
Joined: July 09, 2007 Posts: 610 Location: You'll never leave Sparta alive, Ohio
aa390392 Samba Member
Posted: Mon Aug 16, 2021 3:17 pm Post subject: Re: The Double Cab / Crew Cab thread |
Very nice turk truck.
Great tent...practical. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Mon Aug 16, 2021 6:37 pm Post subject: Re: The Double Cab / Crew Cab thread |
Ohio_Style wrote: |
And now adays. It's a beater truck, but it puts in work.
Beater? I don’t see it that way. That is how a truck as old as that should look and should be used. Mine is nearly the same. A truck unused is a useless truck (parody from Spies Like Us, 1985) hahaha _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
4/62 Double Cab
5/61 Panel (sold)
