classicbug Samba Member
Posted: Mon Apr 05, 2021 11:12 am Post subject: Stalls once warmed up |
My 1960 has developed a habit of stalling (when stopped) after about 15-20 minutes of driving. This happened several months ago, but appeared to resolve itself. I did adjust idle/mixture a couple of months ago as part of a tune up, but the problem didn't start until recently. what's strange is that I ran it for well over 20 minutes in my garage and it never stalled or stuttered. Thoughts/suggestions? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Mon Apr 05, 2021 5:36 pm Post subject: Re: Stalls once warmed up |
Post images of the engine. _________________ In Stereo, Where Available! |
Posted: Tue Apr 06, 2021 6:20 am Post subject: Re: Stalls once warmed up |
Eric&Barb wrote: |
Post images of the engine. |
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Tue Apr 06, 2021 7:10 am Post subject: Re: Stalls once warmed up |
When you took the pics, was the engine cold, warm, hot? I am just noticing the fast idle/choke adjustment is on step 2. _________________ Come on, It's not rocket science. KISS |
Posted: Tue Apr 06, 2021 8:37 am Post subject: Re: Stalls once warmed up |
OK, you do not have the original 36 HP engine. You have a duel port 1600 with Bocar 34PICT-3. Check the idle shut off solenoid is tight and the wiring to it is not failing. Get that wire off the top of the carb, where it will wear thru and short out. That wire should be run below the throttle cable so it is not rubbing against some hard surface.
Do you still have the heat exchangers in place or replaced them with the J-tubes?
Please do post a few more images of the engine a bit farther back to show more of it. _________________ In Stereo, Where Available! |
Posted: Tue Apr 06, 2021 9:28 am Post subject: Re: Stalls once warmed up |
raydog wrote: |
When you took the pics, was the engine cold, warm, hot? I am just noticing the fast idle/choke adjustment is on step 2. |
It was stone cold in this photo. |
Posted: Tue Apr 06, 2021 10:43 am Post subject: Re: Stalls once warmed up |
Eric&Barb wrote: |
Please do post a few more images of the engine a bit farther back to show more of it. |
Thanks, will reroute cable.
Heater exchanges are still there. See additional photos.
type241 Samba Member
Joined: June 02, 2006 Posts: 972 Location: MOSES LAKE, WA
Posted: Tue Apr 06, 2021 12:25 pm Post subject: Re: Stalls once warmed up |
Just my $.02.
Sounds like you are running rich or the choke is staying closed. When your engine warms up it will naturally richen up thus the choke not being needed when warm. You might want to try re-indexing the choke element. |
Posted: Tue Apr 06, 2021 12:44 pm Post subject: Re: Stalls once warmed up |
type241 wrote: |
Just my $.02.
Thanks for your $.02. I'll have a look at that. |
toxicavenger70 Samba Member
Posted: Tue Apr 06, 2021 1:28 pm Post subject: Re: Stalls once warmed up |
It looks like your fuel pump is not hooked up. Are you using an electric one somewhere else? |
leowagen Samba Member
Joined: October 16, 2018 Posts: 171 Location: Argentina
Posted: Tue Apr 06, 2021 3:37 pm Post subject: Re: Stalls once warmed up |
My two cents. I had a similar issue with my 36 hp. Happened to have fuel starvation due a too high glass bowl filter + poorly installed pump diaprhagm + incorrect pump rod length + incorrect carb bowl height.
Sorted one by one, and ended doind flawlessly ever after... runs great even in hot summer. _________________ Frankenwagen: full 1957 pan, under late 60s Brazilian body |
Posted: Tue Apr 06, 2021 4:59 pm Post subject: Re: Stalls once warmed up |
toxicavenger70 wrote: |
Yes, there's an electric one installed--not pictured. |
