ekrossi Samba Member
Joined: March 16, 2008 Posts: 181 Location: outside Jonesborough, TN
Posted: Mon Apr 05, 2021 5:27 am Post subject: Metal brake line to rear wheels |
Anybody got some good advice on how to replace that long metal brake line that runs through the inside of the car? Body on car of course. |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Posted: Mon Apr 05, 2021 7:50 am Post subject: Re: Metal brake line to rear wheels |
I just did this Friday but without the body on the car. With the body on Oy Vey...
Of course you have to pull alot of the interior including your peddle assembly out. I would suggest pulling the old one by bending it in half in the cab to get it out. Then forming the ends of the new one based on the old and installing it the same way. Even with the body off i had to give the middle a bend to get it back in and i had to do some tweaking once installed.
If you were in So. Cal i have a good used one here...
Good Luck. _________________ 1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Wed Apr 07, 2021 6:53 am Post subject: Re: Metal brake line to rear wheels |
If you're using a stock line, straighten it out inside of the car.
I bought 3 short brake lines, that equals the stock length, from the LAPS and some couplings. That way if I 'kink' a line making the bends by the pedal or under the back seat I just have to replace a short piece. Plus, if it should rust again I just have to replace a short piece. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Wed Apr 07, 2021 10:43 am Post subject: Re: Metal brake line to rear wheels |
Get a roll of 3/16” brake line, remove driver seat, back seat bottom, & carpet, & then remove the old line. Unroll about 2’ of the brake line, feed it through the grommets at the Napoleons hat (front pan support next to the master cylinder.). Shove about 1.5’ of that through, then unroll the coil, following the tunnel until you get to the hole in the rear pan support & cut the line about 6” beyond that hole.
Reuse the old flare fitting by sliding it over the line & then flare the line at the rear of the car & then start the flare nut in the union.
Once started, carefully bend, manipulate the line so that it follows the tunnel like the old one including the dogleg to the side of the pedal assembly (make sure that it doesn’t go under the clutch pedal as this can crimp or cut the new line when the pedal is depressed.).
After this is done, in the front fender well, bend the line so that it is pointed at the junction in the master cylinder & then cut the line where it will go into the master cylinder, slide the old fitting onto the line & then flare that end & then install that end into the master cylinder & tighten it up, go to the back & tighten that fitting. Bleed brakes, check for leaks & if good, reassemble interior
How to fabricate your own lines using commonly available 3/16” line & flaring tool from FLAPS.
https://www.thesamba.com/vw/forum/viewtopic.php?t=752443 _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
