Bob's 1959 Single Cab Pickup — "Otto"
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8
bobrk
bobrk is offline
PostPosted: Fri Apr 02, 2021 12:24 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Oh hi.
1959 VW Pickup
1500 single port | 1963 small nut/big brake transaxle | CSP Disc Brakes | dual circuit brake master cylinder | 12V conversion
View user's profile Send private message Visit poster's website Facebook Twitter Instagram Gallery Classifieds Feedback
ach60 Premium Member
ach60 is offline
PostPosted: Thu Apr 08, 2021 12:43 am    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
bobrk wrote:
In my never-ending quest to find the keys to this stupid bus,
The ignition switch isn't original anyway, because I remember you changed it.
Get one of these, and worry about the doors later.
https://www.westcoastmetric.com/search.html?q=ignition+switch&go=Search
Good Luck
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
ach60 is offline
PostPosted: Thu Apr 08, 2021 8:50 am    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
bobrk wrote:
Another interesting mystery is this blue paint under my VW emblem...
It does look like that white paint is flaking off, and you can see the SWR on the outside of the emblem, under the same flaking white paint.
I will have to pull the emblem off to see, and since it's missing a couple of clips anyway, it's probably a good idea.
Done with the lettering City Foreign Car
https://www.facebook.com/photo?fbid=10160705247553362&set=a.10150503602398362
Good Luck
Al
bobrk
bobrk is offline
PostPosted: Thu Apr 08, 2021 11:10 am    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Yeah, I have that picture up here, too...
1959 VW Pickup
bobrk
bobrk is offline
PostPosted: Fri Apr 30, 2021 7:23 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Found my OG door panels and was comparing them to some panels my buddy Al bought years ago.
Trying to decide if I can get these pockets installed on them or if I should just splurge on a new Clara set.
1959 VW Pickup
jeremy57ride
jeremy57ride is offline
PostPosted: Sat May 01, 2021 6:11 am    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Hello- I installed my OG pockets on Clara's panels with pretty good success. Two things to note...
1- The color was harder to match than I thought it would be
2- The OG holes for the rivets are usually too rough to reuse. I moved the rivet holes slightly and redrilled for a fresh start.
"If you don't do it this year, you'll be one year older when you do." -Warren Miller
bobrk
bobrk is offline
PostPosted: Sat May 01, 2021 7:25 am    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Ah, I hadn't even thought about that.
Thanks, those look great! What do you think of the quality of Clara's panels?
1959 VW Pickup
jeremy57ride
PostPosted: Sat May 01, 2021 7:00 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Clara's panel are outstanding, nothing but good things to say. This is my second set, I also used her panels for our westy. well worth it
bobrk
bobrk is offline
PostPosted: Sun May 02, 2021 9:34 am    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Well, I got my windows out yesterday. The rear Philips screws gave me some trouble, but a thorough whacking with an impact screwdriver persuaded them to come out. Several missing bolts on one side that I'll have to replace. Couldn't figure out how to get the windows out after removing those visible bolts and after much struggling, decided to consult my Bentley and found out about the two hidden bolts inside the door. Once I got those off, removal was achievable.
Just noticed the insulation in this Bentley photo. Did the old buses have insulation in the doors?
Now on to the fun jobs of disassembling the frame and replacing all that destroyed rubber.
1959 VW Pickup
bobrk
bobrk is offline
PostPosted: Sun May 02, 2021 3:09 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Got the windows disassembled completely, almost.
Trying to figure out how to get this rock solid door molding out, any ideas?
Looks like there are stops in these grooves, hopefully they're in the WW kit I got...
1959 VW Pickup
PostPosted: Sun May 02, 2021 5:08 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Arggg, been there with seals like that. Fresh razor blade to slice on them while being careful not to cut yourself and basically chiseling them out with little screwdrivers. If you can slice on them a little, it will often release some pressure against the channel and you can slide little pieces out. It's a PITA.
bobrk
bobrk is offline
PostPosted: Mon May 03, 2021 12:50 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Thanks for the advice. Off to get some razor blades.
1959 VW Pickup
peecee69 Premium Member
peecee69 is offline
PostPosted: Mon May 03, 2021 1:01 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
That and heat. I just did this job and it wasn't too bad. Also, take some sandpaper (I used some 1000 grit) in the channels. The ends of that channel are slightly bent in, which you can bend out while putting in the seal. After it's in, bend the ends back down on the seal.
1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight=
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger Facebook Gallery Classifieds Feedback
bobrk
bobrk is offline
PostPosted: Tue May 04, 2021 11:26 am    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Well, the first window took about 2 hours, the second, less than an hour, so I guess I got some mad skills going by the end.
Heat and a utility knife to slice along the side of each track. pick out the middle slice and dig out the two edge slices. Hopefully there will be enough structural integrity to pull them gently out without breaking.
1959 VW Pickup
bobrk
bobrk is offline
PostPosted: Sun May 09, 2021 12:33 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Super glad I got these manuals, they’re saving me from doing stupid things.
Like ruining my window frames…
Or continuing a quixotic search for pick up bumpers…
1959 VW Pickup
Page 8 of 8
