crownline Samba Member
Joined: September 10, 2010 Posts: 592 Location: Northwoods of WI
Posted: Thu Apr 08, 2021 11:36 am Post subject: Re: Buying a Bay Window |
That is a 72. Low lights in front big in back and the bumpers. 1 year only bus like the 68. _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
wagohn Samba Member
Joined: June 24, 2014 Posts: 740 Location: United States
Posted: Thu Apr 08, 2021 11:50 am Post subject: Re: Buying a Bay Window |
crownline wrote: |
That is a 72. Low lights in front big in back and the bumpers. 1 year only bus like the 68. |
If so, it should have the Type IV engine and not the advertised 1600cc - possibly why the shroud is "not installed" - it would be different tinware.
Sure would be nice to see engine bay pics but seller states "No more pics" - I wonder why?
If so (again), run, Forest, run!!!!! _________________ 1976 VW Transporter, 2.0 FI Engine |
Posted: Thu Apr 08, 2021 12:07 pm Post subject: Re: Buying a Bay Window |
Yes it should have the type 4 1.7 engine. If it was a 1600 swapped in if it did not have correct tin installed it's probably fried. When someone doesn't have basic engine or under carriage pictures they are hiding something. I would move on. _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
theguyryry Samba Member
Joined: March 31, 2021 Posts: 100 Location: Portland, OR
Posted: Thu Apr 08, 2021 12:11 pm Post subject: Re: Buying a Bay Window |
crownline wrote: |
Yes it should have the type 4 1.7 engine. If it was a 1600 swapped in if it did not have correct tin installed it's probably fried. When someone doesn't have basic engine or under carriage pictures they are hiding something. I would move on. |
Without even taking a look at it? That seems awfully pessimistic... What if I get there and it's a beautiful, fresh motor and the guy just didn't want to bend over or something. |
Brian Samba Moderator
Posted: Thu Apr 08, 2021 12:15 pm Post subject: Re: Buying a Bay Window |
I'd say hard pass and stick with trying to find a real '71. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
HoboBus Samba Member
Joined: December 29, 2016 Posts: 347 Location: Massachusetts
Posted: Thu Apr 08, 2021 12:17 pm Post subject: Re: Buying a Bay Window |
No harm in looking at it, but there's lots to check.
I'd check every VIN location, make sure they all match. If he's convinced its a 71, something seems weird.
Check for loads of Bondo.
Check the motor. Missing "shroud" could mean he put an upright 1600 in it without the proper tin. Proper tin for that swap is expensive.
Or it could really be a 72 with swapped VINs and the motor is really a 1700 and he doesnt know the differernce, and the fan shroud isn't mounted......
Either way, lots to check, and Be Careful. _________________ Salt air it ain't thin, it'll stick right to your skin,
it'll make you feel fine. Makes you feel fine.
And I wanna be there. -- Jimmy Buffett
Just a beach-oriented camping Hobo with a bus. |
Posted: Thu Apr 08, 2021 12:20 pm Post subject: Re: Buying a Bay Window |
The reason he can't bend over is the passenger side front turn signal lens is stuck up his butt. _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
wagohn Samba Member
Posted: Thu Apr 08, 2021 12:27 pm Post subject: Re: Buying a Bay Window |
HoboBus wrote: |
Either way, lots to check, and Be Careful. |
I think the 71 claim is to add support for the 71 type engine that's now installed. Those tail-lights are a legitimacy giveaway because I haven't come across a 71 with those type of lights. Something is off.
My 2c is it was a Type 4 motor that was blown and a 1600cc motor replaced it, due to the higher cost/low availability of the Type 4 motors. The lack of tinware/pictures supports this theory.
That's not a $15k bus IMHO. _________________ 1976 VW Transporter, 2.0 FI Engine |
Posted: Thu Apr 08, 2021 1:51 pm Post subject: Re: Buying a Bay Window |
Been doing some research... There's no way that's a '71... I think he got his numbers mixed up. I'll check the VIN when I get there, hopefully snap some pictures. It should say on the title, right? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51124 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Apr 08, 2021 1:54 pm Post subject: Re: Buying a Bay Window |
It's a 72, nut likely late 71 production date, the roof looks like it's got a 74+ one on the front with no seals or hinges and still has the early luggage rack on the back, maybe with the rear cut off the later roof?
I'd be very wary of that one, lots of hacks and who knows what's hiding under the paint. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 08, 2021 1:55 pm Post subject: Re: Buying a Bay Window |
wagohn wrote: |
HoboBus wrote: |
That's not a $15k bus IMHO. |
If you had to put a price on it? |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Thu Apr 08, 2021 2:05 pm Post subject: Re: Buying a Bay Window |
If the guy does not even know what year Bus he is selling, what else doesn't he know ??? Maybe he bought it as you see it, found out he got screwed & is just passing it on to another unsuspecting buyer...
As others have said: pretty paint, bogus interior, and the "No more pictures" Bullshit, I'd pass. _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
Posted: Thu Apr 08, 2021 2:07 pm Post subject: Re: Buying a Bay Window |
crukab wrote: |
As others have said: pretty paint, bogus interior, and the "No more pictures" Bullshit, I'd pass. |
Yeah, I'm quickly joining the club. I'm about to go drive to check it out, don't really have any intention of buying though. I figure it's good to check out as many as I can. |
Posted: Thu Apr 08, 2021 2:17 pm Post subject: Re: Buying a Bay Window |
theguyryry wrote: |
Absolutely.
And, its good to learn all the detail points that have been brought up here, so you're as smart of a buyer as you can be.
So when someone says "Yeah, you just need a shroud thing. Probably can get one at a junkyard cheap", you'll know the real situation.
You dont want a hodgepodge mess of a bus with maybe even some VIN issues, with shiny paint.
Good luck! _________________ Salt air it ain't thin, it'll stick right to your skin,
wagohn Samba Member
Posted: Thu Apr 08, 2021 3:25 pm Post subject: Re: Buying a Bay Window |
theguyryry wrote: |
If the general consensus is correct, and its a 72 bus with a 71 engine, Id keep looking. If I had to buy it I'd be at around $7k for it and that's mainly for the paint/body (assuming its not bondo underneath).
Getting the correct engine/trans/roof is pretty big $ and would take some time and wrenching skills.
With a $15k budget you should be able to get a sweet bus. Maybe rough around the edges in places, but the purchased originality and trust in the seller is priceless. This one smells fishy to me. _________________ 1976 VW Transporter, 2.0 FI Engine |
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1178 Location: Vancouver, BC
Magion Samba Member
Joined: February 15, 2016 Posts: 236 Location: Vancouver, BC
Posted: Thu Apr 08, 2021 3:49 pm Post subject: Re: Buying a Bay Window |
Something stinks with the first one. Suspiciously cheap. Also two different busses in the pics
*edit
I can see now, those are not of the actual bus. who knows what it actually looks like
Also you must be joking with saying the second one is decent!
Did you miss the ton of rust hiding in and the sliding door with missing corner? _________________ 1975 Westfalia in Brilliant Orange
1995 Westfalia in Caribbean Green |
danfromsyr Samba Member
Posted: Thu Apr 08, 2021 3:56 pm Post subject: Re: Buying a Bay Window |
new paint means bondo.. sorry but that's the facts otherwise there'd be too much $$ invested to be $15k.
not really too much an issue, that's where that price point will get you if you want shiny.. it's either hazed faded OE paint or shiny bondo covered paint for $15k.
it's ok just don't leave it in the elements, or else the bondo will cause some paint failures within 3-4yrs of rain, wet, damp air.
keep it in a garage when not in use and it'll go ~10+yrs w/o needing extra attention.
theguyryry wrote: |
Ok, so checking my nearby craigslist last night and this one pops up:
https://panamacity.craigslist.org/cto/d/lynn-haven-1971-volkswagen-van-westfalia/7303285551.html
I spoke to the owner on the phone, he's said he's gotten a lot of interest on it but no buyers yet... I'm going to go check it out tonight, but over the phone he mentioned the fan shroud isn't installed on the motor, so he doesn't recommend driving it long distances until that's installed. I figured I'd ask the hive mind for recommendations.
Without even looking at it in person, I can see that it needs the front turn signal housing replaced. That potentially means electrical isn't hooked up. The paint looks good / new, but that could be hiding rust. 15k doesn't seem to bad, does it? |
Abscate wrote: |
Posted: Thu Apr 08, 2021 4:10 pm Post subject: Re: Buying a Bay Window |
Magion wrote: |
*edit
Did you miss the ton of rust hiding in and the sliding door with missing corner? |
What a joke!
delusional seller wrote: |
**Note, the pictures here are not the actual van. These are pics of what it looks like. But it needs work. |
If the door fell off odds are good the whole bottom 6-8" are missing all the way around, maybe a good parts donor, but I'll bet it's a project that will bury you if you want it to be nice and solid after.
The second one says "frame is solid", that translates into "it's the only part left", same missing bottom 1/4 of the body is my guess, don't slam the door too hard or jump the railroad tracks, it'll buckle in 1/2. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 08, 2021 5:36 pm Post subject: Re: Buying a Bay Window |
busdaddy wrote: |
Magion wrote: |
*edit
What a joke!
The second one says "frame is solid", that translates into "it's the only part left", same missing bottom 1/4 of the body is my guess, don't slam the door too hard or jump the railroad tracks, it'll buckle in 1/2. |
Yep, these are the typical ads you get and have to sift through. A lot of unknowns until you see them in person and crawl underneath and find out for yourself, and make an appropriate offer after pointing out the discrepancies. |
