FritzCP Samba Member
Joined: October 23, 2005 Posts: 463 Location: Wisconsin
Posted: Fri Oct 02, 2020 10:42 am Post subject: Re: 1961 Oldspeed inspired Beetle. |
id buy a couple of those! nice work _________________ Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller |
SteveW Samba Member
Joined: February 21, 2004 Posts: 176 Location: Nottinghamshire, UK
Posted: Fri Apr 09, 2021 1:15 pm Post subject: Re: 1961 Oldspeed inspired Beetle. |
I thought i'd update this post a little, not much has changed recently as I have been working on my 1969 Westfalia.
I had some replica Theo Decker decals designed as they are no longer available, they would have been original installed on the fan shroud but I had two sizes made up so they could be used elsewhere. I also picked up an NOS Bosch blue coil.
With lockdown happening in the U.K I haven't really been able to drive it much but when I have, it's been great fun. During the summer it was a great honour to have the car photographed from Volksworld Magazine, the issue came out in April so it might be appearing stateside soon
I have a few things still left to do which i'm hoping to finish off soon, hopefully in time for some VW events! _________________ Steve
1951 Type 1 11c - Chestnut Brown
1995 T3 - South African RHD Microbus / 2.6i |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76706 Location: Sneaking up behind you
Posted: Fri Apr 09, 2021 1:19 pm Post subject: Re: 1961 Oldspeed inspired Beetle. |
You need to reindex the distributor drive so the BOSCH nameplate is facing the rear.
It's all about the details. _________________ Glenn
Member #1009
#BlueSquare |
SteveW Samba Member
Posted: Fri Apr 09, 2021 1:23 pm Post subject: Re: 1961 Oldspeed inspired Beetle. |
I know, I see that everytime. I'm not confident to do it on my own yet and as we have been in lockdown (and the car stored away for winter) I haven't been able to do it. It's high on my list of things to do though! _________________ Steve
Glenn Mr. 010
Posted: Fri Apr 09, 2021 1:29 pm Post subject: Re: 1961 Oldspeed inspired Beetle. |
SteveW wrote: |
I know, I see that everytime. I'm not confident to do it on my own yet and as we have been in lockdown (and the car stored away for winter) I haven't been able to do it. It's high on my list of things to do though! |
Don't lose any sleep over it... summer is coming and you'll get to it.
I like the logos on the intake manifolds.
Might want to look for a cloth covered fuel hose. Flennor hose that is E85 safe and looks correct and made in Germany.
I use it on my old school 2180.
Member #1009
#BlueSquare |
SteveW Samba Member
Posted: Fri Apr 09, 2021 2:05 pm Post subject: Re: 1961 Oldspeed inspired Beetle. |
Glenn wrote: |
SteveW wrote: |
That’s cool! Cheers! I have been looking into cloth fuel line, I’d bought new fittings and was planning on using Cohline cloth covered hose until I read more detail about it, it doesn’t cope well with the ethanol in our fuel! _________________ Steve
Glenn Mr. 010
Posted: Fri Apr 09, 2021 7:17 pm Post subject: Re: 1961 Oldspeed inspired Beetle. |
SteveW wrote: |
That’s cool! Cheers! I have been looking into cloth fuel line, I’d bought new fittings and was planning on using Cohline cloth covered hose until I read more detail about it, it doesn’t cope well with the ethanol in our fuel! |
Flennor
"6.0mm Flennor Multi-Fuel hose. ID 6.0mm, OD 11.0mm
Hoses are cut off a continuous spool. Charged per meter.
Roll length (longest continuous cut) is 15 meters.
Approved for gasoline, diesel fuel, water, air,heating oil and withstands higher levels of Ethanol up to E85
That means this hose can handle up to 85% ethanol in gasoline. Working temperature, -25 to 250 Degrees Fahrenheit
Working pressure 150 PSI, DIN 73379
The hose complies with the requirements of the standards SAE J30R7, ISO 4639-2" _________________ Glenn
Member #1009
#BlueSquare |
SteveW Samba Member
Posted: Wed Jun 02, 2021 6:48 am Post subject: Re: 1961 Oldspeed inspired Beetle. |
I have been searching for and collecting original KPZ 356 wheels for the car, I picked up two more yesterday to make a set of four. One is dated 1/57, two are 7/61 and the last one is 8/61. Hopefully I’ll find another 8/61 to have matching pairs.
Braukuche Samba Member
Posted: Sat Jun 05, 2021 7:13 am Post subject: Re: 1961 Oldspeed inspired Beetle. |
SteveW wrote: |
Good luck getting them balanced. A lot of Porsche guys send them out and have the outer rim removed and new ones welded on and then balanced. They are worse than split bus wheels or beetle wide fives. They just get beat to hell over the years. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1973 Ghia convertible |
5500 Samba Member
Joined: October 16, 2020 Posts: 112 Location: Cape Cod
Posted: Sat Jun 05, 2021 7:23 am Post subject: Re: 1961 Oldspeed inspired Beetle. |
Braukuche wrote: |
SteveW wrote: |
Good luck getting them balanced. A lot of Porsche guys send them out and have the outer rim removed and new ones welded on and then balanced. They are worse than split bus wheels or beetle wide fives. They just get beat to hell over the years. |
Balancing beads (liquid wheel balancing fluid), commonly used for motorcycle wheels, will work if you're having a hard time with static weights. |
MAW65 Samba Member
Joined: September 18, 2011 Posts: 23 Location: Caracas, Venezuela
Posted: Sun Jun 27, 2021 4:04 pm Post subject: Re: 1961 Oldspeed inspired Beetle. |
SteveW wrote: |
homemade 20mm 'Carrera' spacers on the rear
Hi first of all congrats on your car very nice detailed and clean
I just want to know if those home made spacers are one solid piece like the aftermarket ones or five independent cylinders
I am toying with the idea of a similar stand of yours using a set of mocked up '66 wheels drilling holes beside to the lugs, add caps clips and maybe some file work on the slots to mimic the 356's |
SteveW Samba Member
Posted: Thu Jul 01, 2021 8:52 am Post subject: Re: 1961 Oldspeed inspired Beetle. |
MAW65 wrote: |
SteveW wrote: |
Thanks 🙂 The spacers are separate cylinder spacers, 20mm deep and with a hole drilled through the middle instead of being threaded as the original carrera spacers would have been. _________________ Steve
MAW65 Samba Member
Posted: Thu Jul 01, 2021 12:10 pm Post subject: Re: 1961 Oldspeed inspired Beetle. |
Thanks SteveW
A very helpful information indeed I will take the same route of you when I order mines |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Tue Nov 02, 2021 7:53 am Post subject: Re: 1961 Oldspeed inspired Beetle. |
Beautiful car, the more I look at it the more neat things I see...Beautiful. |
SteveW Samba Member
Posted: Wed Nov 03, 2021 11:42 am Post subject: Re: 1961 Oldspeed inspired Beetle. |
Thanks Bill 😊
Not much of an update but I recently restored the KPZ 356 wheels and I’m very happy with the result. I had the rims media blasted and then I painted them myself, I took the rims to a classic tyre specialist who installed new inner tubes with my existing Vredestein tyres and balanced them up with no problems.
MAW65 Samba Member
Posted: Fri Nov 05, 2021 8:36 pm Post subject: Re: 1961 Oldspeed inspired Beetle. |
They look even better than before good job congratulations |
2ndGenVW Samba Member
Joined: January 28, 2022 Posts: 1 Location: East Bay, CA
Posted: Sun Jul 10, 2022 3:10 pm Post subject: Re: 1961 Oldspeed inspired Beetle. |
Late to the party on this thread, but I love your old speed Beetle! I am looking to get back in to a vintage Beetle after a 30+ year break. Ha ha!
The old speed look is what I want to create as well. Would love to see more pics of your build!
Thanks!
Rob |
jaket3 Samba Member
Posted: Mon Dec 04, 2023 2:49 pm Post subject: Re: 1961 Oldspeed inspired Beetle. |
Glenn wrote: |
It's all about the details. |
Unless I'm mistaken can't he just rotate the distributor without reindexing the drive. Then just move the wires round. Since there is no vaccum can to get in the way and I don't think the 010 has a different timing for number 3 either.
Can't he just do that? |
jaket3 Samba Member
Posted: Mon Dec 04, 2023 2:53 pm Post subject: Re: 1961 Oldspeed inspired Beetle. |
Lovely beetle by the way. Looks great.
I have a Ruby Red 65 that is getting a similar treatment. I'll post some photos when I get a chance.
If you have any spare Theo Decker stickers I'd love one! Mine has Theo Decker tailpipes which sound great.
Maybe see you at a show, I'm just up the road in Leeds. Cheers. |
