1979 Federal Bus Exhaust
jhicken
jhicken is offline
PostPosted: Fri Apr 09, 2021 1:43 pm    Post subject: 1979 Federal Bus Exhaust Reply with quote
OK guys, I know I've asked a few questions about this before but now I'm motivated to get this straightened out. I have a '79 Federal bus from New Jersey. I'm now in north San Diego. When I restored the bus I picked up the heater boxes and muffler designed for a '74 [perfect for NJ and the old header was rotted]. As you know, California is different. Can I source a '79 Federal exhaust and get it to pass? Or do I need to find an original CA version. My next question. I have no idea what I'm looking for so does anyone have any pics or diagram of what I need to find? My current set-up was easy, Just like a type 1, basically a couple of heater boxes and the muffler. From what I can tell, this has these random pipes and cross overs and a lot of crap I'm not really sure about. I've see pics where the cat is mounted just before the muffler, and I've seen a few pics where it's underneath by the heater box. Also, if I'm able to find a CA version, is that going to be an issue on a federal car? I found a guy in the bay area that has some of the parts but not all. Like I said before, I'm not sure what I'm looking for so any help would be appreciated.
Der Kleiner Kampfwagens
airschooled
Air-Schooled
airschooled is offline
PostPosted: Fri Apr 09, 2021 2:10 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
Driver door jam dotted sticker is #1. If no dotted sticker, yellow compartment sticker.
If "non-catalyst," then you can use any damn exhaust you like, as long as the sniffer is pleased, and the functional tests and inspections all pass.
If "Catalyst"," you'll have to have a cat with a CA-legal EO number. There is no written law, statute, or regulation that I know of that documents our exhaust setups. Have the correct cat number, all functional parts accounted for, and please the computer.
Honestly, it's really hard to pass the NoX without a functional EGR system, but it is possible. That's going to be your big search/budget item on a federal bus. (On a CA/Cat bus, you can richen the mix to lower NoX and allow the cat to scrub the rest of the gasses.) Your '74 muffler should have an EGR takeoff.
Here is the Motor brand manual that most shops in SD county use:
There are a couple errors, notably in the '79 CA line, but the federal line looks correct.
Good luck,
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
jhicken
jhicken is offline
PostPosted: Fri Apr 09, 2021 3:08 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
I should have mentioned that, it does say "Catalyst"
Airschooled, I sent you an email regarding my situation yesterday. I was considering coming to you to help me get this all in order [I'm in Fallbrook]. I called Jim at Interstate and he's checking to see what he has. The guy up north has the parts below, what else do I need? Is this a CA '79 system or a Federal '79 system?
Thanks for you help.
airschooled
Air-Schooled
PostPosted: Fri Apr 09, 2021 3:16 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
Ha! I have a few dozen more emails to get to before the weekend....
If the sticker says catalyst, it was a CA-spec bus, that’s it. Lots of them were delivered outside of CA.
Where are the right side header pipes?
There are legal issues around buying/selling/installing a used catalytic converter, but it’s an unenforceable law. I would prefer a new cat anyway though, they make passing fairly straightforward. All buses, CA/Fed, auto/manual, are all tested on the same tailpipe average.
Robbie
www.airschooled.com
jhicken
jhicken is offline
PostPosted: Fri Apr 09, 2021 3:39 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
He says he's missing the passenger side heater box/j pipe/catalytic. Isn't that a cat pictured? He wants $250 for what is showing above. Is that worth it? I see I can get a new muffler and a cat, can I reuse the heater boxes I have?
What else is it missing? Do you have any sources for what I need? My plan is to get everything I need, clean it up and have it ceramic coated. I want this the best that it can be. It's on my wife's bus so I don't want to cut any corners.
Wildthings
Wildthings is offline
PostPosted: Fri Apr 09, 2021 4:28 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
If you have actual 72-74 heat exchangers then swapping to '79 heat exchangers is not straight forward. You may either need to do some custom work to the exhaust ports in the heads or install the correct '79 heads.
You need to know what was done to make the 72-74 exhaust work on a '79 engine in the first place and undo it somehow.
jhicken
jhicken is offline
PostPosted: Fri Apr 09, 2021 5:44 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
These are the new ones sold by Dansk, They are square port manifolds.
JaimeH Premium Member
JaimeH is offline
PostPosted: Sat Apr 10, 2021 6:01 am    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
'79 Federal would have had a CAT. The system was different than CA though.
It would have looked like this. The crossover pipe will work with 72-74 heat exchangers as well as the '79 only square port.
1978 Transporter 2.0 FI, BA6
Special Thanks to Razor's Customs, Boscawen, NH
airschooled
Air-Schooled
PostPosted: Sat Apr 10, 2021 7:23 am    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
Our answers depend on your cylinder head ports. What do you have?
The smog shop does not care what pipe setup you have, as long as the cat is present and CA legal. (Half the shops out there don’t even check the number, though they’re supposed to.)
Note that the 72-74 flanges and 79 federal flanges are the same but they have a different placement on the car. 79 federal exchanger flanges are about 1/2” forward from the early flanges. Running a 72-74 exhaust on late flanges requires a spacer for each flange, or removal of the bus oil fill tube in lieu of a 914 tube.
Robbie
www.airschooled.com
JaimeH is offline
PostPosted: Sat Apr 10, 2021 1:13 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
Robbie
Robbie, Does this mean when I install the '79 set-up pictured above on my 72-74 exhangers everything will be 1/2" rearward of it's intended location?
Wildthings
PostPosted: Sat Apr 10, 2021 1:45 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
JimmieH wrote:
Robbie
The bolt patterns may be the same but the flanges aren't compatible without modification being made that are more than most are going to be up to doing.
airschooled
Air-Schooled
PostPosted: Sat Apr 10, 2021 2:19 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
JimmieH wrote:
Robbie
I believe so, but I’m not 100%. Last year I installed a 72-74 muffler on a square port engine with ‘79 federal heat exchangers, and it was 1/2” too close to the engine. German Supply sells a spacer kit for my situation, but I don’t know the ramifications of your reversed situation.
Do you actually have 79 federal heat exchangers, or 72-74 exchangers?
www.airschooled.com
JaimeH is offline
PostPosted: Sat Apr 10, 2021 3:01 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
[quote="airschooled"]
JimmieH wrote:
Robbie
Robbie, Does this mean when I install the '79 set-up pictured above everything will be 1/2” rearward of it’s intended location?
I’m not the OP. Yes I have 72-74 exchangers on ‘78 with oval ports.
I intend to install the ‘79 crossover & CAT.
jhicken
jhicken is offline
PostPosted: Sat Apr 10, 2021 3:09 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
So, I'm still learning here. I believe the image above is the '79 CA set-up. I believe it's missing the exhaust manifold and cat. Am I correct? What else is it missing? The EGR filter? Where does it go?
JaimeH is offline
PostPosted: Sat Apr 10, 2021 3:24 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
‘79 CA didn’t have EGR. Do you have an EGR valve or the remnants of one? You started with ‘79 Federal correct?
jhicken
jhicken is offline
PostPosted: Sat Apr 10, 2021 3:26 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
FWIW, this is the set-up I'm currently running. The heater boxes fit '79 square port heads and the muffler is '72-'74. It's all available new, so that was the way I went.
jhicken
jhicken is offline
PostPosted: Sat Apr 10, 2021 3:28 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
It is originally a New Jersey bus but the sticker says Catalyst. It didn't have anything original. It had a rusty new jersey home made header on it.
jhicken
jhicken is offline
PostPosted: Sat Apr 10, 2021 3:31 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
I'm just trying to figure out what I need. CA or Federal. I have the opportunity to get the stuff above [in the weeds] which I believe is the '79 CA version, and I have a local wrecking yard looking to see what they have. The pic I posted above was an image I pulled off another Samba thread. I drew in the other missing pieces. I'm want to know what else I may need.
JaimeH is offline
PostPosted: Sat Apr 10, 2021 3:49 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
Post a picture of your yellow emission sticker. If you have a ‘79 Federal it will likely say CAT & EGR. If so the ‘79 CA set up your looking at will not have provisions for the EGR.
airschooled
Air-Schooled
PostPosted: Sun Apr 11, 2021 12:00 pm    Post subject: Re: 1979 Federal Bus Exhaust Reply with quote
The stickers say what you should have, regardless of what we call it. The pipe arrangement does not matter, as long as the cat EO number is legal, or if the cat is original to the car. I would advise against using the '79 CA pipe setup, because you can buy more new parts for the other setups, so you won't be SOL when something on the special 79 CA setup rusts out.
Robbie
www.airschooled.com
