Kreelak Samba Member
Joined: September 19, 2011 Posts: 122 Location: Ridgefield Washington
Posted: Tue Feb 02, 2021 8:44 am Post subject: My New Manx 2 build |
finally I'm back at it a lot of life has gone by and I'm getting started again I changed my plans on wheels I'm going away from the wide 5 and now have a new set of torque thrusts and I will be using my old body for mock up only I just call and put a down on a new candy apple red classic Manx body I hope to pick up spring break
Posted: Tue Feb 02, 2021 12:13 pm Post subject: Manx 2 build Classic Manx |
question for you guys I'm planning on using this thing for mostly street use some very light off road if I go in the sand it will just be from point a to b nothing crazy and logging roads here in the north west
I was wanting to run a set of 2 dropped spindles I have a link pin front end and still have the factory bump stops on the beam, i have adjusters installed in the beam if I lower it with stock spindles ill be bouncing off the bump stops ?
I'm trying to get the best ride out of the front end and I don't want to be completely stuck on the street
thanks for any input |
sailtexas186548 Samba Member
Joined: December 01, 2014 Posts: 423 Location: Kemah, Tx
Posted: Thu Feb 04, 2021 4:52 pm Post subject: Re: My New Manx 2 build |
Cool build, where are you mounting the radiator? _________________ it's more fun loud and dirty |
Posted: Thu Feb 04, 2021 5:47 pm Post subject: Re: My New Manx 2 build |
I plan on installing it up in the front angled at about 30゚ under my fuel tank so it blows down through the tube chassis but that could change till
Posted: Thu Feb 04, 2021 7:02 pm Post subject: Re: My New Manx 2 build |
Interesting, don’t think I’ve come across that concept yet and I have been searching. I like it, do you think it will clear the steering? Or are you going with a rack? _________________ it's more fun loud and dirty |
Posted: Thu Feb 04, 2021 7:08 pm Post subject: Re: My New Manx 2 build |
I'm using a rack and pinion
It will be above the lower part of the radiator.i will building a custom fuel tank to give the proper gap so it will create a high pressure area and the cooling fans will be underneath to draw though |
Posted: Sun Feb 07, 2021 11:33 am Post subject: Re: My New Manx 2 build |
I really need your guys input and advice I have installed torsion adjusters in my link pin front end and I still have my factory bump stops, I'm torn should I use my stock spindles or get dropped spindles
I would like a decent ride and don't want to stuff tires into my front fenders |
Posted: Sun Feb 07, 2021 12:59 pm Post subject: Re: My New Manx 2 build |
I am not familiar with link pin stuff, but if you lower with adjusters and leave the rest stock you shouldn’t hit the fenders, with drop spindles you might. You can cycle the suspension without the torsion packs in and see _________________ it's more fun loud and dirty |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Feb 07, 2021 1:01 pm Post subject: Re: My New Manx 2 build |
I was just talking to a guy last weekend that put drop spindles on his 67 bug.......said it drove like Sh*t!!!!!
Took them off and put adjusters in the beam instead.
YMMV _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Mon Feb 08, 2021 9:20 am Post subject: Re: My New Manx 2 build |
sailtexas186548 wrote: |
I am not familiar with link pin stuff, but if you lower with adjusters and leave the rest stock you shouldn’t hit the fenders, with drop spindles you might. You can cycle the suspension without the torsion packs in and see |
thanks haven't had a lot of experience with Vw front ends, i just cleaned up my stock spindles and are ready to install
clonebug wrote: |
YMMV |
I have the adjusters installed already installed, I need it to drive as good as possible that way my wife will enjoy it also |
Posted: Sat Apr 10, 2021 8:02 pm Post subject: Re: My New Manx 2 build (updated) Classic Manx Build |
drove down to Meyers Manx with the trailer in the car
and assembled it in the home depot parking lot
my new classic apple red metallic Manx
and were home
Manx102 Samba Member
Joined: June 07, 2010 Posts: 484 Location: California
Posted: Sat Apr 10, 2021 9:33 pm Post subject: Re: My New Manx 2 build |
I like your trailer build and looking forward to seeing your Manx when it is done. _________________ "The simplest of outdoor adventures - the most treasured memories." - Bruce Meyers
54 years of "outdoor adventures" and "treasured memories" with our Manx in my gallery. |
Posted: Fri Apr 16, 2021 8:47 am Post subject: Re: My New Manx 2 build / Manx Classic |
tried the new cover on the old body and the 2000 Subaru starter sat to high and to far to the right
I got a later model Subaru starter and its more compact
And after that started prepping and cut the whole in the new body
I also found out the new classic body isn't a exact fit to the Manx 2 over time I'm guessing the Manx 2 shrank, the rear of the body is wider on the classic so I'm going to have to widen the of my frame and the parcel tray floor in the classic is also higher then the floor in the Manx 2 so that has given me a little more clearance
you can see at the rear of the car the tube behind the tire the Manx 2 body used to sit on it and the classic does not
jakerot Samba Member
Posted: Mon Apr 19, 2021 10:15 pm Post subject: Re: My New Manx 2 build |
very nice.
sweet looking buggy for sure. |
Manx Lee Samba Member
Posted: Thu Aug 18, 2022 11:23 am Post subject: Re: My New Manx 2 build |
Man this is cool !! |
