atomicmime Samba Member
Joined: March 30, 2004 Posts: 81 Location: Livermore, CA
Posted: Sat Apr 10, 2021 10:15 pm Post subject: Stock cylinder heads look okay? See any problems? |
I've got a pair of heads that came as extra parts with another project, and I want to be sure they are in good shape and without any issues before I post them here in the ads on Samba. I examined very carefully after just a little cleaning, and I see no cracks or other problems, but I'm far from being an expert diagnostician. Stock German dual port heads, right?
113 101 375 A is for a Type 1; 311 101 375 is Type 3, but they can be used as a pair according to threads I read here in the forums.
Any issues you can see? Thanks very much for your help and responses!
_________________ ---------------------------------
--Patrick--
'69 Meyers Manx (still a project, but not for long!)
'72 Westy
'79 Super Beetle (now electric!)
'13 Beetle |
dunk Samba Member
Posted: Sun Apr 11, 2021 2:09 am Post subject: Re: Stock cylinder heads look okay? See any problems? |
they look a bit.... hemi cut to me... |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Sun Apr 11, 2021 2:32 am Post subject: Re: Stock cylinder heads look okay? See any problems? |
Ya I also think they look hemi cut. Maybe good for turbo use?
Measure the CC volume, might make them easier to sell
Can't see any damage, but then again most damage will not be detectable from a photo. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
Posted: Sun Apr 11, 2021 10:04 am Post subject: Re: Stock cylinder heads look okay? See any problems? |
Thanks so much for the responses! Is there an easy way to check the cc volume? If hemi cut heads are used with stock barrels, would it mean just a slight increase in displacement size? _________________ ---------------------------------
--Patrick--
'72 Westy
'13 Beetle |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Sun Apr 11, 2021 11:32 am Post subject: Re: Stock cylinder heads look okay? See any problems? |
Check the plug threads
And check the valve guides for ware |
