Jason37 Samba Member
Posted: Sat Apr 10, 2021 3:52 pm Post subject: Re: My 1964 Birch Green Canadian Squareback |
Did you replace the input shaft seal as well?
The reason I ask is I would have oil in the bell housing, but nothing on the clutch or pressure plate. Pulled the input shaft seal and found the shaft was badly corroded. I replaced it with a shaft from Weddle. |
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1389 Location: Newfoundland
Posted: Sun Apr 11, 2021 8:13 am Post subject: Re: My 1964 Birch Green Canadian Squareback |
Jason37 wrote: |
I replaced that seal when I worked on the transmission a few years back. The oil in the bell housing was engine oil, not gear oil, so it’s not coming from there. Also the pressure plate was dry of oil, just had that reddish dust all over it from (I assume) the throw out bearing. _________________ Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807 |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Sun Apr 11, 2021 10:51 am Post subject: Re: My 1964 Birch Green Canadian Squareback |
I noticed a difference in pressure plates when I went from the 3 arm version to the diaphragm version. The latter is much smoother and I have less chatter if I screw up. |
Posted: Mon Sep 20, 2021 8:52 pm Post subject: Re: My 1964 Birch Green Canadian Squareback |
Just a couple shots from our annual Euro car show, nice that it was back this year after being curtailed last year.
And a little late summer run the other day.
Transmission is still acting up, lots of grinding noise and still terrible shifting. I think it’s the bearing in the main shaft failing now. I have another transmission from a 69 Ghia that I’ll be trying this fall… third time’s a charm right? _________________ Air does not freeze. Air does not boil.
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4887 Location: Southern AB
Posted: Thu Apr 13, 2023 1:15 pm Post subject: Re: My 1964 Birch Green Canadian Squareback |
About time for another update, it’s been a while… Transmission was still the ongoing issue, with a loud roaring main bearing and terrible shifting, so in January I pulled it in the garage and decided to install another one. Third time’s a charm right?
This unit came out of a ‘68 Ghia, and was known to be in decent shape before it was removed in favour of a freeway flyer. Cleaned it up, adjusted the shims on the swing axles to get them moving freely, as they were so tight I couldn’t get them to move by hand. Also put in new large O ring seals, which I surprisingly had a hard time finding from the usual VW parts sources. I ended up buying a pack of 25 from Fastenal for $20 or so. I also replaced the axle boots – this time with the split ones.
I also had to replace the starter bushing, as this is a 12V trans going in a 6V car. Very thin bushing this, so I had to be careful tapping it in.
With that I put the car up on my handy dandy QuickJacks, hauled out the engine and transmission. The 500 pound lift cart I bought a while ago made the job a lot easier.
Interestingly enough the boot area on the transmission that I installed a few years back always seemed to dripping gear oil, I thought the leak was from the side plate, but discovered that both solid boots I had installed were cracked on the bottom. They were supposed to be the good German ones too.
In with the “new”.
Had some issues with the bearings. Went down the whole 68-only long axle rabbit hole - basically if you have a 68 transmission, you need 68 bearing caps, as the recess for the bearing in the axle tube is deeper (13mm vs 10mm) than prior swing axles and the therefore the bearing cap is more shallow. Found this awesome pictorial on here showing the difference- what a great thing the Samba is!
I did have them installed, but there seemed to be a gap so I decided to pull the bearing and measure the depth of the recess in the tube. I made a bearing puller using IRS Allen head bolts and a three inch washer. Worked a treat.
In the end, it was simply that I hadn’t seated the bearing all the way. Interesting that the Type 3 transmission used long axles before anything else, so the old transmission axles and tubes (out of a 63 Squareback) were actually the same length as the 68. That sorted, I buttoned it all up and installed the engine.
As for the hard shifting - I know that I had the T-1 hockey stick in the old tranny, not the proper T-3 with the single indent, even though it was from a ‘63 Type 3. Dad had used it in his Ghia, so I assume he changed the hockey stick. Looking at it, it was actually bent on the end, so I’m sure none of that helped.
The new trans also has a Type 1 hockey stick (being from a 68 Ghia), so I drilled an offset hole in the backside of the coupler to bring it around in the right spot. Problem is my shift rod has also been welded and I think was modified to mate to the backside hole on the Type 1 stick. Another large issue I also discovered was that with just a little force the whole collar with the lock bolt in it on the coupler actually turns. I replaced the coupler with another one and lined up the gear shifter socket in the car visually so that there is equal movement left and right, then tightened and wired the lock bolt. We’ll see if that sorts it.
So now, it’s just a matter of waiting for the weather to come around, and the snow/ice and salt to disappear so I can get her back out of the garage.
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4158 Location: Pasadena CA/DTLA soon China
Posted: Thu Apr 13, 2023 5:21 pm Post subject: Re: My 1964 Birch Green Canadian Squareback |
Awesome work Mr Norman _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22328 Location: Kimball, Mi
Posted: Fri Apr 14, 2023 11:07 am Post subject: Re: My 1964 Birch Green Canadian Squareback |
bobnorman wrote: |
an ones too. |
Just watch what the material you use for that conversion bushing for the starter. I only say that as my son picked one up for his car, and the bushing wore out in 1 year. I took it to a friend on mine and we opened it up and lightly pressed (w/green loctite) in a 12 volt bronze bushing into the brass one. It's been years now since that was done. Just a heads up on that bushing. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
