Official "What oil / additives should I use" topic
Page: Previous  1, 2, 3 ... 229, 230, 231 ... 233, 234, 235  Next
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Sat Jan 23, 2021 10:34 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Several years ago I was an oil distributor and this publication I really liked. It’s still around little pricey or free if you are in business. Some of it you can get right off the website. It covers worldwide business so you’ll see trends and products before they hit the US market. Highly recommend.
https://www.lubesngreases.com/magazine/zddp-lives-on/
Wildthings
Wildthings is online now
PostPosted: Sat Jan 23, 2021 2:52 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
That is a good article, thanks for posting. I knew oils seemed to have become markedly better over the last few years, but didn't know why. Sounds like having a less volatile variant of ZDDP has good all around benefits: less depletion of the amount of ZDDP in the oil over time so it last longer and less ZDDP fouling the converters. I had become quite cognizant that the processing of the base oils had improved.
francoangellini
francoangellini is offline
PostPosted: Fri Jan 29, 2021 10:47 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Hi guys;
Will be fine for my bug stock 1600cc??....more than 1000 ppm Phosphorus, API service CK4.
Any experiences?
My best.
Last edited by francoangellini on Fri Jan 29, 2021 11:34 am; edited 1 time in total
Wildthings
PostPosted: Fri Jan 29, 2021 11:01 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
francoangellini wrote:
Hi guys;
Will be fine for my bug stock 1600cc??....more than 1000 ppm Phosphorus??
Any experiences?
It doesn't say that it is for use in gasoline engines, but does imply its okay so long as you don't have a catalytic converter. Otherwise I don't know if modern diesel oils that don't carry an "S" rating will do any harm to our older gas engine or not.
francoangellini
PostPosted: Sat Jan 30, 2021 6:09 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Hi guys;
Any experiences?
Good point, also zinc ppm is not informed...
Wildthings
PostPosted: Sun Jan 31, 2021 4:45 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Read the article Zundfolge1432 linked to above:
Also most oils with a second number of 40 or above aren't required to have reduced phosphorous so can run the amount of phosphorous the petroleum engineer designing them deems best to go with the rest of the anti-wear package.
modok
modok is offline
PostPosted: Sun Jan 31, 2021 6:12 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
"Oil extreme" Does that ring a bell? from maybe 10 years ago
At the time did not appear any different than the other snake oils, tho was endorsed by a handful of guys who weren't shills.
If it works why isn't everybody using it?
Products sold "direct to the consumer" usually means big companies won't buy their bull. But not always.
How is new oil better? ...Hint hint
And yet another example of why looking at the oil elemental analysis is misguided.
High Phosphorous....ok, You do not know if it is slow burn DZZP or or fast
If high calcium.... that might be tons of detergent OR Good ep additives
How will you know?
If you want to mix some 15-40 or 20-50 with some 10-30 to get around the regulations that's fine, but IMO the reputation of the product and instructions on the bottle, are more reliable than the oil analysis.
jfdestree
jfdestree is offline
PostPosted: Sat Feb 06, 2021 5:35 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Are all those info suitable for European specs oil?
tcbuscg
tcbuscg is offline
PostPosted: Sat Mar 20, 2021 6:51 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Brad Penn has changed their name to PennGrade. it already contains a ZINC Additive.
I suck at math. does it meet the 1200-1500 PPM with .15% Zinc Mass to 1qt?
https://penngrade1.com/wp-content/uploads/PennGrad...s-2019.pdf
Glenn wrote:
There's been too many topics on the same oil subject.
This will be a ongoing topic to discuss what oil works.
Any similar topics in other forums will be pointed to this one and then locked.
Let's keep to the facts and not get into any heated debates.
Basically "clean" oil is best with frequent changes. Organic vs synthetic, single grade vs multi grade, diesel vs gasoline, does it really matter?
Any BS will be deleted, so stay on topic.
Let the debate begin.
Summary
(for those that don't want to read the entire thread):
"The most important thing is to change your oil, no matter what the type or grade. Apart from that, the overall consensus is to use 10/30 Oil for most climates worldwide and a lot of people in this thread recommend Brad Penn oil or your favorite oil plus a ZDDP additive."
ZDDP levels should be between 1200 - 1500 ppm, more is not better.
When in doubt, experts recommend having 10 psi per 1000 rpms. For example, if you are running at 3000 rpms on the freeway, you should have around 30 psi when at full operating temperature.
Also see
Importance of choosing the correct oil weight
Cap10323
Cap10323 is offline
PostPosted: Sun Mar 28, 2021 8:26 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Since purchase, I have been using exclusively Rotella T5 15W-40 high zinc oil.
This was recommended to me by multiple ACVW mechanics.
What's the general consensus on this oil?
-Ian
'77 Westfalia - 2.0 F.I
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Mar 28, 2021 9:11 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
A number of years ago Shell changed Rotella. i have since switched to Bradd Penn.
But i'm no expert.
Glenn
Member #1009
#BlueSquare
evanfrucht
evanfrucht is offline
PostPosted: Sun Mar 28, 2021 9:50 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
I used to use the T6 Rotella in my bug for years but after completing my new build I plan to use a mix of Brad penn and Motul 300v ester based oil after break in.
I still use the T6 Rotella in my wagon, but have thought about switching that over to BP also.
1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder )
Cap10323
Cap10323 is offline
PostPosted: Sun Mar 28, 2021 9:55 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
But i'm no expert.
I've heard that, but I didn't hear that it was nescissarily changed for the worse?
-Ian
HBSTIZZ
HBSTIZZ is offline
PostPosted: Sun Apr 11, 2021 7:14 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Recomendations for oil in southern california. 1914 motor
Wildthings
PostPosted: Sun Apr 11, 2021 8:18 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
10 psi per 1000 rpm on a well warmed up engine.
ekacpuc
ekacpuc is offline
PostPosted: Wed Apr 14, 2021 10:36 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
There's alot of info here.. Maybe I missed it but anyone using royal purple HPS?
Shows up on my dipstick easier than the clear stuff lol. It has their own anti wear package, synthetic and plenty of zddp...
daos
daos is offline
PostPosted: Wed Jun 09, 2021 9:09 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
any thoughts here on oils with MoS2 content? looking at a Liqui-Moly 10w-30 semi-synthetic. would prefer a fully synth, but it's the moly i'm interested in.
PuddleRainbow
PuddleRainbow is offline
PostPosted: Wed Aug 25, 2021 1:19 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
I regularly run VR1 10w-30 in my 76 standard with factory 1600. I switched to BradPenn 10w-40 just before a 5800 mile July road trip from NJ to TX. Kept the BradPenn at the mid point oil change and then went back to the VR1 10w-30 when I got back to NJ.
The valve train noises are notably quieter with BradPenn than the VR1. Corroborating some of the previous posts on the subject.
57Airhead
57Airhead is offline
PostPosted: Sat Sep 11, 2021 2:31 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Recommended oil for 2165 in a 57 bus with bypass filter and thermo cooler and extra sump. North Coast New South Wales, ambient temps 5C–late 30sC, (rarely early 40sC) in summer (say, 40-100F). Many oils mentioned in this thread hard to get in Aus -- Brad Penn, Rotella, Redline, etc. Preumim oils here Royal Purple, Amsoil, Kendall; more middle road Penrite.
Wildthings
PostPosted: Sat Sep 11, 2021 2:46 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
If your engine will make sufficient oil pressure running 5w30 then that would be a good choice. For myself since synthetic oils handle heat better I would choose a premium synthetic oil.
Page 230 of 235
