andybla Samba Member
Posted: Sat Apr 10, 2021 5:19 am Post subject: Primer for difficult to reach spots |
Hi, how would one handle when you are sanding before primer/paint but you have some spots where you can’t reach because there is a support bracket over the hard to reach spot.
Do primers exist of some sort that don’t need prepping/sanding that you can just apply after some degreasing? some kind of aggressive “adhesive” between layer?
I saw at my parents house, they are re doing their bathroom and the handy man sprayed some sort of reddish layer onto the smooth tiles to create a base to glue the new tiles onto |
bomberbob Samba Member
Posted: Mon Apr 12, 2021 4:45 am Post subject: Re: Primer for difficult to reach spots |
Post a photo of the spots you are trying to reach. Self etching primer might grab onto whatever you are trying to cover, but it at least has to be clean and grease free. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Apr 14, 2021 7:35 am Post subject: Re: Primer for difficult to reach spots |
If you can't reach it then you have to spray/air brush gray or red oxide primer & your paint in there. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Thu Apr 15, 2021 12:33 am Post subject: Re: Primer for difficult to reach spots |
Here are some pictures, it is the space between the bracket and the wheel well bit
Danpa Samba Member
Joined: August 21, 2007 Posts: 1253 Location: Valparaiso, in
Posted: Sat May 08, 2021 2:11 am Post subject: Re: Primer for difficult to reach spots |
Would you be able to get in there with a "hose in bucket" sandblaster?
Dan _________________ 67 Beetle (gone)
68 Bay Window Double Cab (gone) sob, sob!
64 Beetle (gone)
77 Scirocco (gone)
73 Squareback (scrapped)
70 Beetle (current, in pieces) |
Posted: Mon May 17, 2021 11:06 am Post subject: Re: Primer for difficult to reach spots |
in the end i used a por equivalent that we have here, that "eats" itself to the primer and sticks and is also an extra primer on itself after a week of drying |
