badufay Samba Member
Joined: December 13, 2010 Posts: 361 Location: Olympia, WA
Posted: Sat Apr 10, 2021 9:37 am Post subject: Solid Core Spark Plug Wires |
Quick question, are these wires considered solid core wires (Duralast Gold E801229)? I’m wanting to run these with a Pertronix II Ignitor and a Pertronix Flamethrower 0.6 ohm coil. Pertronix says not use solid core spark plug wires. Is a tinned copper core considered a solid core? Does anyone know of any other plug wires that could work with a Pertronix II for a type 4 motor? My bus is a 76 w/ stock FI and the 2.0L motor.
Thanks,
Ben _________________ Current: 1976 VW Bus, 3 spd auto 2.0L FI; 2017 GTI S, 6 spd man; 2017 Jetta SE TSI, 5 spd man; 2006 Golf GL 2.0L, auto
Previous: 2015 Golf S TDI, 6 spd man; 2015 Jetta SE TDI, 6 spd man; 12 Jetta 2.5L, 04 Jetta 2.0L, 02 Golf 2.0L, 98 Jetta 2.0L, 98 Golf 2.0L, 98 Cabrio 2.0L, 95 Golf 2.0L, 87 golf GTI 16 valve 1.8L, 86 Cabriolet 1.6L, 80 Audi 4000 1.6L, 76 Audi Fox 1.6L, 76 VW Beetle 1.6L, 74 Audi Fox 1.5L, 69 VW Beetle 1.5L |
timvw7476 Samba Member
Posted: Sat Apr 10, 2021 11:14 am Post subject: Re: Solid Core Spark Plug Wires |
I've used solid core wires in the past, but they were usually Brazilian name manufacturer and were for a breaker point ignition system. The copper strands can carry 'eddy currents' & do strange things to modern electronics which is what the Pertronix ignition is compared to an old points set. I'd go for a graphite infused Denso or NGK wire set & protect the Pertronix ignition circuit. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Sun Apr 11, 2021 11:56 pm Post subject: Re: Solid Core Spark Plug Wires |
The factory stock wires are solid core. There are resistors inside the brown spark plug connectors and the rotor. The spark plug connectors fail periodically. You can check all of this with an ohmmeter - should measure somewhere between 2.5 kohms and 5 kohms, as I recall. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Mon Apr 12, 2021 2:06 am Post subject: Re: Solid Core Spark Plug Wires |
How are the Bosch wires these days quality wise? _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
