Aeonwulph Samba Member
Posted: Sun Apr 11, 2021 12:58 pm Post subject: Vw pancake motor should i sell |
I have a pancake motor that’s been sitting in the rain for awhile it’s in a dune buggy currently but I was wondering if it would be worth it to sell it or should I just scrap it |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sun Apr 11, 2021 1:23 pm Post subject: Re: Vw pancake motor should i sell |
Sell it or give it away to someone who needs it.
Whenever I cant use something I give it away. Vw people need that kind of stuff like that more than the scrap yard do. A vw engine only weighs 300ish lbs so that's like 10 bucks from the scrap yard.
But then again, it is yours, and you can do whatever you wish.
Vw engines also make auxilerating bon fires. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Sun Apr 11, 2021 1:28 pm Post subject: Re: Vw pancake motor should i sell |
Alrighty any idea if I were to sell it how much it would be |
Posted: Sun Apr 11, 2021 1:29 pm Post subject: Re: Vw pancake motor should i sell |
List it on facebook marketplace or HERE on the samba. Does it turn over?
If not, then 75ish
If it turns over, then 125ish
If it runs, 300-500ish
Also, welcome to the samba _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Sun Apr 11, 2021 1:45 pm Post subject: Re: Vw pancake motor should i sell |
Thanks so much man |
Posted: Sun Apr 11, 2021 1:50 pm Post subject: Re: Vw pancake motor should i sell |
Also how would I go about checking if it turns over/ runs |
Posted: Sun Apr 11, 2021 1:56 pm Post subject: Re: Vw pancake motor should i sell |
Take spark plugs out. Put a socket over the pulley nut. Put car in nuetral. If it turns over rough or not at all. STOP.
Rust in the cylinders will scrape the pistons which is a no no. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Sun Apr 11, 2021 2:03 pm Post subject: Re: Vw pancake motor should i sell |
Stop working on it! you're just increasing the price.
Posted: Sun Apr 11, 2021 2:07 pm Post subject: Re: Vw pancake motor should i sell |
modok wrote: |
Next thing you know it'll be completely dissasembled laying on the bench. Happens everytime _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
nextgen Samba Member
Joined: August 19, 2004 Posts: 6025 Location: CONGERS, N.Y.
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5410 Location: Holland, MI
Posted: Sun Apr 11, 2021 3:42 pm Post subject: Re: Vw pancake motor should i sell |
If it’s a T4, be sure save at least the case. Cases are a limited quantity. Good ones are still relatively cheap, but they won’t be around forever. Same with fans and blower housings.
If you part it out...
There is a pretty high demand for 1700 rockers as well with the 8mm adjuster threads (used with Mahle-Wisemann Porsche 911 adjusters).
If it’s a 1700 or 1800, save the rods and crank if you can. No real value in the stock 2.0 crank or rods though due to the aftermarket.
Someone will probably pick the whole thing up for a core and save what they want. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Sun Apr 11, 2021 3:46 pm Post subject: Re: Vw pancake motor should i sell |
That engine is worth 0 if the case is rotted out. If your gonna see if it turns over, you may as well remove the oil plate and feel and or look around. If the cam gear or oil hole opening is rotted, sell it as a parts engine and make sure the buyer knows its rotten. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Sun Apr 11, 2021 3:59 pm Post subject: Re: Vw pancake motor should i sell |
Chickensoup wrote: |
That engine is worth 0 if the case is rotted out. If your gonna see if it turns over, you may as well remove the oil plate and feel and or look around. If the cam gear or oil hole opening is rotted, sell it as a parts engine and make sure the buyer knows its rotten. |
IF it's a type IV, they don't rot the same as type I's...
Even a rotted case typeI has some value---OG head studs. nut washers, various length 8mm studs, misc hardware.. |
Posted: Sun Apr 11, 2021 4:20 pm Post subject: Re: Vw pancake motor should i sell |
I've never opened up a case that was rotted that didnt have rotted heads. And that's been all of them.
Again, if that were the case, the OP would have to dissasemble the whole engine just about to figure that out.
Modok gave the best answer imo _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
oprn Samba Member
Joined: November 13, 2016 Posts: 12714 Location: Western Canada
Posted: Sun Apr 11, 2021 4:44 pm Post subject: Re: Vw pancake motor should i sell |
What makes you think it is not usable in your Buggy? If it is complete with air cleaners, exhaust system etc. the rain may not have harmed anything of consequence.
Type 3 engines around here are as scarce as hen's teeth. Pretty sure some type 3 guy needs it for bits and pieces even if nothing internal is usable
If it's a type 4 engine do not throw it away!
Post a picture.
Where in Canada are you? I would take it if it's within reasonable driving distance. Unless it's an early 1500 type 3 that is... single carb, then only the tinwork is of interest. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Sun Apr 11, 2021 5:04 pm Post subject: Re: Vw pancake motor should i sell |
Alfter all our replys and not hearing from him I checked his number of posts.
Total 4. Maybe he is a newbe and thinks any VW Flat engine is a Pancake.
I know My relatives from Sicily on a visit told me they were driving a Jeep .
Wait for them to pass were I was waiting and then I followed a Jeep for a few miles till we both stopped at a light.
It was not them, what the!! Their son said they call SUV's Jeeps. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5995 Location: Brooklyn
Posted: Sun Apr 11, 2021 6:20 pm Post subject: Re: Vw pancake motor should i sell |
I left this engine sitting out in the rain and now I want top dollar for it _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
cbeck Samba Member
oprn Samba Member
Posted: Mon Apr 12, 2021 5:31 am Post subject: Re: Vw pancake motor should i sell |
sjbartnik wrote: |
I left this engine sitting out in the rain and now I want top dollar for it |
At no time did he say or even infer that! Did you even read his first post?
cbeck wrote: |
Pop the valve covers. If rusty, the value is $0. |
Not true!
I would give him $40 just for the generator, tins, thermostat and hardware. I would up that to $150 if the dual carbs and distributor are usable. And that would be a bargain, I just paid $150 + shipping for a thermostat. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
mark tucker Samba Member
Posted: Mon Apr 12, 2021 9:54 am Post subject: Re: Vw pancake motor should i sell |
out in the rain...how stupid. it may or may not have a $20 part in it. |
