Braukuche Samba Member
Posted: Tue Mar 30, 2021 4:49 pm Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
xoo00oox wrote: |
Braukuche wrote: |
I like rebuilt German Solex the best. But they have to be machined, shaft bushings installed, bases checked for flatness...just putting in a new gasket kit seldom works especially with the PICT 34 -3 carbs. |
Is there a company or a guy you're happy with to get this done? |
https://www.thesamba.com/vw/classifieds/detail.php?id=2435620 _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1973 Ghia convertible |
Marcdeb Samba Member
Posted: Tue Mar 30, 2021 5:24 pm Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
Braukuche wrote: |
xoo00oox wrote: |
Braukuche wrote: |
https://www.thesamba.com/vw/classifieds/detail.php?=2435620 |
I second that. I had Tim (VolkzBitz) rebuild my 34Pict-3 and it came back as good as new.
_________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Tue Mar 30, 2021 10:57 pm Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
While this may be in theory the best option, please check if they can maybe test it after the rebuild.
I had mine rebuilt in Germany (very reputable guy), and it did not idle at all. Backing off the idle jet slightly, and loctiteing into place, did the trick.
Maybe I'm wrong, but there isn't really a way to check if the idle jet was forced into the thread too much at one point, so that when you snug it up normally, it goes past the "sweet spot" (because the thread is longer) and you get less fuel.
At least a small detail to think about
Vlad _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
mxl556 Samba Member
Joined: December 05, 2015 Posts: 62 Location: Vermont
Posted: Wed Mar 31, 2021 5:15 am Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
xoo00oox wrote: |
It's an original Solex 30PICt-3 made in W Germany, doesn't seem to have play in the throttle shaft. to me it feels like it's slightly lean. If I give it a slight tap of the gas to richen it with the accelerator pump it seem better for a second. Possibly a richer idle jet or idle air jet? What do you think? Is this typical of today's ethanol fuel causing lean conditions? |
My understanding is that the gasoline with ethanol would lean out the mixture and it also has less energy and generally does not work the same way as pure gasoline. Need larger jets to overcome this but better to find E0 gas. You should be able to find ethanol free gas in upstate NY, give it a try and see.
I have a 34 pict3 from Tim (Volkzbitz). I got it about 8 years ago and it has been working perfectly. Probably have 10-15K miles on it at least. It has larger 130/55 jets to better handle E10 gas. I believe Tim's carbs normally come with larger jets to work with E10 gasoline.
Max |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2671 Location: East Nassau, NY
Posted: Wed Mar 31, 2021 5:01 pm Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
Thanks for the tips and link guys, I'll continue working with it and try to get it to smooth out.
Meanwhile, the Squrit is smoothing out very nicely....
Posted: Mon Apr 12, 2021 11:43 am Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
I enriched the main jet and pilot jet and that really made the nice improvement in the driveability I was hoping for, no more stalling coming to a stop and the hitching feeling when driving with a light throttle is gone. It's so much nicer to drive being smooth.
How do you guys carry bikes with these things? I can very carefully let it ride as a co-pilot with the roof down but if it starts to rain I'll have to make a decision.
For anyone that cares.......
I marked out the water line with a laser level and painted the bottom of the boat red.
And after that cured, flipped it to start work on the top side!
Posted: Mon Apr 12, 2021 12:47 pm Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
YOW! I sure as Hell am not putting that thing on my car! |
Posted: Mon Apr 12, 2021 1:03 pm Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
Other than the piece of masking tape on it that says Ghia I wonder what other proof he has. I’m calling BS on that one. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Mon Apr 12, 2021 2:03 pm Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
xoo00oox wrote: |
No, I wouldn't either!!! But knowing me, if I put a bike on that beautiful upholstery, with my luck, I would damage it for sure. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Tue Jun 22, 2021 1:23 pm Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
Greetings Ghia group. Not much activity going on with my Ghia, once I got it fully situated looking and driving nice it just sits and collects dust. I don't think I've driven it in about six weeks.
I did just find that tail light lens I needed at the swap meet at the Terryville CT VW show this past weekend. A near perfect Hella made in Germany for only $10!
There were plenty of Ghia sedans at the show....
And in the Ghia convertible section, there was only one...
-check out tha Schwimmwagen
I would have driven mine there but wanted to camp out at the show Saturday night so drove my '89 Westy instead. |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Tue Jun 22, 2021 3:40 pm Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
All of us East Coast convertible owners need to get up to that show next year to boost the vert representation, Charlie, Marc, you guys up for it???
Haven't seen a Schwimmwagen in a long time, you are a lucky man for sure!
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Posted: Tue Jun 22, 2021 3:54 pm Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
Years ago there used to be two Schwimmwagens that would show up to the Litchfield show. I have not seen one in years either, glad that one showed up this year.
Posted: Tue Jun 22, 2021 8:03 pm Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
rbsurfguy wrote: |
Jeff |
Not surprising. Way more coupes out there. I'd love to go, but I need to get the darn thing road worthy first, and then gain some confidence with reliability. But possible for sure. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Tue Jun 22, 2021 8:07 pm Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
xoo00oox wrote: |
I did just find that tail light lens I needed at the swap meet at the Terryville CT VW show this past weekend. A near perfect Hella made in Germany for only $10. |
Hi Andrew,
If you need a reason for a drive, head on over here to Vermont. I'll help you put some miles on that beautiful car! _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Wed Jun 23, 2021 6:50 am Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
Marcdeb wrote: |
xoo00oox wrote: |
Hi Andrew,
If you need a reason for a drive, head on over here to Vermont. I'll help you put some miles on that beautiful car! |
I'm considering going to the Wolfsgart show in Burlington at the end of July.
https://wolfsgart.com/aboutus/ |
Rome Samba Member
Joined: June 02, 2004 Posts: 9584 Location: Pearl River, NY
Posted: Thu Jun 24, 2021 4:16 am Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
xoo00oox wrote: |
You caught me in this photo; I'm at far right with the checkered shirt and the straw hat, speaking with the Ghia's owner rbfara who has his back to you. Nuts that we did not realize who we are. In this group, not seen on the right, was Dennis from v-dubstore in eastern PA who is my VW cylinder head and case machining specialist. I asked the event DJ whom I've known for over 20 years if there was a Samba group photo, which in past years (long ago) used to be taken right at the DJ bus- and there seemed not to be one this year. I missed meeting several other Samba people at the event such as Mustie1 and 67ctbug. Maybe next year your Ghia will be displayed in this class! |
Posted: Thu Jun 24, 2021 6:11 am Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
Rome wrote: |
xoo00oox wrote: |
Cool! I've know JimmyD the DJ for years, he was hanging out with our group around the campfire Saturday night. What a great show it was this year! |
Posted: Mon Aug 02, 2021 10:30 am Post subject: Re: I just bought a Ghia that sat for the past 41 years. |
Well here it is August already and I still don't think I've even put more than a couple hundred miles on my Ghia.
I did come across this beauty over the weekend at the Wolfsgart show in Burlington....
