Farfegnuggin Samba Member
Posted: Tue Oct 22, 2019 4:34 pm Post subject: Turn Signal Wiring question |
I am neck deep into an electrical fight that has caused me to learn WAY more about multi meters, VW relay numbers and auto wiring diagrams than I ever hoped to know. I have had great success following the wiring diagram for my Bug (1971, standard Beetle) and managed to get almost everything working. Except the turn signal 'warning' lamp. Everything works exactly as designed. Emergency flashers flash when switch is activated, turn signals work on both sides with one caveat: once the lamp in the speedo is connected, I get a quick flashing from the circuit. I have the speedo bulb wired into the relay in the same way that the diagram shows. Any thoughts? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31373 Location: Hot Arizona
Posted: Tue Oct 22, 2019 5:30 pm Post subject: Re: Turn Signal Wiring question |
Cusser wrote: |
That warning light bulb is OK, right? |
Thanks. Fair point. Yes it works. |
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Wed Oct 23, 2019 11:50 am Post subject: Re: Turn Signal Wiring question |
It should only quick flash if one of the front or rear turn signal bulbs is missing, burned out, or not connecting.
I had similar issue with the old relay not giving good signal to the KBL terminal. Just connected the blue indicator wire to the 49a instead. As long as the bulbs are making good contact I was good. _________________ 1972 Standard Beetle
1969 Baja Beetle |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Wed Oct 23, 2019 3:07 pm Post subject: Re: Turn Signal Wiring question |
What make/model flasher relay are you using? I suspect you are using the wrong flasher relay (generic relay??) or your flasher relay is going bad.
Without the speedo turn indicator lamp, the flasher relays + corner turn signals is very straight forward:
Power from the fuse box (ignition switch power or battery constant power) passes thru the E-Flasher switch and goes to the 49 (+) terminal on the flasher relay. This is how the flasher relay is powered.
Pulsing output from the 49a terminal of the flasher relay passes thru the turn signal switch before going to EITHER the L or R side corner lamp pairs.
When the E-Flasher switch is turned on the power source swaps to battery constant 12v and a path is opened from the 49a terminal of the flasher relay to BOTH the L and R side corner lamps (4-way).
The end result is pulsing power from the flasher relay passes thru two or four 21W corner lamps.
When you add in the turn indicator lamp in the speedo things get complicated. There are two concepts you need to understand:
1) Small wattage bulbs (2W indicator lamp) are very restrictive and only flow a small amount of current.
2W / 12v = 0.167A (speedo bulb)
21W / 12v = 1.75A (corner turn lamp)
If you place a small watt bulb in-line with a larger watt bulb the current flowing thru the smaller bulb will restrict the current flowing thru the larger. While the small bulb may glow brightly, the larger watt bulb may not glow at all even while the current is flowing thru. This means if power flows thru the 2W speedo bulb on the way to ground thru the corner lamps the corner bulbs will not turn ON even if current is flowing because there is insufficient current to light the larger watt bulb.
2) Most think the only way to turn a bulb OFF is to REMOVE voltage. This is just the most common way. Applying the same (or nearly the same) voltage on both sides of a bulb will reduce current flow to zero (or nearly zero).
Consider this: If you run two wires from the battery (+) post and place one wire on each side of the bulb (12v positive current on both sides of the bulb filament) the bulb will NOT light up.
This may seem obvious, but it is a key point... another way to turn OFF a bulb is to apply equal voltage (potential) on both sides of the bulb.
A bulb glows because current is FLOWING thru the bulb... not because of the presence of voltage. The bulb with two 12v+ wires HAS voltage but because the voltage level on both sides of the bulb are the same voltage potential current is NOT flowing. This means it is possible to flash a bulb by:
Maintaining 12v+ on one side of the bulb,
while alternating voltage on one side of the bulb from 1v+ (bright) ~ 12v+ (off).
When the voltage difference (potential) is high more current flows. When the voltage difference is zero... no current flow and the bulb turns OFF.
Ok, so how does this make the turn indicator lamp in the speedo flash??
When you turn the ignition switch ON, the turn indicator lamp in the speedo "sees" 12v+ on both sides of the bulb. The indicator lamp, along with the OIL and GEN lamps are powered by the ignition switch via a black wire from the fuse box.
On the other side of the turn indicator lamp is the flasher relay 49a OUTPUT terminal. While the ignition switch is ON and the E-Flasher switch is OFF there is 12v+ passing thru the flasher relay and looking for a path to ground. With the turn signal switch centered and the E-Flasher switch OFF there is no open path to the corner lamps.
There IS a path to the turn indicator lamp, but the 12v+ coming out of the flasher relay is running head on into the 12v+ coming thru the indicator lamp. No current is flowing thru the indicator lamp so the indicator bulb is OFF.
When you move the turn signal lamp to the L or R turn position:
A path to ground is now open thru the corner lamps on one side. Pulsing current is flowing out the 49a terminal to the corner bulbs. The corner bulbs turn ON. The speedo indicator lamp remains OFF because there is still 12v+ coming out of the 49a is still running into the 12v+ coming out the indicator lamp.
When the flasher relay pulses OFF... no voltage is flowing out the 49a terminal anymore. So the corner lamps turn OFF. But there is still voltage at the speedo indicator lamp. With no positive voltage coming out of 49a to prevent current flow.. current starts to flow thru the indicator lamp and grounds thru the corner lamps. The indicator lamp turns ON! But there is insufficient current flowing thru the small 2W indicator lamp to burn the filaments in the corner lamps so they remain OFF.
When the flasher relay pulses back ON, the corner lamps turn ON and the turn indicator in the speedo turns OFF. While this continues the turn indicator lamp in the speedo flashes OPPOSITE the corner lamps.
Note that when the flasher pulses OFF this is positive voltage from the speedo indicator lamp passing thru the 49a terminal of the flasher relay. This is where some "generic" flasher relays may have trouble. The simple "generic" relays are not designed to handle voltage appearing on the OUTPUT terminals.
This exactly how the VW turn signal system works. The VW compatible flasher relays must sense current flowing OUT of the 49a terminal but not "freak out" if there is current flowing in/past the 49a OUTPUT terminal.
If disconnecting the speedo turn indicator allows the corner lamps to work perfectly (turn or E-Flasher) it is a sign the flasher relay is the problem. _________________ AshMan40
vdubguru Samba Member
Posted: Tue Apr 13, 2021 7:43 am Post subject: Re: Turn Signal Wiring question |
Greetings all,
I am running into an issue with my 68 beetle that I think fits this thread. I recently made some modifications to the front suspension and want to give full disclosure. Installed a Limebug 4" Narrowed beam. Did the work myself on the floor of my garage. Installed, driving, all is well.
Problem I now have is, my indicators began to fritz out and I was getting a buzzing/squealing noise from the blue 9 pin flasher box. The dash indicator light stays illuminated and the signals will come on but stay on and the noise happens. Eventually, the noise stopped completely and I figured I needed to replace the blue 9 pin box.
Skip to earlier this week, received the new box in the mail, installed and it still squeals. So I put a voltage tester on it and everything seems to be working except the wire feeding terminal 49a is showing 5-6 Volts. Terminals 30 and 15 both see full 12+ Volts as well as well as the Terminal KBL when ignition is switched on.
Did I get a dodgy new box or should I be looking for something else?
I'm baffled. _________________ "I wear a suit of armour made only of my mistakes" -unknown |
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Tue Apr 13, 2021 8:03 am Post subject: Re: Turn Signal Wiring question |
Since you were working with the beam, I would start by making sure you didn't pinch any of the front turn signal wires up under the wheel well. The noise can be from a wire shorting either to ground or shorting to another wire and backfeeding. Eventually, the noise will stop on your new relay too if left like that. A lot of times, odd reading voltages like that are due to poor connections or cross-shorting. _________________ Come on, It's not rocket science. KISS |
Posted: Tue Apr 13, 2021 8:05 am Post subject: Re: Turn Signal Wiring question |
Thanks, I'll take a look again.
I didn't think anything was binding or touched, but its certainly worth another check. _________________ "I wear a suit of armour made only of my mistakes" -unknown |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Tue Apr 13, 2021 8:59 am Post subject: Re: Turn Signal Wiring question |
What happens if you take the flasher out and test it on the battery? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Tue Apr 13, 2021 10:14 am Post subject: Re: Turn Signal Wiring question |
My suggestion would be to disconnect the turn indicator lamp in the speedometer. Get both the corner turn signals and E-Flashers (4-way) working normally. Then, reconnect the turn indicator lamp and see if things stop working.
Test the speedometer turn indicator lamp... disconnect the blue/red wire from the KBL terminal of the flasher relay. With the ignition switch in the ON/RUN position, ground the end of the blue/red wire. The center-bottom speedometer indicator lamp should turn ON solid. This confirms the indicator lamp is powered correctly and grounding the end of the blue/red wire will illuminate the lamp.
As a possible workaround, move the blue/red turn indicator lamp wire from the KBL terminal of the flasher relay to the #49a terminal. See if this helps. This is how the later 3-prong flasher relays were wired and can be used as a workaround when the KBL circuit in the flasher relay fails.
Are you possibly running any LED bulbs in any of the corner turn signal light assemblies? VW flasher relays were designed to work with 21W corner lamps. Most modern LED bulbs only draw around 2W and do not put enough of a load on the stock flasher relay. The easiest fix is to add a 50W LED resistor into both the left and right turn signal circuits to simulate two 25W bulbs. This additional load will fool the flasher relay into thinking the proper bulbs are installed. _________________ AshMan40
Posted: Wed Apr 14, 2021 4:33 am Post subject: Re: Turn Signal Wiring question |
ashman40 wrote: |
Are you possibly running any LED bulbs in any of the corner turn signal light assemblies? VW flasher relays were designed to work with 21W corner lamps. Most modern LED bulbs only draw around 2W and do not put enough of a load on the stock flasher relay. The easiest fix is to add a 50W LED resistor into both the left and right turn signal circuits to simulate two 25W bulbs. This additional load will fool the flasher relay into thinking the proper bulbs are installed. |
Firstly, thanks for your suggestions. I don't run any LED bulbs, but in future if I decide to run any, I'll take this into consideration.
I gave the turn signal light test a go - no issues there. Also, all lights will light up properly when bi-passing the switch, really wondering if that box is bad.
Checked to make sure all my wiring to and from the signals were not damaged, and I didn't see any signs.
Additionally, we now have an issue with the horn - the wire coming through the centre will only sound the horn when it gets grounded to thin metal plate on the turn signal switch (when the wheel is off) or around the snap ring area holding steering column bearing. It should work just by touching the wire to the shaft itself so I think somehow my steering column has grounded itself. Will take that all apart and confirm it goes back together correctly. Probably all all related somehow.
oh, the joys. _________________ "I wear a suit of armour made only of my mistakes" -unknown |
Posted: Wed Apr 14, 2021 3:17 pm Post subject: Re: Turn Signal Wiring question |
vdubguru wrote: |
I don't run any LED bulbs |
Great! That eliminates that as a possible issue.
vdubguru wrote: |
I gave the turn signal light test a go - no issues there. |
Good. So grounding the blue/red wire that normally connects to KBL or 49a results in the turn indicator lamp in the speedometer turning ON solid.
vdubguru wrote: |
Also, all lights will light up properly when bi-passing the switch |
None of my suggested tests were to bypass a switch. Which switch did you bypass? The turn signal switch or the E-Flasher switch? Or did you bypass the blue 9-prong flasher relay?
vdubguru wrote: |
Additionally, we now have an issue with the horn - the wire coming through the centre will only sound the horn when it gets grounded to thin metal plate on the turn signal switch (when the wheel is off) or around the snap ring area holding steering column bearing. It should work just by touching the wire to the shaft itself so I think somehow my steering column has grounded itself. Will take that all apart and confirm it goes back together correctly. Probably all all related somehow. |
Sounds like you misunderstand how the horn should be wired???
The horn itself has constant 12v+ while the ignition switch is ON. Grounding the horn (-) terminal is what sounds the horn. The steering shaft bearing is part of the horn (-) circuit. The steering wheel mounted to the end of the steering shaft is the "loose end" of the horn (-) wire. The wire coming out the center of the steering shaft under the cap in the steering wheel is NOT the horn wire. It is a ground wire. Touch that ground wire (or any ground wire) to the steering wheel of the steering shaft and you are grounding the horn (-) circuit.
The horn (-) circuit starts at the horn (-) terminal.
A brown wire runs from the horn terminal to the steering shaft bearing in the steering column housing.
The bearing connects electrically to the steering shaft.
The steering shaft connects to the steering wheel. This is the end of the horn (-) circuit.
Using a jumper wire grounded at the shifter bolt, touch each of the above points while the ignition switch is ON to confirm that the horn sounds at each step of the way. If you ground one of the above points and the horn doesn't sound... you have a disconnect. Not unusual for years of rust/oxidation to compromise the electrical connection somewhere along the way.
The brown wire coming out of the center of the steering shaft is grounded to the steering box bolt at the steering shaft coupler under the gas tank.
This brown wire connects to the horn ring (button) suspended above the steering wheel by springs and insulating washers.
When you press on the horn ring/button you force the horn ring to make contact with the steering wheel which grounds the horn (-) terminal. _________________ AshMan40
Andersonjoe Samba Member
Joined: July 02, 2013 Posts: 16 Location: Connecticut
Posted: Wed Apr 21, 2021 8:33 am Post subject: Re: Turn Signal Wiring question |
Ashman,
I love how analytical you are with the electrical system. Just wanted to say that everything that you've laid out here is super informative and great notes to take for troubleshooting. _________________ 1973 Std. Beetle- Still in restoration. But who are we kidding? When is a beetle ever fully finished? |
PuddleRainbow Samba Member
Joined: April 13, 2018 Posts: 288 Location: The Dirtiest Of Jersey
Posted: Wed Apr 21, 2021 1:28 pm Post subject: Re: Turn Signal Wiring question |
Quote: |
Problem I now have is, my indicators began to fritz out and I was getting a buzzing/squealing noise from the blue 9 pin flasher box. The dash indicator light stays illuminated and the signals will come on but stay on and the noise happens. Eventually, the noise stopped completely and I figured I needed to replace the blue 9 pin box. |
Check the fuse. Had exact same symptoms when turn signals on for more than 10 seconds. Removed and replace same fuse and works fine now. Of course this was after I chased everything else down. |
