MSMD Samba Member
Joined: November 01, 2019 Posts: 5 Location: Upstate NY
Posted: Mon Apr 12, 2021 6:58 pm Post subject: Sunroof part VW Beetle 1965 |
Does anyone know where I can find the double barrel metal tubing that guides the cable around the front curve of the Steel sunroof?? It looks almost like brake line tubing welded together and bent in a curve. All the other parts can be sourced from Wolfsburg West but not this.....any suggestions? Thanks |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Posted: Tue Apr 13, 2021 6:35 pm Post subject: Re: Sunroof part VW Beetle 1965 |
I have no source for you but there was also a plastic version as well.
My 64 had the plastic. Seems like back in the day when i was parting out bug sunroof parts later years had the metal guides.
You may look at the classified for both newer bugs and even Type 3 as that sunroof was similar. You may even look at Bay window buses which had a similar sunroof in the late 60's and early 70's. _________________ 1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat. |
ALWAYS1961 Samba Member
Joined: June 17, 2017 Posts: 49 Location: ARROYO GRANDE, CA
Posted: Sat Oct 16, 2021 4:17 pm Post subject: Re: Sunroof part VW Beetle 1965 |
In case you haven't found them, I found mine from:
www.bugcity.com |
