Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Tue Apr 13, 2021 7:51 am Post subject: Re: '59 Karmann Ghia fever |
Now see a auto-exposure camera analogy to volts, amps, and ohms in my power source.
Resistance (ohms) is constant — light is constant
Control volts, amps vary per resistance — Control shutter-speed, aperture varies per light (shutter priority mode)
Control amps, volts vary per resistance — Control aperture, shutter-speed varies per light (aperture priority)
Finally had the nerve to up the voltage to 12 to power the interior light bulb. Interestingly only about 8 watts was generated for the 10 watt bulb. _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
Trylon Samba Member
Posted: Tue Apr 13, 2021 6:12 pm Post subject: Re: '59 Karmann Ghia fever |
Interior light wiring fun today.
Cleared a bit of paint for ground and pulled the passenger side door switch wire through:
Attached the wire — only realized how it should go at the last moment (push up the bottom tab, put the wire in the hole, letting the spring hold the wire in):
Pushed the switch into is hole:
Hooked one lead of a multimeter to the other end of the wire and the other lead to the body.
Door open showed continuity:
Door closed did not:
Success!
Then the comedy show began. I had to hook up and tape the other wires (those to the light and those to the other door switch) THREE TIMES! The first time, I realized the harness was on the wrong side of the struts; the second time, on the wrong side of clutch cable; third time, the wires of the harness itself were intertwined.
Finally got it right and pulled them through (with a lot of back and forth coaxing):
It was late and it took too long to do this, so I have not yet wired up the other door switch and interior light.
Hemingway was said to have always stopped writing knowing what he was going to write tomorrow to give him something to get started the next day.
That’s my plan.
Here’s what the harness looks like in the trunk:
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Marcdeb Samba Member
Trylon Samba Member
obus Samba Member
Joined: March 08, 2001 Posts: 11040 Location: just off Garden State Parkway Exit 81
Trylon Samba Member
Posted: Wed Apr 14, 2021 5:50 am Post subject: Re: '59 Karmann Ghia fever |
Yeah, don’t we?
Even without wipers, mirror, interior, ... _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8206 Location: San Dimas
Trylon Samba Member
Posted: Wed Apr 14, 2021 12:04 pm Post subject: Re: '59 Karmann Ghia fever |
Interior light wiring- Day 2
So this is the day I am supposed to be done with rewiring the entire car.
Huh.
Well, moving along...
Got the drivers side switch attached:
Tested continuity on both switches.
Doors closed:
One door open:
The other door open:
Let’s put in the light!
Seems to be a bit of original material in the hole for insulation:
Wired the light. I am assuming the switch goes on the right.
The “constant on” ground wire just ends in bare wire. Would love to hear how it should attach to the body. Is there some sort of clamp I can attach to it? If so, it seems that it could just clamp to the fixture.
Powered it up with 12v:
Off when both doors closed. On when either or both are open.
The drivers side ground is a little iffy. I polished the switch surfaces and I think, from inspecting the switch, that the inside of the hole needs to be clean bare metal. Got it to work but fully expect it not to in the future. Will deal with it again when it fails.
Here’s the fuse box:
Looks like I need to drill a hole in the underside of the dash to hold it in:
Fuse in interior light circuit (yes, I know it is upside down)
I know I have asked before but I need an index to this thread!
Which slots get red fuses and which get white? How many amps for both?
I think wipers are on the docket for tomorrow! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Thu Apr 15, 2021 9:47 am Post subject: Re: '59 Karmann Ghia fever |
So poked around to see where the heck the ground wire for the interior light might attach. Here is someone else’s clear view of what I am only feeling with my finger:
I find nada. I guess I could attach a clip to the wire and clip it on to the body but I seriously doubt that that is how it was done.
Until I get more information, I have pushed the light in (but not all the way):
At least it works with the doors and can be turned off completely. Just can’t be turned on separately.
I can see that this may be a theme in this wiring project— good enough, wait for another day to make it better. Otherwise I might not make next year’s Lime Rock Parade!
So it’s on to the wipers.
I think I have all the parts (and I wonder if there are more here than I need):
Did you note that they are silver?
If you recall, I changed the armature of this 6v wiper motor to accommodate 12v:
Unfortunately, I have been unable to make it move.
Thought there should be continuity between the wiper body mount and 54 but found none. There is no continuity anywhere.
Tried to put 12 volts on it anyway and, as expected without continuity, nothing happened.
Hmm.... _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Thu Apr 15, 2021 10:00 am Post subject: Re: '59 Karmann Ghia fever |
Don’t have this tab shown in Loren’s picture but that should only matter when the motor is mounted:
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13942 Location: Southampton U.K.
Posted: Thu Apr 15, 2021 10:46 am Post subject: Re: '59 Karmann Ghia fever |
Let's stop it, or else we'll get a brick through the screen, or like in classic movies, wake up next to a horses head _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
Trylon Samba Member
Posted: Thu Apr 15, 2021 10:51 am Post subject: Re: '59 Karmann Ghia fever |
Taking stock, we are missing the inner and outer bearing seals:
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Loren Samba Member
Posted: Thu Apr 15, 2021 12:33 pm Post subject: Re: '59 Karmann Ghia fever |
I think the dome light is grounded via the spring loaded button that holds in place. You might have to remove a small piece of the headliner and sand the metal a bit to give it a good ground.
As for the wipers, the color is spot on, it's the roof of the car that is supposed to be black |
Trylon Samba Member
Posted: Thu Apr 15, 2021 12:36 pm Post subject: Re: '59 Karmann Ghia fever |
Loren wrote: |
I read about that grounding method as well but tested that button for continuity and no go. Seemed odd to me as it looks like it would serve as a ground but... maybe I didn’t test it correctly. Will give it another go.
Thanks for playing, Loren! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
PeteSC Samba Member
Posted: Thu Apr 15, 2021 1:41 pm Post subject: Re: '59 Karmann Ghia fever |
Loren wrote: |
Dwayne really outdid himself with that paint correction, didn't he?
Sorry Michael. |
Trylon Samba Member
Posted: Thu Apr 15, 2021 1:50 pm Post subject: Re: '59 Karmann Ghia fever |
PeteSC wrote: |
Loren wrote: |
Sorry Michael. |
I didn’t notice the mod until I saw the apology.
Accepted. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
