Thoragaverung Samba Member
Joined: September 15, 2018 Posts: 81 Location: Saint Paul
Posted: Wed Apr 14, 2021 4:31 am Post subject: Hard brake line replacement: what size line and fittings? |
I am in the last stages of negotiating for an '85.
I want to replace ALL the brake lines. I'd be bending and flaring my own lines (never done this before).
What size line should I be using? Are there metric lines and SAE lines, or does one just use the same stuff you get at a US parts store? What size line would I use, and what size fittings for the master/slave cylinders and calipers?
Thank you. _________________ Happy to help, but my advice comes with no guarantees. Use at own risk. |
Posted: Wed Apr 14, 2021 4:47 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
Oh, and would the 1985 use double or bubble flaring? _________________ Happy to help, but my advice comes with no guarantees. Use at own risk. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17154 Location: Retired South Florida
3/16 ths for the hardline. We buy a roll of hardline from Oreillys auto parts. It’s coated and is very similar to OE Summit Racing sells the fittings. They are 10mm x 1.0 pitch. The clutch may have a larger line, but I’m not sure. You will need a tool that can make a bubble flare.
Making lines is one of my least favorite jobs. If you are talked into stainless, that is even more frustrating. _________________ ☮️ |
space Samba Member
Posted: Wed Apr 14, 2021 5:52 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
Yes=Bubble flared
My local stores had a very poor selection of fittings in the 10mm x 1 range
Bought this last year worked out very well
https://www.ebay.com/itm/3-Way-Tubing-Pipe-Bender-...Sw4w9fNO0V _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
4Gears4Tires Samba Member
Posted: Wed Apr 14, 2021 8:21 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
I don't bother with the pipe bender tool because I use nickel copper (nicop) line for my replacement brake lines and fuel lines. I put a bubble flare on both. Rubber line and a hose clamp seals nicely against a bubble flare for fuel lines. Not only does nicop easily bend by hand, it flares so much easier as well. I find a little grease in the flare tool die helps to get the perfect bubble each time.
https://www.amazon.com/4-75-Copper-Nickel-Brake-Fi...s9dHJ1ZQ==
And it doesn't rust. _________________ '87 Syncro
space Samba Member
Posted: Wed Apr 14, 2021 8:59 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
4Gears4Tires wrote: |
And it doesn't rust. |
Some bends are too tight to bend by hand (01 pathfinder)
T _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
Posted: Wed Apr 14, 2021 9:12 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
Hm... what size hard line would I use if I were going to replace the fuel lines, too?
If I have a tool to make a bubble flare on the end... that would make things simpler too. Nice hard lines, less chance of leaks. _________________ Happy to help, but my advice comes with no guarantees. Use at own risk. |
Posted: Wed Apr 14, 2021 9:23 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
Fuel line is likely close to 5/16ths. _________________ ☮️ |
valvecovergasket Samba Member
Posted: Wed Apr 14, 2021 10:54 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
^^^ all of this!
dont bother with stainless.
you can buy rolls of cunifer brake line and all kinds of fittings from fedhill.com
ive been really happy with the eastwood flaring and bending tools. thankfully never had to remake any vanagon lines but this stuff worked amazing one a couple other much higher pressure systems.
the best part of the cunifer as mentioned, is that you can straighten it by hand. it also flares buttery smooth and you dont wear your tools out flaring it.
Thoragaverung wrote: |
If I have a tool to make a bubble flare on the end... that would make things simpler too. Nice hard lines, less chance of leaks. |
i did this on one of my project cars - use hard line to come out to compression fittings (i did An on that setup) and you can adapt those compression fittings to whatever you want from there - nice barbs, actual AN line, etc etc
again the cunifer is super nice to work with here because the larger sizes in any other material get REALLY tough to handle
_________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Posted: Thu Apr 15, 2021 4:22 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
Thank you!
I had one other idea, now that I've gone down the rabbit hole of flaring pipe ends... one could fab up some nice coolant pipes out of 1.5" copper. GoWesty sells those stainless steel ones for 350 bucks a set, but you could get 20 feet of copper in that diameter for 80 bucks. The only thing is, it would be great to flare the ends so the rubber hose wouldn't slip off the copper when the system pressurizes. How could a guy flare something that big? I'm not seeing a tool for that, at least not in the consumer space...
If I did this I think I'd polish the copper and then lacquer it. I think it would look very cool under there. _________________ Happy to help, but my advice comes with no guarantees. Use at own risk. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4794 Location: Bemidji, MN
Posted: Thu Apr 15, 2021 4:47 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
i've been buying my flare fittings and tubing direct from Federal Hill. in addition to a very informative website on SAE vs DIN flares, they stock all sizes of fittings and true Cunifer brand tubing, beware of Amazon.
https://store.fedhillusa.com/
one thing to keep in mind... often the toughest part of a line to duplicate is the snakey part as it goes into the body by the driver and mounts to the master cylinder. frequently, these line sections are in good shape because they are out of the salt and road abrasive spray so one can just install a coupler in the line to use new stuff from the bad part rearward. yes, it means lying on your back using a hand brake flaring tool.[/url] _________________ -dan
www.thefixitworkshop.com |
Posted: Thu Apr 15, 2021 6:25 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
There is a tool for adding a bead to larger pipes. Turbo folks run into this all the time. Pegasus Auto Racing sells one, but it’s more than you’d likely want to pay. You can modify a pair of vice grips to add a bead. My bet there is a you tube video how to do this. _________________ ☮️ |
Posted: Thu Apr 15, 2021 10:04 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
I did that and it works really well! $7 locking pliers, $3 exhaust clamp, random washer. Took me a few minutes to make the tool and takes a few minutes to go around the pipe but for someone who isn't cranking out piping all day long it suits me just fine. I used a cheater pipe to pull down on the pliers because I did not have the hand strength to bend it.
Held 18psi no problem.
Posted: Thu Apr 15, 2021 10:19 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
Cool tool. _________________ ☮️ |
Posted: Thu Apr 15, 2021 11:21 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
djkeev wrote: |
Read up on how Copper and Aluminum play together...... it ain't pretty!
Dave |
Good callout! I guess copper doesn't like OAC coolant much either. _________________ Happy to help, but my advice comes with no guarantees. Use at own risk. |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
Posted: Thu Apr 15, 2021 5:39 pm Post subject: Re: Hard brake line replacement: what size line and fittings? |
Thank you! _________________ Happy to help, but my advice comes with no guarantees. Use at own risk. |
Posted: Fri Apr 16, 2021 4:01 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
I have been examining "The world of tubing" for a cheaper alternative and I note that stainless steel exhaust tubing is both readily available in 1.5" OD and cheaper than other alternatives. I'm wondering... these would be welded down the seam, no? Would that pipe be able to stand up to the pressure of a sealed, hot cooling system? Or would it blow?
This discussion has morphed such that it should probably be its own thread... but WTH... _________________ Happy to help, but my advice comes with no guarantees. Use at own risk. |
Posted: Fri Apr 16, 2021 7:17 am Post subject: Re: Hard brake line replacement: what size line and fittings? |
Exhaust is much hotter than 200 degrees and the measly 20psi is not an issue for any metal tubing.
Maybe if you made tubing out of gallium it would be a problem. _________________ '87 Syncro
