Aug 50 split
Page: Previous  1, 2, 3
Jos.Hall
Jos.Hall is offline
PostPosted: Mon Jul 25, 2016 2:09 am    Post subject: Re: 50 (51?) split excavation Reply with quote
Subscribed because having seen you're past work, I know this won't phase ya.
Schwing
Schwing is offline
PostPosted: Mon Nov 23, 2020 7:01 am    Post subject: Re: Aug 50 split Reply with quote
I have purchased this project from Seth. Seth and I are very good friends. I actually discovered this in the woods a mere 30min from my home 6+ years ago but I wasn't able to land on a price with the seller. The seller died of a heart attack and his son sold this to Seth. For years I would ask/tease/mention/suggest that he sell this to me. Seth is a stand up guy who eventually worked a very fair deal with me.
Let the fun begin.
The plan:
It will be stitched together with as much original panels as I can locate and will show all of its scars. It will not get repainted. I am working on sourcing an oval pan with title. It will stay mostly stock and maintain the spirit of an early split, with some minor touches because I simply can't afford to be a purist. If I can find 16s and they are in the budget, he will stand tall, or it will sit on some 66/67 style wide 5's painted silver. Seth nicknamed the car "Stitch" and I like it.
Here it is being moved from Seth's shop in Philadelphia. It is now in Centreville, MD which is about 20min from where it was discovered.
I purchased all of the donor parts that Seth didn't need for his current 52 project.
The donor parts are almost another Beetle! Smile
This lower section is from another split and was moved here from FL. Its an amazing piece of steel and essentially my jig. It was cut in two so I mounted it to a 62 chassis I had so it can be welded back together. You will see I have full A-pillars too, which will be the first job.
Also a nice dry front clip from another beetle
Its been moving around my shop since I had some other things to wrap up.
Simple enough, put this onto this.
Speedo is in nice condition. We don't know if its a Hoffmann so for now I will run a KMH speedo.
Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - BBXXVII Long Distance Winner
Basketcase
Basketcase is offline
PostPosted: Mon Nov 23, 2020 8:11 am    Post subject: Re: Aug 50 split Reply with quote
aswesome when cat guys work with each other.
'72 Karmann Ghia Coupe (the Boss's)
Rich's 50
Rich's 50 is offline
PostPosted: Tue Nov 24, 2020 10:10 am    Post subject: Re: Aug 50 split Reply with quote
Nice.. looking forward to the updates
type4split
type4split is offline
PostPosted: Fri Nov 27, 2020 5:57 pm    Post subject: Re: Aug 50 split Reply with quote
It’s gonna be fun. Did you get any work done over the last few days ?
'67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'50-something convertible (*need ribbed 'vert quarter panel )
'63 "milo" beetle
Part, parts and more parts
qwertinatom
qwertinatom is offline
PostPosted: Sun Dec 20, 2020 11:14 am    Post subject: Re: Aug 50 split Reply with quote
Really looking forward to seeing this come together!
type4split
PostPosted: Mon Jan 25, 2021 7:40 pm    Post subject: Re: Aug 50 split Reply with quote
Any updates on progress ?
'52 beetle
'55 convertible
'63 "milo" beetle
Schwing
Schwing is offline
PostPosted: Wed Apr 14, 2021 9:27 am    Post subject: Re: Aug 50 split Reply with quote
Sorry I am slacking on updates.
I welded together the lower section and also welded in the A pillar on the passenger side. I've also been collecting a lot of the parts that were missing when I purchased the car 7 months ago.
Assuming I can wrap up some house projects, I expect to make excellent progress this summer.
This is a donor a-pillar. I will final weld it in once I can test fit door, which is pending a new internal frame to be welded so the door can open and close.
Shadetree Westy
sled
sled is offline
PostPosted: Wed Apr 14, 2021 9:54 am    Post subject: Re: Aug 50 split Reply with quote
love it!!
also makes me really thankful I live on the west coast, and in a particularly dry area Laughing
drive your split.
type4split
PostPosted: Sun Aug 01, 2021 6:46 pm    Post subject: Re: Aug 50 split Reply with quote
Any recent work ?
'52 beetle
'55 convertible
'63 "milo" beetle
David
David is offline
PostPosted: Tue Sep 21, 2021 8:11 am    Post subject: Re: Aug 50 split Reply with quote
Any updates?
Cheers,
Dave
*October '54 Ragtop
type4split
PostPosted: Wed Feb 09, 2022 7:42 am    Post subject: Re: Aug 50 split Reply with quote
how's the project going?
'52 beetle
'55 convertible
'63 "milo" beetle
Schwing
Schwing is offline
PostPosted: Wed Feb 09, 2022 8:01 am    Post subject: Re: Aug 50 split Reply with quote
I have been slowly gathering parts in between finishing up some side work and some small jobs on my other vws.
A few weeks ago I picked up a titled 55 chassis and front beam which I immediately blasted and primed with help from my friend Seth.
Also picked up a hood handle, pedal assembly, 50 rear apron, and a couple other bits.
I managed to fit the passenger side door and final weld the pillar so its all aligned. I also cut the quarter to match my donor, in preparation for that to be welded.
Slow and steady!
Here you can see the 50 rear apron:
Shadetree Westy
chicagovw
chicagovw is offline
PostPosted: Wed May 31, 2023 9:42 am    Post subject: Re: Aug 50 split Reply with quote
Any updates on this? Have you ordered a Birth Certificate to help determine if it is possibly a Hoffman?
Schwing
Schwing is offline
PostPosted: Wed May 31, 2023 11:18 am    Post subject: Re: Aug 50 split Reply with quote
I sold this split to a friend who has made some big progress. And yes he received a birth certificate and found it was a Hoffman delivered on Aug 23, 1950. I can let him update the thread.
Shadetree Westy
chicagovw
PostPosted: Wed May 31, 2023 2:00 pm    Post subject: Re: Aug 50 split Reply with quote
That would be great-thank you for the response!
Schwing
Schwing is offline
PostPosted: Thu Jun 01, 2023 5:17 am    Post subject: Re: Aug 50 split Reply with quote
I have a feeling he may never update this thread so I thought I would bring it to closure. While restoring this split a good friend offered another Aug 50 split (824 units older) to me and it was much further along. While I had the capability of fixing this split, I just couldn't justify the time spent doing it for me personally, while raising a family. So I sold it to my friend who has a restoration business and the SKILLS to get it done.
Here is how it sits now, and it is in fact a Hoffman which is cool because there were only 326 Hoffmans in 1950. It was crazy to think I owned two of them for a few months.
Shadetree Westy
Two Glove Boxes
Two Glove Boxes is offline
PostPosted: Tue Jun 06, 2023 9:45 pm    Post subject: Re: Aug 50 split Reply with quote
More Hoffman's! Keep it up!! Applause Applause Applause
Two Glove Boxes
DLK
Page 3 of 3
