Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Wed Apr 14, 2021 9:08 am Post subject: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
So in a previous post I did I had an obvious spring problem. Everytime I was under the Syncro I always looked at it from the day I bought it and it registered as funny.
My brain just didn't click on it.
Cudos to Mark Ward who caught it in about 3 seconds or less when I posted a picture.
Needed new springs so I took advantage of Burley Motor Sports "Fire Sale"
where he has posted new Schwenks Springs that had the packaging burn down around them. The fire temp was not enough to destroy the temper of the metal.
https://www.thesamba.com/vw/classifieds/detail.php?id=2308037
The springs are fine, just light coating of rust because the paint burned off and some melted plastic bag melted onto the spring. a wire wheel removed that quick enough to repaint them.
Painted nice and shiney. (I do not think the OEM VW spring was on there. It is a progressive coul that had collapsed on the 3 center coils.)
So I installed them and the very next day I found bits of black stuff under the Syncro.
The "new" spring pad just disintegrated. It was some new fangled technology and not made of the old fashioned rubber. I put the old pad back in, but it is not a perfect fit to match the coils.
So now my big question - who makes a good quality spring pad? _________________ This free advice is worth exactly what you paid for it.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17109 Location: Retired South Florida
Posted: Wed Apr 14, 2021 9:16 am Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
x2
Quote: |
So now my big question - who makes a good quality spring pad? |
My syncro has no pads at the moment. The problem might be with the pig tail. The factory pig tail likely fits the indent in the trailing arm better than some aftermarket springs might.
I was thinking maybe a rubber pad might work best. _________________ ☮️ |
Posted: Wed Apr 14, 2021 9:24 am Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
MarkWard wrote: |
x2
I was thinking maybe a rubber pad might work best. |
Definitely the pigtail did not help. You can see that the end of it was in the groove, but the wear pattern starts going outside the groove fairly quick.
I had hoped for more then a days use out of them! _________________ This free advice is worth exactly what you paid for it.
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
Posted: Wed Apr 14, 2021 9:30 am Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
I can try using the white cutting board material and mounting it without the spring fully squeezed. Then taking a paint heat gun to it to get the cutting board soft to deformed under the spring pressure. Think it would maybe take two people - one on the jack handle and one watching the deformation because you do not want to squeeze the spring all the way through the cutting board.
You csn probably do it with one person using a bottle jack under the trailing arm as opposed to a floor jack. _________________ This free advice is worth exactly what you paid for it.
Posted: Wed Apr 14, 2021 9:33 am Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
Seems Burley would be the place to go. You need something that can contour but have some flex. Maybe some conveyor belt material. _________________ ☮️ |
Posted: Wed Apr 14, 2021 9:35 am Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
That looks pretty good, but what use would you have for the remaining 14 -1/2' ?
Maybe make an Air Dam if it can hold it's shape againt the wind like my tractor trailer tire does now as my air dam.
It has a nice 18" width for an air dam, _________________ This free advice is worth exactly what you paid for it.
Posted: Wed Apr 14, 2021 9:39 am Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
MarkWard wrote: |
Seems Burley would be the place to go. You need something that can contour but have some flex. Maybe some conveyor belt material. |
First place I checked. Nothing showing on his website for the upper pads. _________________ This free advice is worth exactly what you paid for it.
Posted: Wed Apr 14, 2021 9:49 am Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
Oops, thought those were the lower pads. For the upper, you could probably with patience cut something out of a used tire. _________________ ☮️ |
Posted: Wed Apr 14, 2021 10:10 am Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
MarkWard wrote: |
Oops, thought those were the lower pads. For the upper, you could probably with patience cut something out of a used tire. |
Mark, I've done tires and cutting those steel bands I don't want to cut again ! :wink
That's 9" wide truck tire for my air dam.:
Posted: Wed Apr 14, 2021 10:19 am Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
Steve M. wrote: |
It has a nice 18" width for an air dam, |
Yeah, that was an example, not necessarily saying to buy that specific one. _________________ Dave O
The Western Syncro build
Posted: Wed Apr 14, 2021 11:03 am Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
Quote: |
Mark, I've done tires and cutting those steel bands I don't want to cut again ! :wink |
I could look around the shop for a used up racing slick. They don't contain steel cords. Let me know. _________________ ☮️ |
Posted: Wed Apr 14, 2021 11:32 am Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
MarkWard wrote: |
I could look around the shop for a used up racing slick. They don't contain steel cords. Let me know. |
Thanks for the offer Mark.
Let's give the thread some time. I know I'm not the only one who's installed them so hoping somebody will chime in that has them.
There are a few stores online that sell urethane pads, but I'm hoping to hear some experiences about them. _________________ This free advice is worth exactly what you paid for it.
jimf909 Samba Member
Posted: Wed Apr 14, 2021 12:26 pm Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
Did the air dam improve mileage? Feel free to respond in this thread on air dams, not spring pads. Thanks.
p.s. It's always nice to see pics of your van
_________________ - Jim
Abscate wrote: |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7753 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Apr 14, 2021 12:36 pm Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
D@mn . . . nice price for merely cosmetic damage...
Anyone have any hot (HAHA!) deals on 2wd springs, with or without pads...??? <shrug>
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Wed Apr 14, 2021 12:59 pm Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
OE part number appears to be 701 511 147 Not very common number on the google. My hunch is you could probably find a Moog part that would work.
Another option would be to slide a piece of hose over the end of the coil. That would keep if from metal on metal. _________________ ☮️ |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Wed Apr 14, 2021 1:18 pm Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
Watching with interest as I bought a set of Schwenk springs recently (pre fire sale) but came withou pads, so will need to source something that works soon. _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Wed Apr 14, 2021 2:20 pm Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
Were your original pads toast? I bought fire sale springs last summer and just reused my old pads. He did include new lower spacers however, even though my originals were still good as well
I have not noticed any issues using the original upper pads. They seem to fit fine. What kind of fit issues are you having with the originals? |
Posted: Wed Apr 14, 2021 2:59 pm Post subject: Re: Burley's "FireSale" on Schwenk Springs. Need a Spring Pad now! |
candyman wrote: |
One of my pads was ruined by the previous mech who installed the Seikel 120 progressive springs. Since he installed the top pad on the bottom I guess he felt he needed to do a full-ass job and not get the pigtail lined up on the pad instead of just doing it half-assed. _________________ This free advice is worth exactly what you paid for it.
