Rear Hatch Seal and gap (photos included)
markeaton
markeaton is offline
PostPosted: Thu Apr 15, 2021 4:32 am    Post subject: Rear Hatch Seal and gap (photos included) Reply with quote
Good morning-
Last night I placed in my rear seal on my 1966. It went in easily, did not need adhesive and the door shut without issues.
But... in the 4th photo, when I got close, I noticed I could see through a gap in just this one area. Should I pull the seal slightly out from the frame as it is seated, or does somehow my door need adjusting?
Thank you
-Mark
busdaddy
busdaddy is offline
PostPosted: Thu Apr 15, 2021 7:23 am    Post subject: Re: Rear Hatch Seal and gap (photos included) Reply with quote
Looks like it need adjusting, the hinge can be moved where it bolts to the door, I'd start by loosening the top bolt and lifting up on the door a bit before retightening. Careful, a little goes a long way, put tape around the edges of the opening and along the edges of the hatch, then close it very slowly watching for interference. Some marks around the hinge in it's current position will help too in case you have to put it back where it was and start over.
Слава Україні!
markeaton
PostPosted: Thu Apr 15, 2021 7:45 am    Post subject: Re: Rear Hatch Seal and gap (photos included) Reply with quote
Thank you busdaddy.... will try that tonight !!!
j.pickens
j.pickens is offline
PostPosted: Fri Apr 16, 2021 1:44 am    Post subject: Re: Rear Hatch Seal and gap (photos included) Reply with quote
Also be mindful of the hatch torsion bar tension.
Do not lower the hatch while the hinge bolts are loose.
It can get dangerous.
BeaterBarndoor wrote:
Red Fau Veh wrote:
markeaton
PostPosted: Fri Apr 16, 2021 4:30 am    Post subject: Re: Rear Hatch Seal and gap (photos included) Reply with quote
I was able to loosen the two sets of bolts on each side of the hinge/door. It was tricky for sure. I tried 3-4 times to get it to seat correctly.
I was real close, but realized that I really need one more pair of hand to help me, one on each side to loosen/tighten almost simultaneously to seat 100% perfect.
While I do need to adjust it slightly again, busdaddy's comments helped my and j.pickens, I agree with you and the tension was quite present.
Thanks to all for help.
mandraks
mandraks is offline
PostPosted: Fri Apr 16, 2021 6:29 am    Post subject: Re: Rear Hatch Seal and gap (photos included) Reply with quote
it is also normal for the rubbers to be quite stiff at first. they will settle a little and close better. that was true from new.
regards
Uli
velvetgreen
velvetgreen is offline
PostPosted: Fri Apr 16, 2021 7:15 am    Post subject: Re: Rear Hatch Seal and gap (photos included) Reply with quote
x2 repro rubber is well known to be far stiffer than original and will cause the rear hatch to require more force to close
markeaton
PostPosted: Fri Apr 16, 2021 7:40 am    Post subject: Re: Rear Hatch Seal and gap (photos included) Reply with quote
Surprisingly the rubber (more like sponge) fit in well. No issue at all. I used Wolfsburg West product and fit 100% perfect https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211829193C
markeaton
PostPosted: Fri Apr 16, 2021 7:42 am    Post subject: Re: Rear Hatch Seal and gap (photos included) Reply with quote
The tension I had was not from the seal, but the upper hinges. Which I think adds to a great open and close.
hitest
hitest is offline
PostPosted: Fri Apr 16, 2021 1:57 pm    Post subject: Re: Rear Hatch Seal and gap (photos included) Reply with quote
Some folks (me included based on advice here) loosen the striker "catch" plate bolts right after the new seal goes in. Then every couple weeks- slide the striker closer in to the trunk and tighten. It's a graduated break in of the seal. Eventually it will close flush and seal well again.
FU#5
