Proper crankcase ventilation?
DerrickfromNC1
DerrickfromNC1 is offline
PostPosted: Tue Apr 13, 2021 4:58 pm    Post subject: Proper crankcase ventilation? Reply with quote
A friend of mine will be connecting the following filters directly to his valve covers:
https://www.spectreperformance.com/cat/air-filters-breather
He asked me if it would provide proper ventilation to his newly built 1904cc engine. I told him I would check with the experts here on Samba.
Thanks
BFB
BFB is offline
PostPosted: Tue Apr 13, 2021 5:32 pm    Post subject: Re: Proper crankcase ventilation? Reply with quote
they'll vent and they'll also get saturated in oil then collect dirt & dust.
Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1
txoval
txoval is offline
PostPosted: Tue Apr 13, 2021 5:40 pm    Post subject: Re: Proper crankcase ventilation? Reply with quote
Not good to install those directly to the valve covers as stated above.
Install a breather box on the firewall and run hoses to it
QRP
QRP is offline
PostPosted: Tue Apr 13, 2021 5:55 pm    Post subject: Re: Proper crankcase ventilation? Reply with quote
Thanks
Let him do it then post pics after he drives it for a while.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Apr 13, 2021 5:59 pm    Post subject: Re: Proper crankcase ventilation? Reply with quote
A breather box separates the oil mist from the air. The oil drains back into the engine and the air vents to the atmosphere.
Glenn
Member #1009
#BlueSquare
74 Thing
74 Thing is offline
PostPosted: Wed Apr 14, 2021 10:13 am    Post subject: Re: Proper crankcase ventilation? Reply with quote
Just vent the 1/2 side
kangaboy
kangaboy is offline
PostPosted: Wed Apr 14, 2021 10:18 am    Post subject: Re: Proper crankcase ventilation? Reply with quote
Breather on crank case only. A 1904 doesn't need valve cover venting.
-74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote:
Shocked
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out Laughing
nextgen
nextgen is offline
PostPosted: Wed Apr 14, 2021 3:23 pm    Post subject: Re: Proper crankcase ventilation? Reply with quote
Two guys with quite a bit of engine experience had different opinions as to were to sent the crankcase gases, in an recent post.
Rich Hunt is my carb rebuilder and Alstrup engine specialist
Frist of all I agree you do not need get the gases from the valve covers unless you have a much larger engine.
The discussion was were to send the crankcase gases to the carbs or atmosphere
Rich Said Atmosphere, knowing from his experience it may create issues in the carb like the oil collecting dirt and causing problems.
Alstrup said to the carb or carbs.
Well in my photos I went to Atmosphere and my bug started smelling of burned oil.
Then went to the Carb and the smell went away.
If it did not smell I for sure would have went to Atmosphere.
Sorry Rich, smell won over your logic.
To show how little a breather you need, check out mine made from a aftermarket oil filler tube turned upside down.
Oil and gas go in and up, gas has no problem going to the carb, oil gets slowed down in my inner tube with the holes and drops down the tube (see slots cut at the bottom of that tube) and falls back into the crankcase.
My aftermarket upside down oil filler tube works great.
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
k-weaver
k-weaver is offline
PostPosted: Wed Apr 14, 2021 3:41 pm    Post subject: Re: Proper crankcase ventilation? Reply with quote
There is not enough information about the engine to make this determination. You have big cam with heads to support it turning high RPM; you will need to vent more than just the case.
BFB
BFB is offline
PostPosted: Wed Apr 14, 2021 5:18 pm    Post subject: Re: Proper crankcase ventilation? Reply with quote
yup. then add a turbo and see how much venting you need, especially if the engine is older and has any blow by.
Jason37
Jason37 is offline
PostPosted: Wed Apr 14, 2021 8:22 pm    Post subject: Re: Proper crankcase ventilation? Reply with quote
Here is a very informative read on the subject.
https://shoptalkforums.com/viewtopic.php?t=118958
madmike
madmike is offline
PostPosted: Thu Apr 15, 2021 4:43 am    Post subject: Re: Proper crankcase ventilation? Reply with quote
Nextgen, how high do you rev that Type IV?
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
Ohio Tom
Ohio Tom is offline
PostPosted: Thu Apr 15, 2021 6:02 am    Post subject: Re: Proper crankcase ventilation? Reply with quote
A few things that Shoptalk forum article has wrong:
Porsche 912 motors only vented the 1/2 side. The 3/4 remained sealed.
It's not the oil ring that "flutters" with high crank case pressures. It's the top compression ring.
Has more to do with ring gaps, but excessive crank case pressure contributes.
ONe of the big points that is missed for dealing with case pressure is ring gaps.
Most folks don't think about it too much. But gaps make a big difference in the amount of blow-by at high rpms (when you are worried about it).
Another one is "internal case porting". This is blending and smoothing the breather ports in the #2 main bearing web. The ports are usually full of sharp corners and very restrictive. Blending and smoothing will allow the case to breather easier and will reduce the amount oil spray in the gasses that vent.
kangaboy
kangaboy is offline
PostPosted: Thu Apr 15, 2021 10:53 am    Post subject: Re: Proper crankcase ventilation? Reply with quote
I guess I'm just lucky then. Actually hit 24psi at the track last weekend.
-18 GTI SE
Shocked
raygreenwood
raygreenwood is offline
PostPosted: Thu Apr 15, 2021 11:23 am    Post subject: Re: Proper crankcase ventilation? Reply with quote
Just for the record....that conversation is missing a lot of info for type 4.
And....it is only speaking of case venting with a carb system.
The factory type 4 system for fuel injected 411/412 and 914 (and to some extent the L-jet injected bus)....is actually a "pull through" system.
It pulls filtered air from the air cleaner (it has a special outlet on the AC).
Then...it pulls this air through a flame trap/splitter....
Then...through 12mm hose into each rocker box where It helps to pull excessive oil and any gases....through the pushrod tubes into the case
Then......gases from the case pass through the "Z" baffle cast into the type 4 case losing some oil vapor....
Then the gases pass through the oil chimney baffle (which works very well by itself for oil separation)....and this is where the "chore boy" scouring pads would be installed........
Then through the factory PCV valve.....and into the intake manifold through the 12mm hose.
So.....type 4 factory injection used manifold vacuum to pull fresh air from teh AC...through the rocker boxes....through the case....out the top and through the manifold.
Most effective PCV and oil separation system I have seen in an air cooled VW.
It takes more vacuum than most carbs generate.
The whole point I was getting at is that in type 4....the vent tubes on the rocker boxes from the factory....were NEVER designed to vent OUTWARD. Why would you want to pull all of that crap through your valve gear?
Ray
nextgen
nextgen is offline
PostPosted: Thu Apr 15, 2021 11:39 am    Post subject: Re: Proper crankcase ventilation? Reply with quote
Madmike, do you think I rev it high if it lasted 30 years, ha.
Seriously like anyone with a T-1 or T-4 Normal revving unless I am showing off on a highway.
It was not built for racing, the engine came out of 914 with a top speed of 127 mph.. I have done 100 easy, 60 to 100 is seconds BUT I will never do it again.
With all the stuff I did to make it hold the road, after 90 the steering gets light.
Freaked me out, but what freaks out cars like BMW's is when they tailgate an hit the gas. W T F!!!
It is a 2.0 71 mm stroke 66 mm. a bit more torque.
Highway speeds it what I wanted and what I got.
nextgen
nextgen is offline
PostPosted: Thu Apr 15, 2021 12:02 pm    Post subject: Re: Proper crankcase ventilation? Reply with quote
MadMike LIke I said I don't baby it, this is last years 60 mile cruise in upstate NY and to the top of Bear Mountain. 50 bugs ( some did not make it )we were 70 mile from NYC and you can see the skyscrapers.
The River is the Hudson, just below West Point Military academy.
https://www.youtube.com/watch?v=Ap0NeT2Q2vc
https://www.youtube.com/watch?v=xSfdw4eAyLI
https://www.youtube.com/watch?v=lIkhkOpF7kU
nextgen
nextgen is offline
madmike
madmike is offline
PostPosted: Thu Apr 15, 2021 1:31 pm    Post subject: Re: Proper crankcase ventilation? Reply with quote
Just wanted to know what rpm's you shift at? ,is all Wink
nextgen
nextgen is offline
PostPosted: Thu Apr 15, 2021 3:18 pm    Post subject: Re: Proper crankcase ventilation? Reply with quote
Oh !!!!!!!! My eyes are the tools I use, it is my ears.
Not a big Tach, Hmmm, now looking at it, I should have put it were my Volt gauge is located.
