vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15280 Location: Deep in the 405
Posted: Fri Apr 16, 2021 12:52 am Post subject: M&H DOT 215/65 drag tires. |
Anybody running the M&H 26X6 slicks or 215/65 DOT drag tires on their Ghia? Will they fit? I'm running 914 Fuchs 2.0L wheels. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1135 Location: Melbourne Australia
Posted: Fri Apr 16, 2021 1:41 am Post subject: Re: M&H DOT 215/65 drag tires. |
I am looking at this set up at the moment.
The points of contact are the edge of the bump stop, the front spring plate bolt and the rear of the guard opening.
with careful trimming of the bump stop and bolt I can fit a 205/60 15 under the back of my 69 Ghia on a 7" rim. The sidewall width is about 8.1 inches, it is close but clears.
the M & H 215 is about 8.4 wide on the sidewall on a 6" rim, so I've had to stretch the rear section of the outer guard, and trim the inner guard to make it fit. You can see the guard work here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=702486&highlight=ian+godfrey
I still don't have the tyre mounted so no pic yet.
Or narrow the torsion. Mike Lawless made new IRS trailing arms to help on his Ghia but I can't remember if he narrowed the torsion as well.
Also every Ghia is a bit different, often side to side as well.
Measure carefully and Good luck |
RickS Samba Member
VeloMikey Samba Member
Posted: Fri Apr 16, 2021 8:46 am Post subject: Re: M&H DOT 215/65 drag tires. |
I am running a 205/65-15 on a 6" Empi Fuchs with zero modifications and no spacer. I am going to try the M&H next.
Pip did it with a genuine 6" Fuchs and a 5mm spacer (I think).
This 63 has a custom CMS 5 3/4" with a custom backspacing too with a 6" Firestone slick.
_________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3907 Location: In Molinya Orbit
