lakeracer69 Samba Member
Posted: Sun Sep 20, 2020 8:53 am Post subject: Another which SCAT lifters with an SC-1 cam |
I have a mild lift and mild duration cam from Schneider, they don't specifically call out what lifters to use. Motor will be a 2180.
SCAT has 3 offerings that I see as well as the SLR offerings which are phosphate coated.
SCAT offerings:
Super Duty 72
Lube-a-lobe with .024 hole
High-rev lightweight solid
Wondering which SCAT one SLR modifies for his.
I even looked at UDO's and it says not for SC-1 blanks.
Which one do folks think should be used with an SC-1 cam blank?
Thanks in Advance |
fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Sun Sep 20, 2020 11:38 am Post subject: Re: Another which SCAT lifters with an SC-1 cam |
Take my advice with a grain of salt since I've not built or run my engine yet, but I went with the Super Duty 72g lifters for my SC-1 ground FK46 cam. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Sun Sep 20, 2020 12:14 pm Post subject: Re: Another which SCAT lifters with an SC-1 cam |
Breaking in an engine now with a SC-1 and Thorsten lifters.
SLR normally uses regular SCAT lifters, not the ones with he window in the side. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
txoval Samba Member
Joined: January 23, 2004 Posts: 3553 Location: The Woodlands, TX
Posted: Sun Sep 20, 2020 12:35 pm Post subject: Re: Another which SCAT lifters with an SC-1 cam |
Udo’s lifters will work...ask him |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Mon Sep 21, 2020 9:37 am Post subject: Re: Another which SCAT lifters with an SC-1 cam |
So do Johnson lifters. I'll be turning the key on a scat type 4 / Johnson lifter combo in a few days time.
Last edited by GARRICK.CLARK on Mon Sep 21, 2020 10:01 am; edited 1 time in total |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Mon Sep 21, 2020 9:58 am Post subject: Re: Another which SCAT lifters with an SC-1 cam |
Steve Long uses Scat blanks and re-grinds both the lifter and the cam so they match as a set.
Never one issue....
Nobody got no time for flat cams... |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Fri Apr 16, 2021 7:01 am Post subject: Re: Another which SCAT lifters with an SC-1 cam |
txoval wrote: |
Aircooled.net's description specifically says don't use them with an SC-1...I'm confused.
https://vwparts.aircooled.net/Udo-Becker-Tool-Stee...ifters.htm _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9755 Location: Oregon
Posted: Fri Apr 16, 2021 7:20 am Post subject: Re: Another which SCAT lifters with an SC-1 cam |
I started a thread on Udo Becker lifters. The very last post on page 2 is directly from Udo himself.
https://www.thesamba.com/vw/forum/viewtopic.php?t=731868&highlight=udo+becker
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Fri Apr 16, 2021 7:21 am Post subject: Re: Another which SCAT lifters with an SC-1 cam |
because they will chip/pit...
Ask me how I know |
txoval Samba Member
Posted: Fri Apr 16, 2021 8:33 am Post subject: Re: Another which SCAT lifters with an SC-1 cam |
The Udo lifters didn't chip because of the cam blank, they chipped because of an error with the hardening process.
Same happened to my Udo lifters with an EP12 blank. Udo is replacing the lifters, granted it has taken 4 months...bad batch of lifters unfortunately
Udo will tell you his lifters will work with any cam blank. |
ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Fri Apr 16, 2021 9:23 pm Post subject: Re: Another which SCAT lifters with an SC-1 cam |
I pulled apart 3 motors I've built using scats and all looked perfect. 2 with the standard "lightweight" (heavy though) and one with the 72g windowed ones.
One was on a c25 with HD singles
72g version was on a web 163 with VW duals
I cant remember the 3rd specs..
I was going to use the windowed version again but went with "web" lifters. They just look like the standard scats and weigh the same (80 something grams).
It appears the pitting issues of the past are gone. If you use the windowed ones I would make sure to soften the edges of the windows and make sure they dont leak from the pushrod cup to inside the windowed area (I've heard of an issue). |
