druuid Samba Member
Joined: April 15, 2021 Posts: 27 Location: West Coast, Canada
Posted: Thu Apr 15, 2021 12:36 pm Post subject: 95 EVC main ECU map sensor issue |
Just joined the club with a 95 EVC!
Mostly in good working order however there is an issue with the ECU map sensor.
Unfortunately on this year the map sensor is part of the ECU.
Does anyone know if you can just replace/repair this part in the ECU?
Anyone have the part# for this internal sensor? I have the skillset to be able to do this work if I can source the part.
Another idea I had was to unsolder and take out old map sensor then solder in an external map sensor like the older model styles but don't know if the ECU would work with it.
My ECU part# is 023906024M for reference.
Any help on this is appreciated! |
wannabecamper Samba Member
Joined: May 09, 2019 Posts: 211 Location: Sunnyside, US
Posted: Thu Apr 15, 2021 1:54 pm Post subject: Re: 95 EVC main ECU map sensor issue |
Inside the ECU. Ebay is the source.
https://www.ebay.com/p/27039055665?iid=114275329711
Or any other ebay listing.
The ECU is located next to the driver side fender near the battery. My recollection tells me it is held by a couple of torx screws. Disconnect the connector, and a few more torx to open the ECU itself. There are a few soldering tabs that you have to unsolder and resolder. |
druuid Samba Member
Posted: Thu Apr 15, 2021 2:23 pm Post subject: Re: 95 EVC main ECU map sensor issue |
Thanks, how did you find this part# and info on this ECU?
I have been perusing eBay for something and do want to make sure to get the right one!
I'll definitely take it apart and take a look to confirm if I can.
Thanks!
wannabecamper wrote: |
VAEV1993 Samba Member
Joined: January 17, 2014 Posts: 153 Location: Harrisonburg, VA
Posted: Thu Apr 15, 2021 5:19 pm Post subject: Re: 95 EVC main ECU map sensor issue |
Yeah. As said above, open up the ecu and you’ll see the p/n for the map sensor and can search based on that. It worked for me really well on my ‘93. Good luck and keep us posted. _________________ 1993 Weekender - Hula
2002 Golf TDI
2017 Golf Alltrack |
BALDY & BLONDIE Samba Member
Joined: July 12, 2013 Posts: 14 Location: United Kingdom
Posted: Fri Apr 16, 2021 7:26 am Post subject: Re: 95 EVC main ECU map sensor issue |
also try checking/replacing vacuum hoses, made a huge difference to mine, also a 95 |
druuid Samba Member
Posted: Fri Apr 16, 2021 9:17 am Post subject: Re: 95 EVC main ECU map sensor issue |
Good tip, already tested the hose and pressure is good!
BALDY & BLONDIE wrote: |
druuid Samba Member
Posted: Fri Apr 16, 2021 11:09 am Post subject: Re: 95 EVC main ECU map sensor issue |
Referencing your old post photo inside the ECU it definitely looks like something I can do (I was worried it was more integrated than the 3 pins I see).
Will post updates here when I get it out and hopefully fixed!
Thanks again for all the support!
For others cross reference this is the excellent post where there is a picture of inside the ECU and MAP sensor:
https://www.thesamba.com/vw/forum/viewtopic.php?t=683873
VAEV1993 wrote: |
Yeah. As said above, open up the ecu and you’ll see the p/n for the map sensor and can search based on that. It worked for me really well on my ‘93. Good luck and keep us posted. |
druuid Samba Member
Posted: Tue May 25, 2021 5:02 pm Post subject: Re: 95 EVC main ECU map sensor issue |
I fixed the issue successfully!
I've posted full detailed instructions in the post noted below on how to do the fix yourself (info on a replacement MAP sensor also in the post).
https://www.thesamba.com/vw/forum/viewtopic.php?p=9645150#9645150 |
Posted: Thu May 27, 2021 11:55 am Post subject: Re: 95 EVC main ECU map sensor issue |
Thanks for the detailed write up and contributing to the community! |
