June '68 Manx Period Restoration
calebmelvin
calebmelvin is offline
PostPosted: Thu Apr 15, 2021 6:06 pm    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Thanks you guys! I really appreciate it! I am deep into editing now. It is quite an adventure.
Caleb
'68 Tagged Manx | My Wanted Ads
calebmelvin
PostPosted: Fri Apr 16, 2021 9:07 am    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Two become one!
A friend helped me pick up the body at my other garage in style.
It was such a beautiful spring day, I decided to do the work outside.
And it is together! I need to finish bolting down later today but it is starting to look like a buggy now! My little helper approves.
Caleb
matthewl
matthewl is offline
PostPosted: Fri Apr 16, 2021 9:19 am    Post subject: Re: June '68 Manx Period Restoration Reply with quote
It's coming together nicely.
Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber
Kreelak
Kreelak is offline
PostPosted: Fri Apr 16, 2021 9:32 am    Post subject: Re: June '68 Manx Period Restoration Reply with quote
looking fantastic
what are you using to attach the body to the pan
calebmelvin
PostPosted: Fri Apr 16, 2021 10:21 am    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Kreelak wrote:
looking fantastic
Thanks! I am using the body mounting hardware kit from Meyers Manx and the original bug rectangular washers on the underside of the pan.
Caleb
calebmelvin
PostPosted: Tue Apr 27, 2021 2:02 pm    Post subject: Re: June '68 Manx Period Restoration Reply with quote
It has been a bit slow going recently.
I finally got around to replacing one of my e-brake cables. I messed the last one up while shortening. I also put together my freshly restored Dietz 820's.
I had a bit of an issue with the wiring harness, and after struggling with it for more than a day, I ripped it back out. I am having Mike at Dune Buggy Brothers make me a custom harness now. I used his on my last buggy but I was itching to try something else...well now I have learned my lesson.
It has been so nice to be able to work outside!
Caleb
parmaynu
parmaynu is offline
PostPosted: Wed Apr 28, 2021 1:06 am    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Im loving your build. Thank you!
Did you modify the tail light housing to fit?
calebmelvin
PostPosted: Wed Apr 28, 2021 6:17 pm    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Thank you!
No they are completely stock. I found a NOS pair and had them chromed. I did have to drill out the studs and replace with bolts, because the Manx body is much thicker than the bug. But otherwise you just tighten them down and they fit pretty flush with the seals!
Caleb
calebmelvin
PostPosted: Wed Apr 28, 2021 6:32 pm    Post subject: Re: June '68 Manx Period Restoration Reply with quote
The small things are so much fun! Put on the front badge and license plate today. Also got the dash squared away by test fitting the gauge and switches.
Caleb
TimGud
TimGud is offline
PostPosted: Wed Apr 28, 2021 6:38 pm    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Wonderful build! Getting ready to restore a buggy myself soon.
I do have one small tip. Rotate the swing axle boots 90 deg as they were designed for. If you leave the seam upright it will crack the boot as it doesn’t flex when the axle comes up.
calebmelvin
PostPosted: Thu Apr 29, 2021 8:45 am    Post subject: Re: June '68 Manx Period Restoration Reply with quote
It is on my list of things to fix but that list just keeps getting longer! haha
Thanks for reminding me!!
Caleb
calebmelvin
PostPosted: Wed May 05, 2021 1:10 pm    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Not much to report. I did get the NOS Lucas signals mounted today. And finally put on my registry tag. Progress! haha
Caleb
matthewl
matthewl is offline
PostPosted: Wed May 05, 2021 8:28 pm    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Progress is progress no matter how small. Looking good, won't be long and you will be taking it for a summer cruise.
joey1320
joey1320 is offline
PostPosted: Thu May 06, 2021 6:07 am    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Amazing work mate Cool
**1971 Super Project
westy
westy is offline
PostPosted: Sat May 08, 2021 9:55 am    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Popcorn
...everyone has something to teach you.
Support our troops. Not all injuries are visible ones.
calebmelvin
PostPosted: Thu May 13, 2021 3:03 pm    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Thanks guys. I always feel like things come in bursts. Right now I am waiting on the wiring harness and after that a lot can get done quickly!
I did work on one project that has been on my list for a while. I fabricated the sheet metal panel that came with the kit to fill in under the license plate. It actually wasn't bad to make. Got my plates on as well!
Caleb
matthewl
matthewl is offline
PostPosted: Thu May 13, 2021 7:21 pm    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Looking good Caleb. Can't wait to see it done.
parmaynu
parmaynu is offline
PostPosted: Fri May 14, 2021 12:17 am    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Would you mind sharing the dimensions of that rear plate? Does it fit to the licence plate studs?
calebmelvin
PostPosted: Sat May 15, 2021 8:27 am    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Yes, the top attached to the license plate studs!
Nelson gave me this info:
Caleb
BL3Manx
BL3Manx is offline
PostPosted: Sun May 16, 2021 6:20 am    Post subject: Re: June '68 Manx Period Restoration Reply with quote
Here are a couple better pictures.
The best way to mount the plate at the top is using the studs which mount the license plate light, it would save drilling holes in the body. However you would need to replace the original studs with longer ones. If you do use the license light studs to mount the stainless panel, when you fabricate the panel, you should ensure it's tall enough to extend up where the two lower license light mount studs will pass through it.
Page 4 of 6
