VeloMikey Samba Member
Posted: Thu Apr 15, 2021 3:15 pm Post subject: Re: '59 Karmann Ghia fever |
Just hook it up, then hook up the battery and pull the knob out! You are way over thinking this. _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Fri Apr 16, 2021 5:38 am Post subject: Re: '59 Karmann Ghia fever |
VeloMikey wrote: |
Just hook it up, then hook up the battery and pull the knob out! You are way over thinking this. |
Ha! You must be new to the thread — welcome! _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
Trylon Samba Member
Trylon Samba Member
Posted: Fri Apr 16, 2021 8:08 pm Post subject: Re: '59 Karmann Ghia fever |
Was in the neighborhood of Joe’s Auto Electric today and hoped to have tales to tell about our generator.
Unfortunately, could not make it there before closing so it’s been back burnered again.
Will be back around there beginning of May to finalize my robot project and will try again.
Back to the wipers tomorrow. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Sat Apr 17, 2021 9:19 am Post subject: Re: '59 Karmann Ghia fever |
Wiper Day
As I could not get the motor to move on 12 volts, pulled the cover and had another look (had replaced the 6v armature with 12v a while back).
With my newly acquired electrical knowledge, I immediately saw that I had not arranged the brushes correctly, they were resting on top of the armature instead of pressing against it.
This gave me hope — rearranged them and gave it another shot.
Nada.
Thought the brushes might be corroded, so lightly sanded them.
Nada.
So I attempted to turn the wiper by hand — it was quite difficult so I sprayed a bit of WD40 at the juncture where the actuator meets the body and tried again.
It did move but only a bit, each time I applied the voltage, and then stopped.
So I spent some time working the actuator by hand to free it up more and sprayed electrical cleaner on the contact points.
Better but no cigar:
I am finding continuity between the hot connection and the grounding body with about 2ohms of resistance. That would lead me, via ohms law, to expect 6 amps. Getting .6 ish so I must be reading the ohms wrong (0.2 ?) or the display is not in whole ohms?
Anyway, any thoughts would be appreciated. My next thought is to remove the armature and check out greasing. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Loren Samba Member
Posted: Sat Apr 17, 2021 12:23 pm Post subject: Re: '59 Karmann Ghia fever |
Have you removed the base plate to clean the gears and replace the grease? Over time the original grease tends to solidify and keep the gears from moving smoothly. |
Trylon Samba Member
Posted: Sat Apr 17, 2021 12:40 pm Post subject: Re: '59 Karmann Ghia fever |
Loren wrote: |
Yes, I believe I did this but I will check again.
Thanks Loren! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Sat Apr 17, 2021 12:58 pm Post subject: Re: '59 Karmann Ghia fever |
Moving forward.
Guess I can put the visors and rear-view mirror back:
Went to my local hardware store and found rubber washers to use instead of the grommet that doesn’t fit. Seems to be more like what was used originally anyway (5 & 6):
Put some permatex between them to finesse a grommet.
The white nylon bushings for the wiper control rods don’t fit either— not in the hole or on the wiper hub. (For your reference, those white bushings in the baggie):
Luckily, the wiper rods seem to have serviceable ones installed.
So, got the hubs on:
And the wipers:
I am sure that there will be adjustment fun when I get the motor installed.
But, there they are.
Silver wipers. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Loren Samba Member
Posted: Sat Apr 17, 2021 1:07 pm Post subject: Re: '59 Karmann Ghia fever |
Your Ghia is looking great! A note of caution on the visors though, you might want to leave them off until we source the attaching hardware, especially the pieces at either end. Without these pieces in place to support the visors they might crack or break when the Ghia goes over a big bump. |
Trylon Samba Member
Posted: Sat Apr 17, 2021 1:11 pm Post subject: Re: '59 Karmann Ghia fever |
Loren wrote: |
Darn!
Ok, before I go for a drive, if the hardware is still not there, will pull them but leave the mirror. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3914 Location: In Molinya Orbit
Posted: Sun Apr 18, 2021 3:47 am Post subject: Re: '59 Karmann Ghia fever |
When you finally succeed with getting the motor to go, have the wiper arms off the screen just in case you have made an error with the motor arm and linkages. The error could send the arms downwards to the paint rather than upwards to the glass. Not a problem if the arms are lifted and away from the paint.
I encountered this during my foray into wiper motors and found the nicest looking one in my small collection was the worst one to use because it pushed in the wrong direction.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Trylon Samba Member
Posted: Sun Apr 18, 2021 5:08 am Post subject: Re: '59 Karmann Ghia fever |
That was my plan, Nicolas, but had no clue just how bad it could have been.
Could you have reversed the polarity by exchanging wires on the brushes? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Sun Apr 18, 2021 11:36 am Post subject: Re: '59 Karmann Ghia fever |
Pulled the base plate on the wiper motor.
Yuck:
Cleaned and greased:
Now works like a charm including the self-parking circuit!
Now I need to get/fashion a grounding tab. And figure out what bolts are used to attach the motor to the bracket.
Had a thought for grounding the interior light.
Attach the ground wire to this piece that I crimped and slide it on the framework provided for the light:
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Mon Apr 19, 2021 5:19 am Post subject: Re: '59 Karmann Ghia fever |
Well, darned if I can find any information regarding how the wiper motor is bolted to the strut.
Screw? Bolt? Washer? Size? Direction?
I’m sure I could just wing it but I am equally sure I will get called on it if I do. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Loren Samba Member
Posted: Mon Apr 19, 2021 9:17 am Post subject: Re: '59 Karmann Ghia fever |
The screws are "cheese head" screws. They have a round top with a slot, very similar to the screws that hold the engine tin together (you might even be able to use engine tin screws). Though it doesn't have a clear image of the screws this post might help with some of the original details for the wipers and wiring:
These images might help too:
The aussie Trimmer Samba Member
Joined: July 05, 2006 Posts: 385 Location: Western Australia
Posted: Mon Apr 19, 2021 3:49 pm Post subject: Re: '59 Karmann Ghia fever |
I know that area's on the inside of the body is going to be covered by rubber or carpet and unseen, but it too deserves some TLC and to be cleaned up and have a fresh lick of paint to seal the metal.
or am I just OCD? anyway that's what I would do. _________________ Cheers,
Kev.
Drive with your lights on (Be aware be seen) help others GIVE Blood |
Trylon Samba Member
Posted: Mon Apr 19, 2021 5:22 pm Post subject: Re: '59 Karmann Ghia fever |
Thanks Loren.
Went to the hardware store before your response and gathered hardware that I thought might work but would much rather get it close to right.
Tried the cheesehead screws for the tin but try as I might it seems that they may be just one size too big. Will try again and, if no luck, will seek out the right size.
Surprised to see the rubber — as it doesn’t seem to make sense to electrically isolate the motor, I gather it is there to help dampen vibration. Will at least add some rubber washers.
Also tried to sort out the wiring for the motor. Not sure the harness came with all that is needed but I have plenty of wire to spare. Have a screw terminal switch on its way.
Tried out my idea for grounding the interior light. Works like a charm so that portion of the project is complete— all three positions of the light switch work.
Moving on, decided the next easiest harness would be the headlights.
Pulled them and had a look-see:
Loren pointed out a crack in one of the running lights:
Now I’ve really done it:
Looks like I should get new seals. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
obus Samba Member
Joined: March 08, 2001 Posts: 11065 Location: just off Garden State Parkway Exit 81
Trylon Samba Member
Posted: Mon Apr 19, 2021 7:45 pm Post subject: Re: '59 Karmann Ghia fever |
obus wrote: |
while you have that revealed i would throw a coat of wax inside those headlight buckets but thats me. When i dont know wtf im doing i generally just try to clean things. |
Interesting that you bring that up.
Asked Dwayne what I should do to keep up our car’s finish. Was surprised when he just said to keep it clean— doesn’t have a can of wax in his shop.
Commence comments.... now! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
obus Samba Member
