calebmelvin Samba Member
Joined: July 19, 2006 Posts: 3140 Location: Seattle, WA
Posted: Fri Apr 16, 2021 9:07 am Post subject: Re: June '68 Manx Period Restoration |
Two become one!
A friend helped me pick up the body at my other garage in style.
It was such a beautiful spring day, I decided to do the work outside.
And it is together! I need to finish bolting down later today but it is starting to look like a buggy now! My little helper approves.
_________________ Caleb
'68 Tagged Manx | My Wanted Ads
matthewl Samba Member
Kreelak Samba Member
Joined: September 19, 2011 Posts: 122 Location: Ridgefield Washington
Posted: Fri Apr 16, 2021 9:32 am Post subject: Re: June '68 Manx Period Restoration |
looking fantastic
what are you using to attach the body to the pan |
Posted: Tue Apr 27, 2021 2:02 pm Post subject: Re: June '68 Manx Period Restoration |
It has been a bit slow going recently.
I finally got around to replacing one of my e-brake cables. I messed the last one up while shortening. I also put together my freshly restored Dietz 820's.
I had a bit of an issue with the wiring harness, and after struggling with it for more than a day, I ripped it back out. I am having Mike at Dune Buggy Brothers make me a custom harness now. I used his on my last buggy but I was itching to try something else...well now I have learned my lesson.
It has been so nice to be able to work outside!
parmaynu Samba Member
Joined: March 29, 2004 Posts: 182 Location: Kent, England
Posted: Wed Apr 28, 2021 1:06 am Post subject: Re: June '68 Manx Period Restoration |
Im loving your build. Thank you!
Did you modify the tail light housing to fit? |
Posted: Wed Apr 28, 2021 6:17 pm Post subject: Re: June '68 Manx Period Restoration |
parmaynu wrote: |
Thank you!
No they are completely stock. I found a NOS pair and had them chromed. I did have to drill out the studs and replace with bolts, because the Manx body is much thicker than the bug. But otherwise you just tighten them down and they fit pretty flush with the seals! _________________ Caleb
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Wed Apr 28, 2021 6:38 pm Post subject: Re: June '68 Manx Period Restoration |
Wonderful build! Getting ready to restore a buggy myself soon.
I do have one small tip. Rotate the swing axle boots 90 deg as they were designed for. If you leave the seam upright it will crack the boot as it doesn’t flex when the axle comes up. |
Posted: Thu Apr 29, 2021 8:45 am Post subject: Re: June '68 Manx Period Restoration |
TimGud wrote: |
It is on my list of things to fix but that list just keeps getting longer! haha
Thanks for reminding me!! _________________ Caleb
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
westy Samba Member
Joined: June 16, 2004 Posts: 154 Location: isle of misfit bus owners
Posted: Sat May 08, 2021 9:55 am Post subject: Re: June '68 Manx Period Restoration |
_________________ ...everyone has something to teach you.
Support our troops. Not all injuries are visible ones. |
Posted: Thu May 13, 2021 3:03 pm Post subject: Re: June '68 Manx Period Restoration |
Thanks guys. I always feel like things come in bursts. Right now I am waiting on the wiring harness and after that a lot can get done quickly!
I did work on one project that has been on my list for a while. I fabricated the sheet metal panel that came with the kit to fill in under the license plate. It actually wasn't bad to make. Got my plates on as well!
Posted: Fri May 14, 2021 12:17 am Post subject: Re: June '68 Manx Period Restoration |
Would you mind sharing the dimensions of that rear plate? Does it fit to the licence plate studs? |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Sun May 16, 2021 6:20 am Post subject: Re: June '68 Manx Period Restoration |
Here are a couple better pictures.
The best way to mount the plate at the top is using the studs which mount the license plate light, it would save drilling holes in the body. However you would need to replace the original studs with longer ones. If you do use the license light studs to mount the stainless panel, when you fabricate the panel, you should ensure it's tall enough to extend up where the two lower license light mount studs will pass through it.
