mdross Samba Member
Posted: Thu Apr 15, 2021 12:50 pm Post subject: 74 SB 34 pic 3 carb parts |
Does anyone make a needle and seat for the Empi 34mm pict 3 carb that will not leak when engine is not running? This is not right especially with a new carb. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Thu Apr 15, 2021 1:25 pm Post subject: Re: 74 SB 34 pic 3 carb parts |
mdross wrote: |
EMPI? Good luck. Definitely contact EMPI, return it back if they cannot help. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Starbucket Samba Member
Posted: Fri Apr 16, 2021 12:22 pm Post subject: Re: 74 SB 34 pic 3 carb parts |
Did you check the float level? If set too high it can't turn off. Remove the top and use a short piece of gas line and blow in it and push the float up and see if it leaks. |
