erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Thu Apr 15, 2021 8:57 am Post subject: Re: stock speakers |
gbrandt wrote: |
cut the back of the old speakers and mount them on the door card. Looks stock and won't hit the dash. This assumes that the speaker fits that way. |
I agree that this is the best way to get those to work while clearing the window crank and dash.
The 6.5"s I installed straight to the metal on the door were 2.54" deep, so the 2.6" depth of those Focals shouldn't be a problem. |
SteveMc Samba Member
Joined: December 19, 2013 Posts: 210 Location: Alberta, Canada
Posted: Thu Apr 15, 2021 8:40 pm Post subject: Re: stock speakers |
Thanks for the comments. I’ve done enough measuring, sketching, and test fitting that I’m confident they will fit nicely. The dash will cover a small portion of the speaker. My truck never had speakers in the doors so I don’t have stock grills. I have GoWesty heavy duty high offset window cranks that easily clear the grills that came with the Focals. _________________ 1986 Transporter Single Cab Syncro |
oasis Samba Member
Posted: Fri Apr 16, 2021 1:33 pm Post subject: Re: stock speakers |
Man, you guys have me thinking, thinking, and thinking. If I did this in school, I would have been a straight-A student. I love the varied responses and approaches. I even may have a decision soon. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
Vanuber Samba Member
Joined: February 16, 2020 Posts: 411 Location: Virginia
Posted: Fri Apr 16, 2021 6:29 pm Post subject: Re: stock speakers |
I wanted to keep a stock look and keep the OEM speaker grills intact on my '85 Westy. The stock grills will accept a 3.5" speaker without modification. I used the Hertz DCX 87.3 - https://www.crutchfield.com/S-TCIw8eTOYZl/p_301DCX873/Hertz-DCX-87-3.html - photo below.
They have a cardboard rim around the speaker that give it the perfect offset from the face of the grill. Remove the old speaker from the grill with a heat gun and a twisting motion. Trim the mounting ears and seal the gap around the perimeter with silicone.
3.5" speakers certainly lack bass, but they were a big upgrade from the blown out Blaupunkt's and the van is unmolested.
_________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
'02 Subaru Forester 2.5L |
oasis Samba Member
Posted: Sat Apr 17, 2021 6:09 pm Post subject: Re: stock speakers |
For better or for worse, I did make a decision. Or four.
(1) I decided to go with ABS plastic door cards. I got them in grey as that would look better in Sinka. That leaves my current door cards unmolested should I go back to stock radio-delete.
(2) I decided on a Pioneer DEH-S6220BS stereo with CD changer. Finding a single-DIN stereo with CD, Bluetooth, mic, SiriusXM, etc. was quite difficult.
Best Buy link
(3) I decided on Audiofrog GS42 four-inch speakers for the door. They were pricier than the stereo but being able to do a listening comparison between these and brand names I had heard of before at the Crutchfield site, I couldn't pull myself away. The grills will need special holes for their screws, but the grills are nice and understated ... and they are included. I have some ideas swirling in my head if they aren't enough for supplemental speakers, but we'll see.
Crutchfield link
(4) I decided on the GoWesty high-offset window cranks. I will still have the old ones should I go back to stock, and the average Joe won't know they're not stock. I did a test drive imagining them closest to my knee. I foresee no problems.
GoWesty link
Hopefully, I will have an install in early May, and I will be pleased. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Posted: Sun Apr 18, 2021 5:25 pm Post subject: Re: stock speakers |
oasis wrote: |
(3) I decided on Audiofrog GS42 four-inch speakers for the door. |
I considered those speakers as well. I like that the grille style is similar to the OEM speakers.
Sounds like a good setup! _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
1971BugGuy Samba Member
Joined: October 16, 2004 Posts: 426 Location: Ontario, CANADA
Posted: Sun May 02, 2021 6:13 pm Post subject: Re: stock speakers |
Nice job on the speakers.
I did a very similar thing and bought the exact same Kicker speakers but I epoxied them in. I wish I had seen your post first since your setup is far easier to change.
I used Ford Taurus window cranks and they come nowhere near to rubbing. There is easily twice the clearance of VW cranks if not more. (I also think they look better)
[/img] _________________ Only a fool or a child would judge a project before it reaches its completion.
1971 Super Beetle
1986 Vanagon Westfalia Weekender |
Posted: Thu Aug 12, 2021 7:37 pm Post subject: Re: stock speakers |
Better late than never. Simple install and I am very happy with the sound.
I removed all of the foam backing, for better clearance, where the speaker is mounted.
Good clearance from GW crank.
Noticed grill, not the plastic, is rubbing a bit on the passenger side. Should be able to remedy that fairly easily.
Driving them with a Continental head, no amp. This is great unit and looks like it belongs. _________________ 1986 Transporter Single Cab Syncro |
