radstude Samba Member
Joined: January 29, 2005 Posts: 397 Location: Lynchburg Va.
Posted: Thu Apr 15, 2021 7:09 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I went to full synthetic Royal Purple oil. When change oil 1 month ago, I cleaned all the white oily mess. I checked yesterday when saw your post. Here what it looks like. I drive the car daily, I don’t know what to do next.
Pegasín Samba Member
Joined: March 11, 2009 Posts: 109 Location: Asturias (Spain)
Posted: Thu Apr 15, 2021 10:21 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Castrol GTX 15W40, untill now, the best oil for reduce noise on tappets.
Before, Mobil 15W40 worked well reducing noise but not as well as Castrol. Gulf 20w50 was awfull for this issue.
I think semi-synth or fully-synth are too thin for our engines on mild weather and oceanic climate (less than 10w40 for example)
15W40 is recommended in the official owner manual.
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Thu Apr 15, 2021 11:46 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Castrol GTX 15W40 IS semi-synth. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
Posted: Fri Apr 16, 2021 7:57 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
GArBa wrote: |
Castrol GTX 15W40 IS semi-synth. |
Here we have a trouble: depending of the market, some Castrol are tagged as "synthetic"... even 20W50
GTX 15W40 was sold in Spain first as mineral, later as part-synthetic and finally as "synthetic technology"...
In 2018 I sent an e-mail to Castrol asking what happening with this oil. The answer was:
"Synthetic technology means oil base is type III with less saturated hydrocarbons (<90%) less sulphur ( <0.03%) and more viscosity (>120). Before was oil base type I. Oils type III are minerals also but with a process called hydrocracking to improvement them."
OK, this is Castrol answer three years ago. Now GTX 15W40 changed again and it's tagged API SN. Before was API SF...
Before 2018: part synthetic and API SF
2018: synthetic technology and API SL
2021: synthetic technology and API SN
alikatcraig Samba Member
Joined: September 09, 2007 Posts: 556 Location: Anaheim, CA
Posted: Fri Apr 16, 2021 6:58 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Here in So-Cal, I run 10-30 in all of my cars. 10/40 or 15/40 causes sludge like you show in my cars. 10/30 with hydraulic lifters is just fine. _________________ 1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug |
GArBa Samba Member
Posted: Fri Apr 16, 2021 11:55 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Let's not start a oil discussion here... regardless of branding. and the answer from Castrol (the switched the type of mineral base), 15W40 is technically a semi-synthetic, but even if it was a modern full synth it would be OK. the recommendation in the manual is based on synthetics of more tan 30 years ago. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
Posted: Sat Apr 17, 2021 9:31 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
GArBa wrote: |
Let's not start a oil discussion here... regardless of branding. and the answer from Castrol (the switched the type of mineral base), 15W40 is technically a semi-synthetic, but even if it was a modern full synth it would be OK. the recommendation in the manual is based on synthetics of more tan 30 years ago. |
Oils... the mother of all discussions |
nagerjaeger Samba Member
Posted: Sat Apr 17, 2021 7:18 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
There is fuel leaking, if I press on the rubber boot, squirting, out of the electrical connector on the top of my fuel pump. Here is a photo with the leaking component crudely circled.
Update: Referenced hopkins comments with photos on the fuel pump from VW girl. Found the Pierburg pump (says it on the side, had the part number on the side) on eBay for $35 including shipping. The leaking pump has no markings. Might be a knock off. I read that there are a lot out there.
Photos and explanations of my fix.
Disassembled swirl pot. Very simple to do. 5 screws. I scratched the case in one place so I'd put it back together the same way. I suspect the swirl pot is after market. The pump certainly is.
Two new pumps!! One in the box. The other was a return that was not boxed so the seller could not resell, and it is brand new. I'm keeping the boxed pump as a spare. I opened the box to make sure it was correct.
You can see here that Pierburg and the part number are stamped on the new pump.
More of the part number.
Pierburg and knock off side by side. Note the difference of the position of the bump.
Knock off being slid into filter. Note the bump is on top.
Knock off all the way in the filter. Note the distance between the bottom of the pump and the bottom of the filter.
Pierburg in the filter, slid in from the bottom. Note the distance between the bottom of the pump and the bottom of the filter.
So far the new pump works great and there are no leaks. I was concerned that the Pierburg might slide down into the swirl pot. But it is so tight in there that I don't think that will happen. I'll keep my eye on it.
Also, I removed the fuel tank, but I don't think I need to do that to pull the swirl pot. I did remove the front wheel for access.
Sotobaggins Samba Member
Joined: February 23, 2016 Posts: 264 Location: Orlando, FL United States
Posted: Sat Apr 17, 2021 7:37 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
"There is fuel leaking, if I press on the rubber boot,"
Might sound dumb check the socket and see if its the pump...
while there replace with new plug ... _________________ 2001 Ultima Clasico Edicion Mexibeetle
2003 Black GTI 1.8T |
GArBa Samba Member
Posted: Mon Apr 19, 2021 7:35 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I suspect the leak comes from the o-ring sealing the pump to the swirl pot. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Mon Apr 19, 2021 7:40 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
nagerjaeger wrote: |
I'll update this post as I learn more. |
Interesting, for interests sake could you please post some photos of the pump disassembled and the Pierburg pump and knock-off? _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
pathfinder_88 Samba Member
Joined: September 30, 2020 Posts: 19 Location: BC, Canada
Posted: Mon Apr 26, 2021 8:48 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Folks,
I’ve got a bad ecu on my ‘95. We attempted to have it repaired however it is sending insufficient voltage to the coil. I’m told the ecu should send 5v to the coil but we are only getting 2.7v. Does anyone have or know of a working used ecu that I can purchase? This could prove to be very challenging! |
Posted: Wed Apr 28, 2021 10:35 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Breather, hose and box of the air filter fully cleaned.
And of course, oil and filters changed...
Look at the water dropping from the oily paste...
Where the hose is conected to the air filter box
After cleaning and blowing with a compressor
Posted: Wed Apr 28, 2021 3:25 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Give it 2 weeks, it’ll will be back. |
Posted: Wed Apr 28, 2021 5:17 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
in the breather box I have a small sponge in the corner section ... just putting it out there _________________ 2001 Ultima Clasico Edicion Mexibeetle
Posted: Thu Apr 29, 2021 9:24 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
radstude wrote: |
Surely... I know
Sotobaggins wrote: |
in the breather box I have a small sponge in the corner section ... just putting it out there |
Thanks! I saw some boxes with absorbing stuffs. I will do it when I found something appropriate |
hopkin Samba Member
Posted: Thu Apr 29, 2021 9:38 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Also, I removed the fuel tank, but I don't think I need to do that to pull the swirl pot. I did remove the front wheel for access. |
Great job, good info here......... _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
GArBa Samba Member
Posted: Fri Apr 30, 2021 7:15 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
that pot is most likely an aftermarket one, it surely is newer than the rest of the car. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
Posted: Sun May 02, 2021 6:27 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Pegasín wrote: |
radstude wrote: |
Surely... I know
1 week and 200 km (120 milles) later...
Posted: Mon May 03, 2021 10:17 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Sunz out. Bugz out. 1998 City Car. 24K kilometers. Not a great photo but I'm loving the bug life today.
