Dave.Arthur Samba Member
Joined: November 02, 2009 Posts: 55 Location: Yarmouth, Nova Scotia, Canada
Posted: Tue Jul 07, 2020 4:23 pm Post subject: Re: JX diesel injector pump boost device |
Wow, good catch on the accelerator lever!
I must have been pressing to hard
I have a replacement! |
JFW Samba Member
Joined: August 06, 2018 Posts: 33 Location: Hølen, Norway
Posted: Fri Jul 10, 2020 1:40 am Post subject: Re: JX diesel injector pump boost device |
Great thread, Dave! Thx. This will be saved. It also reminded me of a thread over at Brick-Yard that might be of interest: http://www.brick-yard.co.uk/forum/the-definitive-smokey-jx-thread_topic33228.html
Br,
Truls _________________ --------------------------------------------------------
1986 Caravelle C Reimo camper (AAZ TD)
1989 Caravelle C Syncro (JX TD, 2xdifflocks, PS)
Museum director.
Bicycle framebuilder.
Thinkerer. |
JFW Samba Member
Posted: Fri Jul 10, 2020 1:45 am Post subject: Re: JX diesel injector pump boost device |
Btw, I just uploaded the original JX manual to the Vanagon Owners group over at FB. It can also be found here: https://www.dropbox.com/s/ruurzjqwledsgj1/Dieselmotor_Mechanik_MKB_CS-JX-KY.pdf?dl=0
Cheers!
Museum director.
Thinkerer. |
dave Friday Samba Member
Joined: July 13, 2013 Posts: 60 Location: Southern Spain
Posted: Mon Jul 13, 2020 5:24 pm Post subject: Re: JX diesel injector pump boost device |
That link didn't work for me heres one I use; Syncrosport.com
Good luck. _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
Now with " sb" engine |
Posted: Mon Jul 13, 2020 10:59 pm Post subject: Re: JX diesel injector pump boost device |
Thanks Waldo for the information about the stuck wastegate,I've been adjusting it and still only have .4 bar! But I have full fueling EGt maxim is 800deg c as a result!!
Thanks folks. _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
JFW Samba Member
Posted: Tue Jul 14, 2020 2:04 am Post subject: Re: JX diesel injector pump boost device |
dave Friday wrote: |
Good luck. |
Strange! It should be shared and easy to access. The one over at Syncrosport only covers the injection system.
Museum director.
Thinkerer. |
Posted: Tue Jul 14, 2020 2:23 am Post subject: Re: JX diesel injector pump boost device |
Yes yours right ,piitty I can't see your manual
Ta,Baz _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
JFW Samba Member
Posted: Tue Jul 14, 2020 2:37 am Post subject: Re: JX diesel injector pump boost device |
Ta,Baz |
Very strange. However I found it another place. Hopefully you'll have better luck here: https://www.vw-bus.ru/docs/T3/Dieselmotor_Mechanik_MKB_CS-JX-KY.pdf _________________ --------------------------------------------------------
Museum director.
Thinkerer. |
Posted: Tue Jul 14, 2020 5:33 am Post subject: Re: JX diesel injector pump boost device |
Thanks that works.
Kr,Baz. _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
Posted: Sun Apr 18, 2021 5:59 am Post subject: Re: JX diesel injector pump boost device |
Further on JX boost enrichment. Im in the process of building an IP for an ALH transplant into my T3. I intend on using the JX boost enrichment device on the mTDI pump under construction.
The manner in which the boost enrichment is actuated is the same between the JX and the more conventional aneroid device. A lever acts upon the fuelling control lever.
I am attaching two images, one of the business end of the JX device where it contacts the fuelling control lever and the eccentric that is rotated when the LDA moves.
Posted: Thu Oct 21, 2021 4:44 pm Post subject: Re: JX diesel injector pump boost device |
In search of knowledge and understanding of the JX LDA (tin can), I came across a manual from Oettinger, covering the addition of a liquid intercooler to the JX, increasing the Turbo boost and modifying the LDA to perform extra fuelling.
Im trying to translate it to english. I ran across this excert and looking for a german speaker to actually translate it rather than Google!
Kontur des unteren Hebels im VL-Anschlag-Bereich dem oberen Hebel angeglichen
Fixiernase des unteren Hebels entfernt
Hebellage gegeneinander so eingestellt, daß VorspannWeg in Nullage 0,2 ... 0,3 mm beträgt
(Z ie 1: Mehrfördermenge)
I believe they want the lower cam profiled (ground down) to fit the contour of the upper cam... |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Fri Oct 22, 2021 12:20 am Post subject: Re: JX diesel injector pump boost device |
The fuel enrichment works the same all these Bosch VE pumps, but the JX pump has an unique shaft/cam system rather than the standard cone driven follower.
The Oettinger modification allows a bit more turn of the shaft which allows more movement of the pin on the cam.
However it is still less than you can achieve on the standard cone system by modifying the plastic bump collar or the entire cone angle. And the spring inside the membrane canister is soft and the preload range is more limited.
So IMO it has really limited potential of adding more power. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
Posted: Wed Oct 27, 2021 9:17 am Post subject: Re: JX diesel injector pump boost device |
Agreed Zoltan. I was just trying to understand what they were doing in the instructions. What I really need to do is add a regular LDA to my pump and clearance the engine cover to fit.
Im having trouble finding a VE aneroid assembly... Any tips? |
ZsZ Samba Member
Posted: Wed Oct 27, 2021 10:33 am Post subject: Re: JX diesel injector pump boost device |
Dave.Arthur wrote: |
OK. The manual says grind down the locating bump on the lower lever then adjust the two levers against each other to have 0.2 to 0.3 mm preload at the resting position
On the german forums there are more agressive levers.
https://www.bulliforum.com/viewtopic.php?t=100375 _________________ Zoltan
pvfahrer Samba Member
Posted: Sat Feb 05, 2022 10:59 am Post subject: Re: JX diesel injector pump boost device |
Not sure if this is still needed:
Match profile of lower lever with VL-limiter-area of upper lever.
Holding protrusion (Fixiernase, not really sure what a good translation is) of lower lever removed.
Levers adjusted against each other that play at rest is 0.2-0.3mm.
(Objective: adjusted fuel delivery) |
weekenderraf Samba Member
Joined: December 16, 2015 Posts: 27 Location: Olen Belgium
Posted: Sun Feb 06, 2022 7:42 am Post subject: Re: JX diesel injector pump boost device |
Yes, also the diagram used in Bosch pumps on Cummins Diesel engines fit as well. You can order these at various diesel repair shops or eBay as well.
https://www.ebay.com/itm/Anaroid-AFC-DIAPHRAGM-for...632-2357-0
As a matter of fact I am just trying to install one and the PO must have done this before. Word of advice is if you open up the pressure box be careful not to grind down the outer rim too much because the diagram will need some surface to seal properly. |
jhax Samba Member
Posted: Sun Feb 06, 2022 4:52 pm Post subject: Re: JX diesel injector pump boost device |
pvfahrer wrote: |
Damnit! I just purchased one from the german shop and paid a lot more on shipping than necessary. Oh well. Going to tuck this away for future reference. |
jhax Samba Member
Posted: Mon Feb 21, 2022 10:08 am Post subject: Re: JX diesel injector pump boost device |
Fixirnase
From what it seems like, the procedure is to rotate the upper eccentric to match the lower, turning it "clockwise" so there is as little space as possible between the lower and upped profile on the fuel line side of the pivot arms. Then cut the profile of the bottom (removing the nose) to match the top. Is that correct? |
Posted: Tue Apr 19, 2022 8:29 am Post subject: Re: JX diesel injector pump boost device |
Looking at the Bulliforum www.bulliforum.com I found quite a bit of information about the T3 LDA.
There is a lot of discussion about re-profiling the lower cam plate, this will allow for more fuelling. However the LDA push rod extension needs to match the boost profile of the turbo.
Their solution was to make a new cam (or grind the existing) and use a stronger spring in the LDA. One is not useful without the other. I am trying to get specifics on the spring and source it now.
BTW I did discover the use of the stop screw adjustment that holds the cam at rest. It is the equivalent of the 'Smoke Screw' in normal LDA discussions. It determines the start of enrichment when the boost comes up based on the RPM/governor. Reducing the length will start enrichment earlier, lengthening will delay enrichment.
I'm posting a picture of the before and after cams.
