Inlet Manifold gaskets woes
k@rlos
k@rlos is offline
PostPosted: Sat Apr 17, 2021 4:05 pm    Post subject: Inlet Manifold gaskets woes Reply with quote
Evening all
I’ve got a 2110 with cb 044 ultra mag heads and idas on scat tracs, it has an appetite for blowing inlet manifold gaskets (head to Manifold) I use the fibre gaskets which I match the ports and torque the manifolds down to 16 lbs ft with flanged m8 nuts. It’s not a difficult job I know but it is getting rather tedious Rolling Eyes
Never had this issue when I had the old drd heads with 44’s on CSP manifolds, used the same gaskets, hardware and torque setting. Scratching my head a bit now... Confused is it down to poor quality gaskets? The lack of material between the inlet port? Would a sealant be better? Any thoughts or suggestions would be greatly appreciated.
Thanks
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Sat Apr 17, 2021 4:18 pm    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
Blown out? Or sucked in?
Blown out would be rather strange. But things happen.
Perhaps the intake valves are a little tight. Or your jetted o the lean side of things.
Sucked in. Are you sure that the manifold base is flat and true?
You can use Locktite 518 sealant in place of the gaskets.
But the head and intake manifold mating surfaces need to be flat, to get the sealant to work correctly.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
k@rlos
k@rlos is offline
PostPosted: Sat Apr 17, 2021 4:22 pm    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
Sucked in, Lash and jetting are spot on. The Manifolds are a few years old and used before I brought them so it’s a good possibility that it’s not perfectly flat. That’s something I will look into further
Thanks
PostPosted: Sat Apr 17, 2021 4:42 pm    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
I have a recent pair of JayCee intake manifolds.
I flattened the mating surfaces with a belt sander. Just to make sure that the mating surfaces are in good nik! Smile
Buy Once, Cry Once!
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Apr 17, 2021 4:57 pm    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
THIS
Also make sure the top of the "ears" that the fastening nuts hold against are parallel and flat. Otherwise you can have uneven torque on the studs.
Glenn
Member #1009
#BlueSquare
modok
modok is offline
PostPosted: Sat Apr 17, 2021 5:14 pm    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
Make sure the manifold will bolt on flat with no gasket......not hanging up on some edge or another. No "rocking"
oprn
oprn is offline
PostPosted: Sat Apr 17, 2021 5:56 pm    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
My manifolds hung up on the top cylinder tin. Had to trim it back a wee bit in a couple places.
We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age)
74 Thing
74 Thing is offline
PostPosted: Sat Apr 17, 2021 6:10 pm    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
All the tips mentioned above about the manifolds being flat and easy on and off without interference and spread a small amount of loctite 518 on the bottom of the manifold with your finger and install (no gasket/no leak).
Wreck
Wreck is offline
PostPosted: Sat Apr 17, 2021 6:17 pm    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
I use a flat piece of thick glass ,In my case a oven window from a scraped stove,spare bug windows work well and a sheet of coarser grit wet and dry sand paper .
Handy to surface all sorts of things . tops of cylinders etc .
The fibre type gaskets dry out over time and shrink , then you get and air leak , then an intake backfire from the lean mixture which blows out the gasket .
One engine I have has very small sealing surfaces , about a 1.5vmm in some places , I just use sealant no gasket after countless fibre gasket failures . The other engine has welded heads /manifolds ,good 5mm sealing surface all round , I use a fibre gasket and glue it to the manifold with a very light smear of ultra grey . I can remove the manifold and the gasket stays on the manifold to be used again .
sled
sled is offline
PostPosted: Sat Apr 17, 2021 9:09 pm    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
zero gasket and this
drive your split.
57BLITZ
57BLITZ is offline
PostPosted: Sat Apr 17, 2021 9:18 pm    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
For several years now, that's what I've been using also!
Thanks for the tip MCMSCOTT!
Jesucristo es mi Señor y Salvador!
k@rlos
k@rlos is offline
PostPosted: Sun Apr 18, 2021 1:03 am    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
Thanks for your input people, I’ll have a tinker today and also order some 518
Many thanks
UK Luke 72
UK Luke 72 is offline
PostPosted: Sun Apr 18, 2021 1:46 am    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
I've been using black RTV, same as my cylinders get and it holds up fine, not difficult to clean up either.
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
k@rlos
k@rlos is offline
PostPosted: Sun Apr 18, 2021 3:16 am    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
I’ve ordered some of the loctite the others recommended. Getting the right hump with it now Rolling Eyes Laughing
If it carries on I might fuck the stroker and ida’s off and get a 1600sp Shocked Laughing Laughing
UK Luke 72
PostPosted: Sun Apr 18, 2021 3:25 am    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
I'm not surprised, gaskets on ported heads aren't my cup of tea tbh.
GARRICK.CLARK
GARRICK.CLARK is offline
PostPosted: Sun Apr 18, 2021 3:27 am    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
I would as many have said check the flatness of the manifolds. To do it properly you need an engineers flat block. Put stuarts Blue on the faces of the manifolds. Wait till it drys, then wrap some 600 paper around the flat blocks and flat the faces till the blue disapear's.. If this problem still happens, me personally would try another set of manifolds. I hope the head/seating surface is flat.
Cusser
Cusser is offline
PostPosted: Sun Apr 18, 2021 6:58 am    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
Hmm - I've always used the metal gaskets between the intake manifold and the cylinder heads. These exist for dual port. Single port heads use a simple metal/copper "ring" but the old seal must be first removed.
Mr. 010
Glenn is offline
PostPosted: Sun Apr 18, 2021 7:54 am    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
Metal for stock heads, fiber for ported heads.
Glenn
Member #1009
#BlueSquare
GARRICK.CLARK
PostPosted: Sun Apr 18, 2021 8:55 am    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
Make sure the area on the manifold where the washers and nut"s fit is flat also. 99 percent of manifolds I see are just cast aluminium and the nut area is always ruff cast and not flat.
If the porting is big and the gaskets are thinon the edges you may also need to weld them to thicken up the thin part of the gasket.
Pics are needed
k@rlos
k@rlos is offline
PostPosted: Sun Apr 18, 2021 10:01 am    Post subject: Re: Inlet Manifold gaskets woes Reply with quote
I’ll blue up the manifolds bases tomorrow and bolt down to see if they and the head surfaces are flat. Will check the surface where the nuts go too, my manifolds have plenty of material around the outside edge but the split between the 2 ports is quite tight.
