kjbtsi Samba Member
Joined: September 14, 2007 Posts: 390 Location: Amarillo, TX
Posted: Fri Apr 16, 2021 5:31 pm Post subject: Early lowback seat question |
I was wondering if the springs for the back of the front seats on a 62-63 squareback are the same as same year of bug. My 63 square someone decided to put highbacks in it, I have several front bug seats and a set of lowbacks from a 66 fastback, just wondering if I can take the seat back springs off the 66 fastback seats and use the springs from a 62 bug instead?
Thanks _________________ "Dammit, every time we have a sweet idea the government has to come and screw it up"-Kyle Broflowski
1966 Bug Bahama Blue(my first car)
1958 Euro Bug
1962 Pearl White Bug
1970 Fastback Clementine
1966 Fastback VW Blue
1970 Fastback Diamond Blue
1967 Bug
1963 VW Variant
1963 Karmann Ghia Ruby Red
1969 VW Variant |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22358 Location: Kimball, Mi
kjbtsi Samba Member
Posted: Sat Apr 17, 2021 11:15 am Post subject: Re: Early lowback seat question |
Is there any difference in the springs on a type3 lowback? I have a set out of a 66, wondering if the spring contour is different or is it the pad that changes the shape at the top of the seat? _________________ "Dammit, every time we have a sweet idea the government has to come and screw it up"-Kyle Broflowski
1958 Euro Bug
1967 Bug
1963 VW Variant
1969 VW Variant |
Posted: Sat Apr 17, 2021 11:41 am Post subject: Re: Early lowback seat question |
kjbtsi wrote: |
Is there any difference in the springs on a type3 lowback? I have a set out of a 66, wondering if the spring contour is different or is it the pad that changes the shape at the top of the seat? |
I think it's a little of both, since the 66 on have a more "squared off top", versus the curved tops of the 65 and earlier cars. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22416 Location: Escondido CA
Posted: Sun Apr 18, 2021 9:43 am Post subject: Re: Early lowback seat question |
Bobnotch wrote: |
kjbtsi wrote: |
I think it's a little of both, since the 66 on have a more "squared off top", versus the curved tops of the 65 and earlier cars. |
You can see the profile difference. The early seats were designed with more of a slab look where the later lowbacks sloped over at the top. Its the early slab look that makes people think a bug seat might work.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Sun Apr 18, 2021 11:32 am Post subject: Re: Early lowback seat question |
What you might also find is that the 66 on springs might be the same, and it's really the seat frame that's different. I only say that as I've converted a few sets of high back seats to low backs. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Qldelsie Samba Member
Joined: September 22, 2019 Posts: 518 Location: Queensland Australia
Posted: Mon Apr 19, 2021 7:46 pm Post subject: Re: Early lowback seat question |
As I am sure you are all aware, they also all "hinge" differently. My Aussie 1970 (so therefore made with pre-1970 low back seats) seat (photo) have the hinge point further forwards than the ones in the top pic of notchboy's post above. Not only is this another reason that you can't "mix and match" bases and backs, but it is also a nuisance when fitting seat covers. I only noticed this negative impact of the forward hinge position when I tried to fit seat covers recently.
Most seat covers nowadays are sold as a "single piece", so that the back and the base are actually a single piece of material. So if you have a seat like mine in the photo, you cannot use a single piece seat cover because when you tilt the seatback forwards, the lower part of the back rest pivots much further forwards. While this allows better space for rear seat passengers to get in, it also means a seat cover tries to pull forward off the base, which it is of necessity tied onto.
I am getting sheepskin covers in mine a) because they are cool in summer (no more sticky shirt backs on the vinyl ) and b) warm in winter. I am also getting a small insert sewed inside the side corners of the back piece to "shape" them a bit better, and give me more lateral support. But I am having to get custom-made covers which have a separate base from the back so I can tilt the seat forwards.
Just thought I would mention the hinge issue............
G
Posted: Tue Apr 20, 2021 7:13 am Post subject: Re: Early lowback seat question |
Qldelsie wrote: |
G
Interesting. Thats one I haven't heard. I have thought the seat bases- with the exception of the latest type seat were all the same - relatively. I know the spring backs and bottoms do have variations in how they sit on the frame and base. But the pivot points remain the same. The base and back frames all pivot the same, but the spring backs do change on the frame from early to late. My seat above is a bad example as it has an aftermarket recliner attached. As well as my last pic in the grouping below. The seatback position has been altered. They are close to a stock position but the pivot points remain the same on the base.
Seat recliner is a bad example of any kind of proper stock pivot point.
t3kg wrote: |
1964 1500 S
joel55bug Samba Member
Posted: Sat Jul 31, 2021 8:08 am Post subject: Re: Early lowback seat question |
My question is more for the seat pads. I have 1963 Notchback and want to use a hair seat pad because currently my drivers seat is the only one needing reupholstered and I want it to resemble the rest of my seats as much as possible. My question is will the a ‘56-‘63 Type 1(beetle) hair seat pad be the same as the early Type 3 hair seat pads? |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17963 Location: Eugene, OR
Posted: Sat Jul 31, 2021 11:13 am Post subject: Re: Early lowback seat question |
joel55bug wrote: |
No, the Bug seats are narrower. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat Jul 31, 2021 12:42 pm Post subject: Re: Early lowback seat question |
Any suggestions on where to find a Type 3 specific hair seat pad? |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13247 Location: Tejas!
Posted: Sun Aug 01, 2021 11:38 am Post subject: Re: Early lowback seat question |
joel55bug wrote: |
swap meets. they are not available new
you could buy the bug ones and add more coconut fiber material. It's called coir. I know someone that bought a kit for mercedes and trimmed them down as well. |
