designer Samba Member
Joined: November 05, 2009 Posts: 484 Location: Idaho-but just the tip
Posted: Sun Apr 18, 2021 2:07 pm Post subject: Propex spontaneously turns itself on |
Second time this has happened.
Went for a 25 mile drive heater off. Got home and about 30m later taking trash out hear the propex running.
Anybody have this experience? Seems to work normally otherwise.
Have I miswired it? Open wire somewhere possibly?
Might have to run it through my aux switch board as a master
On/off
Thank you. _________________ __________
87 Syncro Westy : 2.5l
"It is that annoying, accelerating downhill so I can make it up the next hill in the same gear. Foot to floor hoping I can get out of the way of other cars getting onto the highway." - somebody on here around 2013. |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1826 Location: Vancouver Island, BC
Posted: Sun Apr 18, 2021 2:10 pm Post subject: Re: Propex spontaneously turns itself on |
Hi
Since you don't mention it: is the switch turned to off, and the thermostat set on Minimum? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Sun Apr 18, 2021 5:22 pm Post subject: Re: Propex spontaneously turns itself on |
there are no lights on the display illuminated. I don't think the temp is set to low - probably high, but will check ... are you saying it's reading the atmospheric temp and trying to adjust to that by calling for heat?
I went out and looked - no lights on. pressed the gas button, first temp that popped up was 85. i pressed down arrow to about 35 and then pressed gas button again. and it went off. Then 75 stayed on the screen assuming that is current temp.
My assumption is the unit was totally off when it turned itself on today.
thanks for your help! _________________ __________
