Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Sun Apr 18, 2021 4:46 pm Post subject: Paint for steering box? |
What works good? I like the natural metal look.
Max |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Mon Apr 19, 2021 5:58 am Post subject: Re: Paint for steering box? |
Well....if you like the natural metal look.....call that "silver" for now.... ......and you want to prevent corrosion......order a quart of Master Series silver rust sealer.
Looks great, rough as nails and will likely never rust in your lifetime.
Yeah....its moderately expensive but you WILL end up using it all somewhere and it will be worth the money. Ray |
Posted: Mon Apr 19, 2021 8:28 am Post subject: Re: Paint for steering box? |
I was thinking of clear but it needs to go directly on the cleaned metal. I think the box is cast iron.
Max |
Jason37 Samba Member
Posted: Mon Apr 19, 2021 8:51 am Post subject: Re: Paint for steering box? |
Dupli-color makes a high temp paint in cast iron. I use it a lot. the only downside is it needs to be baked. I spray on my coats, let dry for a week or too, then set in the toaster over for an hour at 300. I'm sure you can get away with the no bake, but I find it really hardens it.
You can see it on my distributor in this pic. a little bronze tone to it.
Posted: Mon Apr 19, 2021 11:36 am Post subject: Re: Paint for steering box? |
Max Welton wrote: |
Max |
Master series goes directly on metal. No primer required. Very self leveling. Absolutely bulletproof and bad-ass silver paint. Great chemistry. It will be waterproof and not rust in your lifetime.
Search on it in the forums. Many people use it.
Ray |
carlos_magnum Samba Member
Posted: Mon Apr 19, 2021 11:52 pm Post subject: Re: Paint for steering box? |
Eastwood has some really good paints also. |
Posted: Tue Apr 20, 2021 6:31 am Post subject: Re: Paint for steering box? |
I painted two type 4 steering boxes with VHT and a short bake time.
They did very well. They also have a silver caliper paint that works very well.....but its not natural metal silver. Ray |
Posted: Tue Apr 20, 2021 6:53 am Post subject: Re: Paint for steering box? |
I've used Duplicolor caliper paint on heat exchangers and brake drum and rotors. Seems to hold up pretty well. I even use it on engine tin with good results. I don't think it comes in clear.
Max |
Posted: Tue Apr 20, 2021 6:30 pm Post subject: Re: Paint for steering box? |
After looking through my collection of paint I found some left over clear engine enamel.
Of course!
I used this on my steel type-3 FI intakes after media blasting. It looked great through several years of all-weather daily-driving. It lasted until I blasted it off and reshot in black caliper paint.
Max |
