Best Transmission Oil?
Ghia73Girl72
Ghia73Girl72 is offline
PostPosted: Mon Apr 19, 2021 5:30 pm    Post subject: Best Transmission Oil? Reply with quote
Our retired local mechanic dude used to top off our trannies with something he called "Unimog gear oil, 120 weight pink stuff...i.e. the good stuff". An internet search for something specific to Unimogs yields bupkes, so I wondered what the fine peeps at The Samba might recommend? We have a 1972 Bus which is about a quart low in transmission gear oil, so the sooner we determine what to buy the better. We also run that stuff in our 1973 Karmann Ghia, so having a few quarts or a box full in the shed would be great. If it matters, we live in north central Arizona, high desert, and summers can be toasty and winters are mild.
Advice? What should I search for? What do you all use?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Apr 19, 2021 5:42 pm    Post subject: Re: Best Transmission Oil? Reply with quote
We have a topic dedicated to what gear lube to use: https://www.thesamba.com/vw/forum/viewtopic.php?t=276529
Glenn
Member #1009
#BlueSquare
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Bay Window Bus All times are Mountain Standard Time/Pacific Daylight Savings Time
