H82WRK Samba Member
Joined: March 04, 2011 Posts: 155 Location: Cincinnati, OH
Posted: Sun Apr 18, 2021 9:02 am Post subject: Any photos of Bugs running same size front and rear tires |
Any type of wheel is fine. Just looking to try to see a set of example 185 50 15 on the front and back. Everything I see everybody’s got a larger rear tire and a smaller front tire. If anybody’s got photos of it on a lowered Bug with a swing axle... even better.
Thanks so much!!
Rachael |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Sun Apr 18, 2021 7:22 pm Post subject: Re: Any photos of Bugs running same size front and rear tires |
H82WRK wrote: |
Thanks so much!!
Rachael |
Not lowered, but Swing Axle with 185 65 15 on my car, front and back:
_________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
H82WRK Samba Member
Posted: Tue Apr 20, 2021 9:59 am Post subject: Re: Any photos of Bugs running same size front and rear tires |
Thank you Hopkin!!! That’s exactly what I was looking for. I have 185 on the front of my bug with 205 in the rear. Wanted to match the fronts and run 185 all around. Knew it wasn’t a huge difference in size but still wanted to get a visual. You are the best!!! |
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 572 Location: South of Raleigh
Posted: Wed Apr 21, 2021 7:07 pm Post subject: Re: Any photos of Bugs running same size front and rear tires |
185/65-15's on mine as well...
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Wed Apr 21, 2021 7:10 pm Post subject: Re: Any photos of Bugs running same size front and rear tires |
195/60-15 all around. 3" drop front and 1" rear.
_________________ Glenn
Member #1009
#BlueSquare |
vwchad Samba Member
Joined: June 07, 2007 Posts: 54 Location: Marysville, Wa
Posted: Tue May 11, 2021 11:55 am Post subject: Re: Any photos of Bugs running same size front and rear tires |
185/70 15s all around on 4.5" Vintage 190 wheels. Car is a 63.
Stock Steve Samba Member
Joined: April 10, 2005 Posts: 1963 Location: My Left Nutmeg State
jhogan59 Samba Member
Joined: August 14, 2020 Posts: 1 Location: Sacramento
Posted: Sat Jun 26, 2021 4:39 pm Post subject: Re: Any photos of Bugs running same size front and rear tires |
vwchad wrote: |
I have a '59 in the planning stage. Please share your suspension setup - dropped spindles, drums or disks, narrowed beam, rear drop, etc.
If I can fit 175/65s (or wider) on Vintage 190s with 2.5" dropped spindles and a stock beam I think I'll be a happy camper. Being able to do it with disks would be icing on the cake. |
vwchad Samba Member
Posted: Tue Jun 29, 2021 12:32 pm Post subject: Re: Any photos of Bugs running same size front and rear tires |
jhogan59 wrote: |
vwchad wrote: |
PM sent with details.....
In short, with my particular set up, I didn't like dropped spindles. They didn't work well for the rest of my suspension to give me what I was after. |
boostretard Samba Member
Posted: Sun Oct 03, 2021 12:05 pm Post subject: Re: Any photos of Bugs running same size front and rear tires |
72 standard with 195/65/15 all around on 15x4.5” smoothies on wide 5 conversion
Car is “nominally” level and front is air adjustable but riding primarily on torsions. Drop spindles and adjustable rear plates.
Others in my gallery:
https://www.thesamba.com/vw/forum/album_search.php...ts=summary |
BruceJ Samba Member
Joined: June 16, 2009 Posts: 236 Location: Portland, ME
Posted: Thu Oct 21, 2021 5:55 am Post subject: Re: Any photos of Bugs running same size front and rear tires |
vwchad wrote: |
Beautiful! Thinking of a similar setup for my '65, same wheels (if I can find them). With the Vintage 190's (which I suppose have thicker mounting flanges), what size lug bolts or nuts/studs did you use? _________________ 1965 Beetle
1972 Westfalia |
