Viewing feedback for: VolkzBitz Email: [email protected] Last Visited: Today |
Ronix Samba Member
Joined: September 24, 2015 Posts: 34 Location: North Dakota
Posted: Tue Jul 14, 2020 7:32 pm Post subject: Re: VolkzBitz - [email protected] |
Purchased a 28 PICT-1 from Tim. His communication, lead Times, and pricing were exceptional. As for the 28 PICT-1 is perfect in a appearance. Cannot was get it installed.
Thanks Tim! |
riverside66 Samba Member
Joined: June 04, 2008 Posts: 218 Location: Sparta, NC
Posted: Thu Jul 23, 2020 7:29 am Post subject: Re: VolkzBitz - [email protected] |
I finally pulled the trigger on one of Tim's rebuilt VW/Solex 34 Pict 3 carburetors, and man what a difference!
I tried (and lost) with a generic Chinese copy, and had worse results with it than a tired old Redline I was using. I bit the bullet, and contacted Tim. It took about 5 weeks, but sure enough right at the 5 week mark I received an email from Tim saying that my carb was ready. I put it on yesterday, and I can honestly say that my bug has never run better!
Thank you Tim!
Volkbitz carbs are now my very first recommendation when someone I know needs a carb replacement. _________________ 1977 Standard Beetle -Sold-
1979 Transporter - "Wheatbread" -Sold- |
AppomattoxVW Samba Member
Joined: June 14, 2015 Posts: 16 Location: Appomattox VA
Posted: Thu Jul 23, 2020 6:26 pm Post subject: Re: VolkzBitz - [email protected] |
Can't be more satisfied with Tim and his work and the 28PCI he sent me for my 1956 Beetle. It looks better than new. My car idles much more smoothly. I assume the carb's bowl will still be filled with gas in 1 week for an immediate start unlike my old carb
_________________ '56 Beetle still have
'65 Beetle
'69 Ghia wish I still had
'73 Super Beetle
'77 Super Beetle Convertable
'82 Quantum TD
'85 Vanagon
'91 Jetta Carat
'93 Eurovan (2)
'99 Jetta
'03 Passat (gave to son with 190,000 miles)
'13 Touareg
'19 Tiguan |
kent70ghia Samba Member
Joined: June 15, 2020 Posts: 176 Location: Tacoma, WA
Posted: Fri Aug 07, 2020 10:20 pm Post subject: Re: VolkzBitz - [email protected] |
Tim remanufactured my 30 PICT 1, for my Ghia. It looked better than new when it arrived and bolted right on. It started right up and runs the best it ever has. I added the screwed in barbed fuel fitting, so never have to worry about it coming out.
Thanks for the great work. |
cruiser Samba Member
Posted: Fri Aug 14, 2020 10:47 am Post subject: Re: VolkzBitz - [email protected] |
15 pages of high praise for Tim and what he does for our Volkswagen community...I'll add yet another recommendation to this LARGE feedback forum posting. Tim performed his magic on my 28 PICT and I couldn't be more satisfied. Excellent communications throughout the whole restoration of it, shipping was speedy and like the last client posting here, bolted right up and the car runs superb. Thank you Tim! I look forward to doing business with you again in the near future. |
levin Samba Member
Joined: November 05, 2017 Posts: 8 Location: Dallas, TX
Posted: Sun Sep 20, 2020 5:36 am Post subject: Re: VolkzBitz - [email protected] |
Nothing I can add that hasn't been said several hundred times.
I've purchased two carbs from Tim so far, and will definitely return any and every time I need a stock carb. |
mxl556 Samba Member
Joined: December 05, 2015 Posts: 62 Location: Vermont
Posted: Fri Oct 09, 2020 5:54 am Post subject: Re: VolkzBitz - [email protected] |
I purchased a 34pict4 from Tim about 6 years ago and it fixed all the problems I had (poor unstable idle, hesitation, leaks, constant need for adjustment). The carb has been working perfectly and needed no adjustments in about 15K miles. Highly recommended! |
scranscran Samba Member
Posted: Tue Oct 13, 2020 3:29 pm Post subject: Re: VolkzBitz - [email protected] |
I just got my carbs back from Tim, and holy crap.....I am beside myself with what a good job he did/does. Sooooooo glad I decided to send them out to him as opposed to buying a set of new Webers. Its going to be awhile before they actually get put on my car since the engine is being rebuilt, but I can't wait till they do! |
zabo Samba Member
Posted: Thu Oct 15, 2020 4:49 pm Post subject: Re: VolkzBitz - [email protected] |
Got a 28pict from tim. its beautiful and my cars driving better than it has in years! thanks!!! _________________ 1960 6 volt sedan- 1978 adventurewagen
–wanted bill spreen atlanta dealer tag frame |
joe cool Samba Member
Joined: August 20, 2006 Posts: 1259 Location: Yolo County CA
Posted: Mon Nov 23, 2020 9:36 pm Post subject: Re: VolkzBitz - [email protected] |
First experience with Volksbitz exceeded my expectations. He corrected stuff I didn’t even know that as wrong. I will be sending more carbs his way. |
nreslifer Samba Member
Posted: Tue Nov 24, 2020 4:07 pm Post subject: Re: VolkzBitz - [email protected] |
Got my carburetor bottom yesterday put it back together today,fired it up it was great not to see and smell gas leaking out of the throttle bushings anymore.Great job guys I'ld recommend VolkzBitz for carburetor work anytime. |
DaBraink Samba Member
Posted: Thu Dec 10, 2020 4:17 pm Post subject: Re: VolkzBitz - [email protected] |
I purchased a new, in the box EMPI 34 PICT 3 and found the choke would not close due to casting material, I tried to return it and was basically told "out of luck if the box is opened". I managed to file down the extra material but never could get it to run correctly. I found the only way it would idle was to back the idle jet out about 1/8th of a turn then use medium blue Locktite to secure it. Over the past year it has been running worse than ever and no amount of adjustments could make it run correctly.
I finally sent my SOLEX 34 PICT 3 to Tim and just installed it today. I bolted it on and it fired right up, idles nicely and has no hesitation as the accelerator pump is set perfectly. I asked for the threaded barbed inlet and was so glad to see it is the proper 5.5mm size to run the German hose.
I run an SVDA and the EMPI would have a horrible flat spot even after many attempts to adjust. Bottom line, just send to Tim and enjoy driving instead of repairing. _________________ If it ain't broke.................find something else to fix.
There's never enough time to do things right, but always enough time to do them over. |
BeeDubyaBugz Samba Member
Posted: Thu Dec 31, 2020 10:59 am Post subject: Re: VolkzBitz - [email protected] |
Awesome buyer. Bought cores from me many times. Very fair and quick payment! Thanks Tim! _________________ ALL LOST IN MARSHALL FIRE 12-30-21
1964 21 window
1963 bug sedan
1963 ragtop bug
1965 Bug convertible
Fire Survivors:
1969 bug autostick
1974 sun bug |
lwhiting Samba Member
Joined: February 06, 2009 Posts: 34 Location: Silverton, Oregon
Posted: Sat Jan 09, 2021 11:04 am Post subject: Re: VolkzBitz - [email protected] |
Just bought a rebuilt 34pict3 from Tim. What a work of art.....thought it should go in a shadow box for display rather than on an engine. A vote of thanks to the folks that keep the volks on the road. Without them we would be doomed to the chinese copy. Larry _________________ 1980 Westy
1973 Land Rover Series 2 |
mloret Samba Member
Posted: Mon Jan 11, 2021 5:39 am Post subject: Re: VolkzBitz - [email protected] |
I can't say enough good things about my experience with Volkzbitz. Tim's communication was outstanding. He answered all of my questions prior to purchase. When I finally made the purchase, the turn-around time was excellent. For months, I had been struggling to get my car to run right after I installed an Empi carb on my '72 Super Beetle. I adjusted and adjusted and adjusted and I just couldn't get the car to hold an idle. I heard that Tim's products would fix my car right up, and the tales were true! My car runs impeccably now! Finally, when adjusting the screws on the rebuilt carb, Tim was kind enough to answer my questions and help ensure that I didn't screw up the settings. All in all an outstanding transaction and superior service. _________________ Michael Loret |
Mercury-man Samba Member
Posted: Sat Jan 16, 2021 9:27 pm Post subject: Re: VolkzBitz - [email protected] |
Tim overhauled my 1967 beetle carburetor.
The turnaround was quick and Tim’s communications were excellent.
Tim does excellent work and has my highest recommendation. |
Mark 75 Super Convertible Samba Member
Joined: December 20, 2014 Posts: 199 Location: Cleveland/Fort Myers Beach FL.
Posted: Fri Jan 22, 2021 7:54 pm Post subject: Re: VolkzBitz - [email protected] |
I just got my 34 PICT from Tim-it's a work of art! It looks better than new, literally. I'm hoping to get it put on my car and try to start it, for the first time in 28 years, in a few days. Quick turn around time, pleasure to deal with. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Tue Apr 06, 2021 3:21 pm Post subject: Re: VolkzBitz - [email protected] |
Another pleased VolkzBitz customer here.
My 30 PICT-1 is happily co-operating with my SparxVerks distributor.
Posted: Wed Apr 21, 2021 5:52 am Post subject: Re: VolkzBitz - [email protected] |
I bought a 34 from Tim outright, and it's a work of art! It looks probably better than they did new! I bolted it on the car, and without touching anything it fired right up and idled perfectly the first time. Honestly, it reminded me of a fuel injected car in that it fired so fast! I haven't driven my car yet, but I'm assuming it will be fine. Thanks again Tim for an excellent product, and excellent service! |
SteveMoore Samba Member
Posted: Fri Aug 06, 2021 1:29 pm Post subject: Re: VolkzBitz - [email protected] |
My A+ rating for Tim got lost in Sambaland. So, Tm did a super job on the 30/31 bolted on, fired up! Thanks Tim nice work there man.
71 super. 1600 205t dist. |
