Joined: August 31, 2013 Posts: 12846 Location: North Carolina
Posted: Mon Mar 29, 2021 12:57 pm Post subject: Re: The DUMBEST things you've found done to engines |
Chickensoup wrote: |
How the hell did you pull that off? maybe you could share? Just a lil bit? or did it break? If it did break, I feel for you |
I did share, just a few posts above in response to your post. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Mon Mar 29, 2021 1:13 pm Post subject: Re: The DUMBEST things you've found done to engines |
TDCTDI wrote: |
I did share, just a few posts above in response to your post. |
Yup, your right. My bad. Btw, is that a silver b5 passat in that picture you posted? It seems most the b5 Passat I come across tend to be silver for some reason. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Mon Mar 29, 2021 2:12 pm Post subject: Re: The DUMBEST things you've found done to engines |
Nope, it’s the other non-vanilla, safe color, metallic grey. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Thu Apr 01, 2021 6:44 am Post subject: Re: The DUMBEST things you've found done to engines |
TDCTDI wrote: |
As if on command.
Movie or it didnt happen....
(Seriously, well done.)
Quote: |
maybe plastic was a poor choice on the engineers fault?!? |
Engineering is not responsible for Idiot User. _________________ .ssS! |
Posted: Thu Apr 01, 2021 7:38 am Post subject: Re: The DUMBEST things you've found done to engines |
Who who wait! That dont look like a tdi! that be a gasser? Either way, it still looks like a close fit. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Fri Apr 02, 2021 7:11 am Post subject: Re: The DUMBEST things you've found done to engines |
Who who wait! That dont look like a tdi! that be a gasser? Either way, it still looks like a close fit. |
TDI, gasser, all the same. Not really any tighter than a Golf or Jetta, & you can’t remove the frame rail in the way on those. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
AutoMechanic Samba Member
Joined: December 28, 2019 Posts: 483 Location: Roanoke Virginia
Posted: Tue Apr 06, 2021 7:59 pm Post subject: Re: The DUMBEST things you've found done to engines |
Let’s see. I know I am a young mechanic but I’ve seen my fair share of screwups in engines. We had one customer who replaced his spark plugs and had slathered anti seize all over the threads and electrodes and had the car towed in saying I don’t know why my engine isn’t running right. I had to clean them up and properly apply anti seize. Later that same guy had the same car towed in with another father and son handy fix again with anti seize this time they replaced the PCM and slathered the anti seize all over the connections and it was acting weird cleaned them off and all good again. I told him not to use anti seize anymore on anything without my help lol. Most of the other stuff is dumb stuff I’ve seen while working in the shop like a guy burning the shop down because he was welding near gasoline and the others is a customer driving in the pit and many other things. |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
Posted: Wed Apr 07, 2021 9:41 am Post subject: Re: The DUMBEST things you've found done to engines |
For those wondering what service mode on a b5 passat looks like...
going to do the balance shaft delete while you're at it? _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Wed Apr 07, 2021 9:46 am Post subject: Re: The DUMBEST things you've found done to engines |
borninabus wrote: |
going to do the balance shaft delete while you're at it? |
Nah, the balance shaft exist for a reason. But I am considering converting to gear driven instead of chain.
This car is already a money pit and it was never even supposed to be lol.
If the chain breaks I can always swap the engine for a v10 TDI _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Tue Apr 20, 2021 5:01 pm Post subject: Re: The DUMBEST things you've found done to engines |
well i was nearly ready to fire up the passat and break in the cam. i just need to tighten the timing belt and hook the accessories back up. I should have it running again 2marrow.
new cam, lifters(the black oxide style), cam bearings, water pump, tensioners, belt, etc.
im posting on this b/c i did something really stupid 2day... I tried using the cam pulley puller backwards and stripped a thread good news is, only the very first thread got goofed up. So all is good now.
i dont know why the video i was watching had me do this. but i did it any way. The factory timing marks were still on there thankfully so the timing is exactly how it was be 4.
Well damn! that boy messed up.
and it being a deisle, your gonna get FILTHY.
I was hungry and didnt want to digest oil, so a banana worked out well.
nearly back together. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
calvinater Samba Member
Joined: September 06, 2014 Posts: 3327 Location: 802 The Pointless Forrest
Posted: Wed Apr 21, 2021 2:54 am Post subject: Re: The DUMBEST things you've found done to engines |
Maybe you should get some gloves. _________________ "Albatross"! |
finster Samba Member
Joined: May 26, 2012 Posts: 7934 Location: north o' the border
Posted: Wed Apr 21, 2021 3:37 am Post subject: Re: The DUMBEST things you've found done to engines |
or you'll have a cock like a tiger's tail! as an old mechanic once said to me... _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Wed Apr 21, 2021 8:03 am Post subject: Re: The DUMBEST things you've found done to engines |
Did you mag out all the valleys in the head to get as much of the particulate out as possible?
Did you check that the galley plugs were still intact in the injector rockers? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Apr 21, 2021 8:55 am Post subject: Re: The DUMBEST things you've found done to engines |
TDCTDI wrote: |
Did you check that the galley plugs were still intact in the injector rockers? |
Yes and no. Hopefully all is well with the second part.
Good news is, it's running, and I timed it right.
It has TONS for power. Although I cant drive it very fast due to the radiator hanging down. And the smoke is nearly gone. I will run I deisle purge and see what happens.
Right now it's got a chirping noise. I double checked all tensoiners. The noise was present before i replaced anything.
I'm thinking it's a bad altenator bearing and sperentene tensioner.
I read over on tdiclub that the outside of the timing belt can rub and make the same sound, so I will see if the candle trick works.
Oh, and I can hear my turbo now
Next on the list now that the cam burn in is complete, is an oil change and filter which will be here tomarrow. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
calvinater wrote: |
Maybe you should get some gloves. |
Not at 16 dollars a box!! _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Dave Samba Elder
Joined: July 11, 2002 Posts: 2691 Location: The Forest Moon of Endor, in the Redwoods
Posted: Wed Apr 21, 2021 11:32 am Post subject: Re: The DUMBEST things you've found done to engines |
guy sold me an engine for an aircooled, dual relief, dual Dellorto 40's, guy said it ran, but it vibrated like hell at idle. I did a valve adjust, oil change, put it on my run stand, and fired it up, thinking the guy didn't know how to synch the carbs...engine at idle almost shook the run stand on it's side.. this ain't no carb synch issue.. pull the head on the 3-4 side...okay, 92's, and 82mm stroke, great!! it's a 2180..pull the other side...no friggin way, says right on the pistons 90.45... yeah it might be a tiny bit out of balance.. _________________ 2003 Samba Chummie Winner- Best Story
"Those that matter, don't mind,
and those that mind, don't matter" |
kingkarmann Samba Member
Posted: Wed Apr 21, 2021 2:11 pm Post subject: Re: The DUMBEST things you've found done to engines |
Engines and the cars that they power are engineered and built for ease of factory assembly. Very little consideration is given when it comes to service ancillary parts like water pumps, starters, spark plugs and the like.
It seem like lately every time I tackle a job on a "modern" car or truck the first step in the procedure is to remove motor mounts, raise transmissions for clearance or remove frame members to gain access to what should be simple repairs. Dumb and frustrating! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
mark tucker Samba Member
Posted: Wed Apr 21, 2021 3:24 pm Post subject: Re: The DUMBEST things you've found done to engines |
I stoped doing diesels after the first 4-71 I did....it took over a year to get all the crap out of the jet clean!!!! 1 they are too effing heavy, 2 they are stinkey,3 nasty...
on another note...that engine only have 1 valve per cylinder?dam chicken hows it run?? just kidding. |
Posted: Wed Apr 21, 2021 3:27 pm Post subject: Re: The DUMBEST things you've found done to engines |
it's actually a two cylinder
I'm sure you already know dis butt those are the injectors you see on the top.
Which is y they call them "pumper dusen" or however you spell it.
Edit, I found the noise. It's just the serpentine belt dampener. If it explodes oh well. It wont be the end of the world.
'66 RIP
'69 RIP
Posted: Wed Apr 21, 2021 5:39 pm Post subject: Re: The DUMBEST things you've found done to engines |
Oh btw, at the last vw meet I was at, I saw this....
The video speaks for itself lol
And this was after we got it running. Engine had a top end "rebuild".
The china carb came with bolts not studs. And the rear bolt was bottoming about and pushing the carb up. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
