howler9 Samba Member
Joined: April 12, 2012 Posts: 30 Location: United States
Posted: Wed Apr 21, 2021 11:14 am Post subject: Stuck Stereo Removal |
Hello all,
I am trying to install an aftermarket radio but my old one seems stuck on one of the corners (bottom, right). Any suggestions on getting this thing out? I'm not as interested in keeping the old intact since it's not working correctly anyway. Many thanks in advance!
_________________ 1984 1.9L Westy |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Wed Apr 21, 2021 11:43 am Post subject: Re: Stuck Stereo Removal |
Normally you’d have 2 tools and pull the head out squarely. Look at the side you have out to get an idea how the tool works and how the head clips in. _________________ ☮️ |
Posted: Wed Apr 21, 2021 11:57 am Post subject: Re: Stuck Stereo Removal |
MarkWard wrote: |
Normally you’d have 2 tools and pull the head out squarely. Look at the side you have out to get an idea how the tool works and how the head clips in. |
Hi Mark, so by squarely do you mean parallel to the dashboard? I did try that and I think I understand the brackets that the tools slide into. It seems one of the brackets may be sticking outward which is why the stereo won't slide out. Please let me know if I understood you correctly. _________________ 1984 1.9L Westy |
4Gears4Tires Samba Member
Posted: Wed Apr 21, 2021 12:10 pm Post subject: Re: Stuck Stereo Removal |
Remove the ash try and access it from above. _________________ '87 Syncro
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
jlrftype7 Samba Member
Posted: Wed Apr 21, 2021 7:47 pm Post subject: Re: Stuck Stereo Removal |
4Gears4Tires wrote: |
Remove the ash try and access it from above. |
. ^^^^^. Sometimes the sleeve/frame distorts and even with the correct release tools, you are stuck on the sides as a ‘finger’ jams radio against the frame. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Apr 22, 2021 4:22 am Post subject: Re: Stuck Stereo Removal |
A heavy enough slide hammer should prove adequately persuasive...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Thu Apr 22, 2021 4:54 am Post subject: Re: Stuck Stereo Removal |
I worked at the dealer when these radios came out. It was the first attempt at a theft deterrent. You would not believe how destroyed interiors were and the radio chassis was still there. We had on convertible that looked like a crime scene. Dash and console destroyed, broken glass, blood everywhere and yet the radio chassis was still there. The joke was we should hang the removal tools from the mirror. _________________ ☮️ |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Thu Apr 22, 2021 5:44 am Post subject: Re: Stuck Stereo Removal |
Since the radio does not work and you have no nostalgic live for it there is one slughty destructive thing you can try without damaging the dashboard.
Take the faceplate off and use a good stout needle nose pliers and possibly a small 6" crescenet wrench
Use the pliers to see if you can curl the offending side inwards toward the center and away from the locking tabs.
Ya gotta be careful cause you can distort the top and bottom into the dash, but I think you'll get the hang of it.
You could probably bend twist crack the entire inside until it's empty of parts....😁 _________________ This free advice is worth exactly what you paid for it.
