VWBeetleObsessed67 Samba Member
Posted: Wed Apr 21, 2021 3:19 pm Post subject: How Do I Use A 1968 VW Shift Knob On My 1967 VW Beetle? |
I Want To Install An Aftermarket Shift Knob In My 1967 VW Beetle But The Knob I Want Has The 1968 And Later Thread... Please Help Me... |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Wed Apr 21, 2021 5:06 pm Post subject: Re: How Do I Use A 1968 VW Shift Knob On My 1967 VW Beetle? |
Some sort of helicoil or similar thread insert may let it work.
"Universal" aftermarket knobs had wide threads and then narrower threads further inside so they would work on either. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Wed Apr 21, 2021 6:10 pm Post subject: Re: How Do I Use A 1968 VW Shift Knob On My 1967 VW Beetle? |
So just what are the thread sizes for these? Possibly a solid threaded insert could be available. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
milo9rat Samba Member
Posted: Thu Apr 22, 2021 11:16 am Post subject: Re: How Do I Use A 1968 VW Shift Knob On My 1967 VW Beetle? |
Stick a piece of rubber hose in the new knob( vacuum, fuel hose, whatever) till you find one that slides into the new knob and screws onto the old one.... _________________ You live. You die. In between you build hot rods. I mean VW's |
KTPhil Samba Member
Posted: Thu Apr 22, 2021 11:25 am Post subject: Re: How Do I Use A 1968 VW Shift Knob On My 1967 VW Beetle? |
Since most accessory knobs have both threads, maybe someone already stuck a thinner piece deep inside the knob, preventing you from engaging those finer threads? |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Tue Apr 27, 2021 7:04 pm Post subject: Re: How Do I Use A 1968 VW Shift Knob On My 1967 VW Beetle? |
Fill the hole with some epoxy. After it cures, drill it tap to the correct size. |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2506 Location: Santa Cruz, CA
Posted: Tue Apr 27, 2021 7:18 pm Post subject: Re: How Do I Use A 1968 VW Shift Knob On My 1967 VW Beetle? |
AirHead1966 wrote: |
↑ This ↑
JB Weld is good for stuff like this. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Tue Apr 27, 2021 7:26 pm Post subject: Re: How Do I Use A 1968 VW Shift Knob On My 1967 VW Beetle? |
How about cutting some kitchen aluminum foil into a long strip about 3/4" wide, then wrap it onto the shifter's threads clockwise until you reach a thickness of about 1/16"? Screw the shifter knob on firmly while pushing down on it. I think the '67's shifter has 7 mm diameter and the '68's knob is 10 mm. 3 mm difference is ~ 1/8"; half of that for the thickness of the foil. |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Wed Apr 28, 2021 5:38 am Post subject: Re: How Do I Use A 1968 VW Shift Knob On My 1967 VW Beetle? |
Or, drop a ‘68+ shifter in the hole & screw your new shift knob on top. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
KTPhil Samba Member
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed Apr 28, 2021 10:36 am Post subject: Re: How Do I Use A 1968 VW Shift Knob On My 1967 VW Beetle? |
… OR just change the stick shifters - put the '68 shifter in your '67 - z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
