bolinasnative Samba Member
Joined: April 21, 2021 Posts: 5 Location: Los Angeles
Posted: Wed Apr 21, 2021 2:39 pm Post subject: Replacement ideas for Eurovan curtain glider stopper? |
I recently replaced the tint on the windows of my 02' Weekender and the tint guy took out all my curtains and never replaced the stoppers that keep the hook gliders from gliding right on out. This an impossible part to find, and even the hooks and gliders are discontinued. (Yes, Gowesty sells a lousy version of them). Trying to figure out a solution to keep the gliders in the track. Anyone have any experience with this or have any ideas? See attached photos of the piece in question. Thanks!
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12103 Location: Port Manteau
Posted: Wed Apr 21, 2021 3:36 pm Post subject: Re: Replacement ideas for Eurovan curtain glider stopper? |
Just yesterday I installed a locking glider I got from GW, to address this exact problem. It was unpleasant to install, but now it's locked in place.
https://www.gowesty.com/product/curtain-parts/2995/curtain-track-glider-lock-each-?v=
_________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
MrPulldown Samba Member
Joined: September 08, 2020 Posts: 649 Location: Truckee
Posted: Wed Apr 21, 2021 5:56 pm Post subject: Re: Replacement ideas for Eurovan curtain glider stopper? |
Was thinking of various decorative tacks with large heads. Cut the pin off and hot glue in place.
_________________ 2002 EVC |
Posted: Wed Apr 21, 2021 9:24 pm Post subject: Re: Replacement ideas for Eurovan curtain glider stopper? |
Thanks for the reply. I actually bought a bunch of those from GW as well- but I now realize they're for Vanagons? All I could figure out to do with them was remove the loop from the rectangular piece and slide that into the track. Which fits, but hangs lower than the OEM loops...I still don't understand how the "lock" works...that's why I posted the OP. Any chance you could post a photo of your installed? |
Posted: Wed Apr 21, 2021 9:25 pm Post subject: Re: Replacement ideas for Eurovan curtain glider stopper? |
MrPulldown wrote: |
Great idea! Thanks! |
Posted: Wed Apr 21, 2021 10:35 pm Post subject: Re: Replacement ideas for Eurovan curtain glider stopper? |
bolinasnative wrote: |
They fit EVs. The tolerances are a little tight, but you have to push up and use a set of pliers to rotate the loop 90 degrees. It's kind of a bitch, but does work. The loop needs to be parallel with the other loops when it's set in place. _________________ Casey--
y u rune klassik? |
rcowan Samba Member
Posted: Thu Apr 22, 2021 10:56 am Post subject: Re: Replacement ideas for Eurovan curtain glider stopper? |
I lost ours on the sliding door curtains. The plug is hidden behind curtains so I went to the local hardware store and got a very small cork plug. I pushed that in the hole. It was a nice and tight fit. It was worked great so far. It was cheap and didn't damage the track incase I can ever hunt down the correct piece.
If it's visible, maybe this solution along with the decorative tack idea? |
Posted: Thu Apr 22, 2021 4:40 pm Post subject: Re: Replacement ideas for Eurovan curtain glider stopper? |
rcowan wrote: |
Also a great idea- thanks. Was actually thinking maybe fill that space where the stopper should be with some kind of putty or epoxy but cork makes more sense- less messy/permanent but still stays in place. |
staxx Samba Member
Joined: September 08, 2008 Posts: 4 Location: San Jose, CA
Posted: Sun Jun 26, 2022 10:09 am Post subject: Re: Replacement ideas for Eurovan curtain glider stopper? |
I used foam ear plugs, just rolled it tight enough to insert it in the track. it's working great so far. |
